Topic: Arduino Test Scetch (Read 709 times) previous topic - next topic
Jassper
Does anyone have a scetch that will test the ATMega 168?
I can make one but if someone already has a testing method it would save me a ton of time  8-)
AWOL
If you get as far as loading a sketch, you've certainly tested the serial section, probably a couple of timers and some of the program memory and RAM.
What do you want to test?
"Pete, it's a fool looks for logic in the chambers of the human heart." Ulysses Everett McGill.
Do not send technical questions via personal messaging - they will be ignored.
I speak for myself, not Arduino.
Jassper
I was wanting to test the I/O pins as well.
I guess I will need to set up a board with buttons or some such to check all the digi pins and analog pins.
The program runs fine and I get my serial data, so that part is ok.
