Topic: MKRFOX1200 read battery voltage (Read 4613 times) previous topic - next topic
astroman35
Hi guys,
I saw on this page that it's possible to read battery voltage on the MKRZERO board with few lines of code :
Code: [Select]
  ReadBatteryVoltage
  Reads the analog input connected to the battery output on a MKRZero or MKR1000, converts it to voltage, and prints the result to the serial monitor.
  Graphical representation is available using serial plotter (Tools > Serial Plotter menu)
  This example code is in the public domain.
// the setup routine runs once when you press reset:
  // initialize serial communication at 9600 bits per second:
// the loop routine runs over and over again forever:
  // read the input on analog pin 0:
  int sensorValue = analogRead(ADC_BATTERY);
  // Convert the analog reading (which goes from 0 - 1023) to a voltage (0 - 4.3V):
  float voltage = sensorValue * (4.3 / 1023.0);
  // print out the value you read:
  Serial.print(voltage);
  Serial.println("V");
I tried to put this code in the MKRFOX1200 but the value returned are weird.
I've modified the formula by replacing 4.3 with 3.3 but same problem.
Do you know if it's possible to read battery voltage on this board ?
ManfredDoetsch
This one works:
  int sensorValue = analogRead(A0);
  // Convert the analog reading (which goes from 0 - 1023) to a voltage (0 - 5V):
  float voltage = sensorValue * (5 / 1023.0);
Did you check the constant ADC_BATTERY ?
astroman35
Thanks for your answer ManfredDoetsch, i will check it in my next code upload.
astroman35
I've uploaded ManfredDoetsch code in my board but it doesn't seem to work as expected.
Here is a historical view of the voltage value since may 25 :
Do you have any idea ?
fabricecarrique
Have you advance on the function to read the battery life, I have a similar project.
flc85
For the mkrfox1200 maximun input 3.3v
Quote
Warning: Unlike most Arduino & Genuino boards, the MKRFOX1200 runs at 3.3V. The maximum voltage that the I/O pins can tolerate is 3.3V. Applying voltages higher than 3.3V to any I/O pin could damage the board. While output to 5V digital devices is possible, bidirectional communication with 5V devices needs proper level shifting.
GeirFrimann
Anyone got a solution to reliably read the battery voltage on a MKRFOX1200?
It is a must-have feature for my project.
janvanbogaert
In order to have an accurate battery measurement you need to compare the battery voltage to a reference voltage.
The MKRFOX1200 has an internal reference voltage of 1V.
The  ADC_Battery pin is connected to a resistor network that divides the battery voltage. So in case the battery voltage is 3.3V, the voltage at battery equals 1V. You need to tell the ADC to compare the ADC_Battery with the internal reference voltage of 1V. I believe this can be done using the analogReference() instruction.
jpe1908
I have a project, where I also have to read the battery level, and I use the analogReference(), and it works fine....but I also have to use another analog pin to measure a distance, but that don't work when I use the analogReference().
What to do ?
jot4p
#9
Aug 22, 2018, 11:47 am Last Edit: Aug 22, 2018, 11:47 am by jot4p
Based on this thread.
Code: [Select]
  analogReadResolution(10);
  analogReference(AR_INTERNAL1V0); //AR_DEFAULT: the default analog reference of 3.3V // AR_INTERNAL1V0: a built-in 1.0V reference
  float voltage = sensorValue * (3.25 / 1023.0);
Result: 3.25 volts for 3.25 volts battery
