Topic: ribbon controller (Read 927 times) previous topic - next topic
Archie64
Hi hope someone can help, I intend to build some of the excellent Tom Scarff midi to ribbon controllers, when I looked at the sletch for the arduino it seems to be only covering a range of 15 notes but on the site it states that the scale can be changed to 24 or 36 notes - can anyone tell me which parameter in the sketch I need to change to obtain either a 24 or 36 note scale?
* NAME:                 Ribbon/Softpot Controller forSound Generation via MIDI
* WRITTEN BY:           TOM SCARFF
* DATE:                 20/2/2009
* FILE SAVED AS:        midi_ribbon_controller.pde
* FOR:                  Miduino ATmega168
* CLOCK:                16.00 MHz CRYSTAL
* PROGRAMME FUNCTION:   Trigger a MIDI Sound,
* depending on ribbon/softPot voltage level when pushed,
* and generate Pitch Bend while Note is ON.
// analog Thresholds for softPot sensing
#define softPotThreshold_ON 100
#define softPotThreshold_OFF 10
#define startNote  60
#define Bounce_Period 15
#define Pitch_Bend_Sensitivity 2
#define Program 50
int softPotPin = 0;                 // softPot connected to analog pin 0
int LedPin = 13;                // LED connected to digital pin 13
byte softPotState=0;
byte x;
byte MIDIchannel;
byte velocity=127;
byte note_onoff;
int bend;
int val_noteOn;
int val_now=0x7f;
int val;
void setup()                    // run once, when the sketch previouss
 pinMode(4, INPUT); // Set Inputs for 4 way DIP Switch
 pinMode(5, INPUT);
 pinMode(6, INPUT);
 pinMode(7, INPUT);
 digitalWrite(4, HIGH); // Set inputs Pull-up resistors High
 digitalWrite(5, HIGH);
 digitalWrite(6, HIGH);
 digitalWrite(7, HIGH);
 Serial.begin(31250);
 pinMode(LedPin, OUTPUT);      // sets the digital pin as output
 for (x=1; x<=4; x++){
   digitalWrite( LedPin, HIGH );
   delay(300);
   digitalWrite( LedPin, LOW );
   delay(300);
 midiSend( 0xC0 | MIDIchannel, Program );
void loop()                     // run over and over again
 // Read 4-way DIP switch
 MIDIchannel=digitalRead(4) + (digitalRead(5)<<1) + (digitalRead(6)<<2) + (digitalRead(7)<<3);
 val = analogRead(softPotPin); // read voltage on analog pin 0
 if( val >= softPotThreshold_ON  && softPotState==0) {
   note_onoff=val/64 + startNote;  //  0 to 15 + 60
   noteOn(MIDIchannel,  note_onoff, velocity);
   softPotState=0xff;
   pitch_bend_test();
 if( val <= softPotThreshold_OFF  && softPotState>0 ) {
   noteOff(MIDIchannel,  note_onoff, velocity);
   softPotState=0;
 delay(Bounce_Period);
//++++++++++++++++++++++Functions++++++++++++++++++++++++++++++++++++++++
// Send a MIDI note-on message.
void noteOn(byte channel, byte note, byte velocity) {
 midiMsg( (0x90 | channel), note, velocity);
// Send a MIDI note-off message.
void noteOff(byte channel, byte note, byte velocity) {
 midiMsg( (0x80 | channel), note, velocity);
// Send a MIDI Pitch bend  message.
void pitch_bend(byte channel, byte LSB, byte MSB) {
 midiMsg( (0xE0 | channel), LSB, MSB);      // set LSB = 0
//  Send a two byte midi message
void midiSend(byte status, byte data ) {
 Serial.print(status, BYTE);
 Serial.print(data, BYTE);
// Send a general MIDI message
void midiMsg(byte cmd, byte data1, byte data2) {
 digitalWrite(LedPin,HIGH);  // indicate we're sending MIDI data
 Serial.print(cmd, BYTE);
 Serial.print(data1, BYTE);
 Serial.print(data2, BYTE);
 digitalWrite(LedPin,LOW);
void pitch_bend_test(){
 val_noteOn = analogRead(softPotPin)/Pitch_Bend_Sensitivity; // read voltage on analog pin 0 range 0 to 1023
 while(val >= softPotThreshold_ON){
   val_now = analogRead(softPotPin)/Pitch_Bend_Sensitivity; // read voltage on analog pin 0 range 0 to 1023
   if(val_now > val_noteOn){
     bend = (val_now - val_noteOn) + 64;
     bend = bend & 0x007F;
     pitch_bend(MIDIchannel,0x00, bend);
   if(val_now < val_noteOn){
     bend = 64 - (val_noteOn - val_now);
I will publish photos of the controller as soon as I have made them but need to sort this problem out first as I intend to build several of them for an electronic music performance.
Many thanks
Archie
Grumpy_Mike
Quote
Change the 64 to a lower number to get more notes.
val has a range of 0 to 1023 so the divide by 64 will split the range into 16 notes. If you use a divide by 32 you will get 32 notes. However, the notes will be more closly packed on the sliding scale and could produce some jitter.
