Topic: LED matrix power control (Read 341 times) previous topic - next topic
SynonZelra
Hi all
I'm working on a project that is to make myself a keyboard.
Basically, the idea is a 4x16 key switch matrix with a 4x16 LED matrix.
I just want to have every single LED under control with PWN, so I work with a 328p driving TLC5940 and p-MOS and the sampling testing is pretty good.
So I'm thinking if I can make the matrix RGB and here's the problem.
my current limiting is set at 20ma, for a 4x16 matrix it's at 20x16=320ma which is pretty safe for the USB port.
But, if I make it RGB, it's like 3x20x16=960ma and it's go boom.
Of course, it happens only when all 16 ports at 100% duty and you push 16 buttons at the same time which I can say almost impossible; but I'm wondering if there's a way that I can control the matrix's peak consumption at like 450ma?
I have a 500ma fuse but I don't want it just reset that often.
Thanks
septillion
Option 1, don't turn them all to full brightness in software
Or option 2, and I think a more reasonable option, limit the current to 5mA or so. 20mA through a modern led is A HECK of a light! I would say wayyyy to bright to use in a keyboard anyway.
Use fricking code tags!!!!
I want x => I would like x, I need help => I would like help, Need fast => Go and pay someone to do the job...
NEW Library to make fading leds a piece of cake
https://github.com/septillion-git/FadeLed
Grumpy_Mike
Quote
Not boom but sag.
Yes more LEDs mean more current. It's Physics, you can save current at the expense of brightness by multiplexing them so that only say 8 are on at any one time.
It sounds like you are basically making an RGB monome. Here are two I made earlier.
http://www.thebox.myzen.co.uk/Hardware/Mini_Monome.html
 http://www.thebox.myzen.co.uk/Hardware/Hexome.html
