Loading...
Pages: 1 2 [3] 4   Go Down
Author Topic: Arduino on Linux  (Read 7016 times)
0
Offline Offline
Newbie
View Profile
Looks like the processing .class files have hard references to the compiler tools.
On linux it should just run avr-g++ which will be in the PATH when installed from a package.
I don't see how to edit the source to point to my own avr tools... since its encased in a binary .class file and the SVN trunk seems to contain no files used to generate that .class file.. ?
Maybe adding a setting in the "Perferences" for the Avr tool path would be best..?
.b.
Logged
0
Offline Offline
Newbie
View Profile
I've tried using the script higher in this thread, and using the instructions from
http://www.arduino.cc/playground/Learning/Linux
but no matter what I do I can't get arduino to find my avr-g++ binary (and I suppose neither the rest of the AVR toolkit)
ok, after searching it looks like these files refer to the tools/blah stuff:
Library.java, Compiler.java, Sizer.java, Uploader.java
Seems to me there should be a function that has the job of choosing where all the avr and uisp tools are.
Ok, HCS is making some changed to these files and I'll post back here results.
anyone out there working on a debian package for arduino?
.b.
Logged
Brooklyn, NY, USA
Offline Offline
Full Member
arduino for all
View Profile
WWW
I just worked out a patch for the avr-gcc, etc. path issues with bbogart:
http://www.arduino.cc/cgi-bin/yabb2/YaBB.pl?num=1156638816/0
Tested on Mac OS X and Linux.
Logged
0
Offline Offline
Newbie
View Profile
I've documented the process of today at: http://www.arduino.cc/playground/Linux/Debian
Logged
Forum Administrator
Cambridge, MA
Offline Offline
Faraday Member
View Profile
WWW
Thanks much for your help with us.  None of the core developers have regular access to a Linux box, so we rely on contributions to improve the process.  If you have any other suggestions or fixes, please let me know.  In particular, I'm curious about the need to chmod the Arduino files from svn.  Who owned them when they were checked out?  Did you check them out with a sudo?
Logged
0
Offline Offline
Newbie
View Profile
I am trying to get the Arduino board installed on my Fedora Core 5 laptop: no luck yet.
My problem appears to be with the Java GUI
I have followed the guid of an earlier post in this thread, taken form here: http://riereta.net/tiki/tiki-index.php?page=PdInstallationArduino
I was getting a strange error...
check_group_uucp(): error testing lock file                     creation Error details: Permission deniedcheck_lock_status: No permission to create lock file.
So I copied the proper rxtx version serial lib into the work directory ( cp /usr/java/jre1.5.0_07/lib/i386/librxtxSerial.so work/ )
Now I don't get that error.
When I run arduino:
1) I get the file selector dialog but no files are displayed.
2) When I enter a filename a directory within the work directory is created: for example if I try to open Pd_firmware.pde a directory is created work/NullPd_firmware.pde/
Is there a way to upload this firmware to the arduino from the command line?
Logged
0
Offline Offline
Newbie
View Profile
So I looked into it and this is the specific error:
Copying dist files...
cp: cannot create regular file `work/lib/.svn/empty-file': Permission denied
cp: cannot create regular file `work/lib/.svn/entries': Permission denied
cp: cannot create regular file `work/lib/.svn/format': Permission denied
cp: cannot create regular file `work/lib/.svn/README.txt': Permission denied
and this is beause the build/linux/dist/lib contains a few read-only files:
-r--r--r-- 1 bbogart bbogart    0 2006-08-27 15:45 empty-file
-r--r--r-- 1 bbogart bbogart 6192 2006-08-27 15:45 entries
-r--r--r-- 1 bbogart bbogart    2 2006-08-27 15:45 format
-r--r--r-- 1 bbogart bbogart  118 2006-08-27 15:45 README.txt
Which seems to be an .svn directory.. does svn creates this itself, or are they checked in? I tried running through again and the errors can be ignored (I did not realize that at the time.) if the compile fails and someone tries to recompile though then they need to override the readonly to delete the work/ directory.
probably best to have all files read-write for the current user.
Thanks for applying the patch to the svn! I'll update the howto accordingly.
How do I debug a java freeze???
Quote
Logged
0
Offline Offline
Newbie
I love YaBB 1G - SP1!
View Profile
yo on the second service i got the arduino compiled. with run.sh i get the file open dialog however steering f.e. to  work/dist/examples/digital\ IO/ no files are displayed/can be chosen & selecting this (or others) directory it segfaults.
what kind of file the selector is looking for to keep him goin?
Experimental:  JNI_OnLoad called.
Stable Library
Native lib Version = RXTX-2.1-7
Java lib Version   = RXTX-2.1-7
./arduino: line 51: 27916 Segmentation fault      java processing.app.Base
Logged
USA
Offline Offline
Newbie
View Profile
WWW
I'm working on installing on Arch Linux, which has no avr packages
Just wanted to say that I found this website
http://www.nongnu.org/avr-libc/user-manual/install_tools.html
it seems to have good instructions for compiling gcc binutils and libc for avr.
I'm in the midst of it now, i'll post back if its successful
Logged
USA
Offline Offline
Newbie
View Profile
WWW
That works!
I have the Arduino devel evironment running under Arch Linux
If anybody needs help with that lemme know.
Logged
0
Offline Offline
Newbie
View Profile
i'm trying to make arduino work from the command line on my fedora core 6 box. since there are no avr-gcc rpms available at the time of writing for fedora, i compiled them myself.
using the instructions from here: http://www.arduino.cc/playground/Learning/CommandLine i'm trying to compile a simple example code, but i'm getting errors:
Code:
avr-objcopy -j .eeprom --set-section-flags=.eeprom="alloc,load" \
        --change-section-lma .eeprom=0 -O ihex foo.elf foo.eep
avr-objcopy: there are no sections to be copied!
avr-objcopy: --change-section-lma .eeprom=0x00000000 never used
make: [foo.eep] Error 1 (ignored)
avr-objdump gives the following output:
Code:
$ avr-objdump -h foo.elf
foo.elf:     file format elf32-avr
Sections:
Idx Name          Size      VMA       LMA       File off  Algn
  0 .text         00001050  00000000  00000000  00000094  2**0
                  CONTENTS, ALLOC, LOAD, READONLY, CODE
  1 .data         00000096  00800060  00001050  000010e4  2**0
                  CONTENTS, ALLOC, LOAD, DATA
  2 .bss          0000009b  008000f6  008000f6  0000117a  2**0
                  ALLOC
  3 .stab         00002280  00000000  00000000  0000117c  2**2
                  CONTENTS, READONLY, DEBUGGING
  4 .stabstr      000016fd  00000000  00000000  000033fc  2**0
the versions of the software i'm using are the following: avr-binutils-2.17, avr-gcc-4.1.1, avr-gcc-g++-4.1.1, avr-libc-1.4.5.
Code:
$ avr-gcc -v
Using built-in specs.
Target: avr
Configured with: ./configure --prefix=/usr --mandir=/usr/share/man --libdir=/usr/lib --target=avr --disable-libssp --enable-languages=c,c++ --disable-libmudflap --disable-libiberty --disable-libstdc
Thread model: single
gcc version 4.1.1
any help would be appreciated.
Logged
0
Offline Offline
Newbie
View Profile
i figured it can be a problem of avr-binutils, although the program can be uploaded regardless of the error.
objcopy.c should be patched at about line 1421:
Code:
   if (bfd_count_sections (obfd) == 0)
      non_fatal (_("there are no sections to be copied!"));
      return FALSE;
FALSE can be changed to TRUE to avoid the error.
reference: http://2313.avrfreaks.net/index.php?name=PNphpBB2&file=printview&t=39014&start=0&POSTNUKESID=9c998e6153cb4e6bba14ec5311d6cc05
Logged
Forum Administrator
Cambridge, MA
Offline Offline
Faraday Member
View Profile
WWW
gabor: the error seems to be appearing in a command to build a file you don't really need.  You can modify the Makefile to not build it at all.  Change line 127 from:
Code:
build: elf hex eep
to:
Code:
build: elf hex
And change line 136 from:
Code:
upload: $(TARGET).hex $(TARGET).eep
to:
Code:
This will be fixed soon.
Logged
0
Offline Offline
Newbie
View Profile
WWW
I just compiled everything needed to run arduino on Linux by myself and it works fine.
I just missed the hint to build an avr-g++ either - but that was a minor problem to be fixed easily.
Just follow blindly step by step the buildprocess of an avr-environment, install some JRE, jikes, RXTX, build the usb-serial kernel module, get the IDE via the subversion repository, set up pathes and environment variables and smile happily at your blue-ish IDE. smiley
Now I have to wait for the actual board as I just placed my order two hours ago.
Just to report some success... (Slackware 11.0)
Logged
0
Offline Offline
Newbie
View Profile
mellis, thanks for your help.
on the other hand, i'm planning to submit the avr rpms to fedora repositories. if they got excepted users will be able to install avr development tools easier in the future in fedora.
Logged
Pages: 1 2 [3] 4   Go Up
Print
Jump to:
