Topic: Change FileName And Count NameIndex (Read 1 time) previous topic - next topic
donclemente
Hello together,
i´d like to Change Filename by pressing a button:
Messer00.csv
Logger00.csv etc...
and i want to Count the index up if the file is already exisiting
Messer00 - Messer01.csv etc
  // create a new file
  char filename[] = "LOGGER00.CSV";
  for (uint8_t i = 0; i < 100; i++) {
    filename[6] = i/10 + '0';
    filename[7] = i%10 + '0';
    if (! SD.exists(filename)) {
      // only open a new file if it doesn't exist
      logfile = SD.open(filename, FILE_WRITE);
      break;  // leave the loop!
so, what to do - please
thanks
DonClemente
PaulS
Quote
That snippet of code seems to do what you want. What is the problem?
donclemente
i come from vb.net and i´m new on c
so i try again
in
i want to replace
"LOGGER00.CSV" by some Kind of variable; lets call it FN
so it Looks something like
char filename[] = FN;
when pressing button 1 the FN changes
FN = Messer00.csv
FN = Logger00.csv
when pressing button 2 the saving begins...
so, how to declare FN ?
Thanks DC
larryd
Create a new function, pass the function the address of the array you want to use as the file name.
No technical PMs.
The last thing you did is where you should start looking.
donclemente
thanks for your help,
but as im new on C could i please have some code...
larryd
#5
May 25, 2017, 11:03 pm Last Edit: May 26, 2017, 01:51 am by larryd
Read this to learn about functions:
https://www.arduino.cc/en/Reference/FunctionDeclaration
Create a function in which you pass a byte parameter, let's call it 'whichFile'.
When 'whichFile' is == 0, use Messer00.csv as the base for your file name.
When 'whichFile' is == 1, use Logger00.csv as the base for your file name.
Edit:
Code: (NOT TESTED) [Select]
//create a new file and open for write
//return true if successful, else false
bool openFile(byte whichFile)
  if (whichFile != 0 && whichFile != 1)
    return false;
  char filename1[] = "Messer00.csv"; //whichFile == 0  default
  char filename2[] = "Logger00.csv"; //whichFile == 1
  char *p = filename1;
  if (whichFile == 1)
    p = filename2;
    p[6] = i / 10 + '0'; //  or     *(p + 6) = i / 10 + '0';
    p[7] = i % 10 + '0'; //  or     *(p + 7) = i % 10 + '0';
    if ( logFile.open( p, O_CREAT | O_EXCL | O_WRITE ) )
  return logFile.isOpen();
} //E N D  o f   o p e n F i l e ( )
No technical PMs.
