Topic: malloc and free ... yeah again :) (Read 2625 times) previous topic - next topic
noonv
does free() works?
my sketch use malloc() and free()
after several iterations it fail :(
what could be?
ma bey its malloc fragmentation?  :-/
so how to win this?   :-?
any ideas?
AlphaBeta
Might we see the code?
(Remember to use the
  • button in the 'post editor')
noonv
thx :)
i try to use Neuro Net  :)
just apdate it from http://nnfpp.sourceforge.net
my library of NNFpp for Arduino: http://robocraft.ru/files/neuronet/NNFpp.zip
I have problemes with example "and"
// and.pde
// for test NNFpp purposes
// noonv                                                RoboCraft.ru
#include "NNFpp.h"
       float weights[]={
           -3.868201,
2.603633, 2.759537 ,
2.221923,
0.242479, 0.843111 ,
-5.077891,
3.518630, 3.420209 ,
2.098542,
1.713860, 1.024128 ,
-3.447142,
5.275442, -2.022131, 7.489859, -1.423821
float *out, in[2]={0,0};
int Neurons[3] = {2,4,1};
     Serial.println("Start...");
       Serial.println("Logical AND with neural network");
       NNFpp net(3,Neurons,1,NNF_SIGMA_LOGISTIC,0.6);
       net.LoadWeights(weights);
       Serial.println("\nTest: ");
               in[0] = 0;
               in[1] = 0;
               out = net.Execute(in);
               Serial.print("0 0 -> 0: ");
                       Serial.println(out[0]);
               in[0] = 0;
               in[1] = 1;
               Serial.print("0 1 -> 0: ");
               in[0] = 1;
               in[1] = 0;
               Serial.print("0 -> 0: ");
               in[0] = 1;
               in[1] = 1;
               Serial.print("1 1 -> 1: ");
     Serial.println("...end.");
       net.Free();
//      while(1)
Spinlock
#3
Sep 14, 2009, 03:32 pm Last Edit: Sep 15, 2009, 03:11 am by Spinlock Reason: 1
Are you positive it is memory allocation that is failing?
memory allocation uses the stack,
[EDIT:  Nope - I was wrong, thanks to AWOL for pointing out my mistake!]
so as soon as the loop stack exits, I can't see how it would be memory fragmentation.  I suspect it is rather a pointer writing outside its allocated memory.
Try moving the declaration of your net object to make it a global variable.  If the same problem exists( such as with Execute ) that would verify a loose pointer, vs a malloc failure.
Oh yeah, you may want to check the malloc returns in the constructor of the class to see if they are returning null.  That may help, too!
AWOL
#4
Sep 14, 2009, 03:48 pm Last Edit: Sep 14, 2009, 03:54 pm by AWOL Reason: 1
That's news.  :o
Spinlock
You are right AWOL.  alloca uses stack, malloc does not.
Sorry, got my fingers going faster than my eyes today for some reason.
noonv
Spinlock
yes your right :)
if i use code:
#include "NNFpp.h"
       float weights[]={
           -3.868201,
2.221923,
-5.077891,
2.098542,
-3.447142,
               in[0] = 0;
               in[1] = 0;
               in[0] = 0;
               in[1] = 1;
               in[0] = 1;
               in[1] = 0;
               in[0] = 1;
               in[1] = 1;
     //  net.Free();
//      while(1)
its work fine.
here only one malloc() after that only execute()  ;)
But if ill try to eatch time malloc new net?  ::)
Spinlock
#7
Sep 14, 2009, 04:57 pm Last Edit: Sep 15, 2009, 04:47 am by Spinlock Reason: 1
One thing I can think of is that you are calling NNFpp::Free() twice, yet NNFpp::Free() doesn't handle it properly.  (You explicitely called it in loop(), and the compiler probably generated the calling of the class's destructor function calling in the loop stack cleanup.)
You may want to set layers=0 in Free and check it on Free()'s entry to ensure you don't attempt to free the pointers in the arrays of pointers, or add a check to see if weight is non-null before starting to free it's array memory.
The part I think is suspect is this in NNFpp::Free():
for (i=0;i<layers;i++)
           free(bias[i]);bias[i]=NULL;
           free(value[i]);value[i]=NULL;
           free(delta[i]);delta[i]=NULL;
           if (i)
                 [glow]for (j=0;j<neurons[i];j++)[/glow]
                 [glow]{[/glow]
                       [glow]free(weight[i][j]);weight[i][j]=NULL;[/glow]
                 [glow]}[/glow]
           free(weight[i]);weight[i]=NULL;
noonv
2Spinlock
i see...
may be you right  ;)
ill try:
           if(bias[i]){free(bias[i]);bias[i]=NULL;}
           if(value[i]){free(value[i]);value[i]=NULL;}
           if(delta[i]){free(delta[i]);delta[i]=NULL;}
           if (i)
                       if(weight[i][j]){free(weight[i][j]);weight[i][j]=NULL;}
           if(weight[i]){free(weight[i]);weight[i]=NULL;}
Spinlock
I wouldn't go that direction...
You can't trust the array pointers at that point because the array of those pointers was already freed.  If the memory was re-allocated, the pointers contained in weight may be non-null, even though you explicitely set them to null earlier.
That's why I say it may be better to use the variable layers, and set it to 0 on exit of Free().  The next time in, nothing gets called.  (A better way would be to test if(layers==0) and return right at the entry of Free.)
Looks like a cool project though.  I was thinking of pulling out some of my c# neural network classes...
noonv
2Spinlock
I understand - just use the flag of Free  8-)
its not so many RAM to use more usable (and complex  ::) ) Neuro Net :(
