Loading...
Pages: [1]   Go Down
Author Topic: Linux PowerPC  (Read 2076 times)
0
Offline Offline
Newbie
View Profile
WWW
Hello world, I use a Debian GNU/Linux 3.1 on my TiBook G4 AND my led are blinking!
First of all tnx at Massimo and all Arduino's people!
If you are a enthusiastic linux powerpc owner and you want open your mind you need read how much follows...
step 1: RXTX are build for X86 architecture (little endian) so it don't works!
  • get librxtx source and recompile it!
    (http://www.rxtx.org/) or (apt-get source librxtx)
  • remove in 'configure'  all '-source 1.3' (I use j2sdk 1.3)
  • remove in 'src/Zystem.java' (I don't know: I'm not a Java Man. I drink orzo coffe! )
    else if (mode == J2SE_LOG_MODE)
                           java.util.logging.Logger.getLogger("gnu.io").fine (s);
                           return (true);
  • remove in 'src/RawImp.c' (it's a sola: it make a sys/io.h file not found!)
    #ifndef __APPLE__  /* dima */
    #include <sys/io.h>
    #endif /* dima */
    (see also http://lists.debian.org/debian-glibc/2003/03/msg00457.html)
  • compile'n'install! (./comfigure && make install) or (debian/rules binary && dpkg -i ../librxtx-java_2.1.7-1_powerpc.deb)
  • rename old RXTXcomm.jar file in 'trunk/build/shared/lib' in
    RXTXcomm.jar-little-endian
  • copy new BIG Endian RXTXcomm.jar (on debian /usr/share/java/RXTXcomm.jar) in to 'trunk/build/shared/lib'
  • rename 'trunk/build/linux/dist/lib' in 'trunk/build/linux/dist/lib-little-endian'
  • create a new 'trunk/build/linux/dist/lib'
  • copy all new BIG Endian librxtx (on Debian 'cp /usr/lib/librxtx* trunk/build/linux/dist/lib')
step 2:  ./make.sh (!!!)  smiley-wink
If you have only jre 1.3 comment in 'trunk/app/syntax/JEditTextArea.java':
   // no more need for reflection, pde requires use of java 1.4
   if (System.getProperty("java.version").startsWith("1.4")) {
   try {
       Class kWheelHandler =
         Class.forName("processing.app.syntax.WheelHandler");
       java.lang.reflect.Constructor konstructor =
         kWheelHandler.getConstructor(new Class[] { getClass() });
       konstructor.newInstance(new Object[] { this });
     } catch (Exception e) {
       System.err.println(e);
   //new WheelHandler(this);
   addMouseWheelListener(new MouseWheelListener() {
       public void mouseWheelMoved(MouseWheelEvent e) {
         if (!scrollBarsInitialized) return;
         int amt = e.getWheelRotation();
         vertical.setValue(vertical.getValue() + amt * 3);
That it's all!
ps: Sorry for my terrifull english!
« Last Edit: March 03, 2006, 01:27:29 am by fab » Logged
0
Offline Offline
Newbie
Arduino rocks
View Profile
It took me a couple of nights of hacking to get RXTX compiled and installed successfully on a PPC PowerBook G4 running Ubuntu 9.04 Jaunty. Ultimately, I was successful building from the rxtx-2.2pre2 source. Here's what I did.
Code:
unzip rxtx-2.2pre2.zip
cd rxtx-2.2pre2
Next, I edited the "configure" to remove "-source 1.3 -target 1.3" both times it appears.
The Zsystem.java file has moved from src/System.java to src/gnu/io/Zsystem.java. After finding its new home, I applied the edit suggested by fab, removing
Code:
                       return (true);
Finally, in src/RawImp.c, the code I removed looks a bit different. I removed these lines:
Code:
#ifndef PPC
#include <sys/io.h>
#endif /* PPC */
#endif /* dima */
Now, when I first attempted to compile, it failed with this error
Code:
./src/I2CImp.c:135: error: 'UTS_RELEASE'  undeclared (first use in this function)
Some further research pointed to a workaround solution, as noted here: (sorry the board will not let me post an active line because I'm a n00b, you'll have to reconstruct yourself) mailman.qbang.org / pipermail / rxtx / 2009-February / 4371059.html
In my case, I used "uname -r" to get my release info, and edited /usr/include/linux/version.h to include the following final line
Code:
#define UTS_RELEASE "2.6.28-6-powerpc"
At this point, I was able to successfully make and install
Code:
make
sudo make install
And Arduino 0017 now runs without complaints.
Logged
Pages: [1]   Go Up
Print
Jump to:
