Topic: Stray ## (Read 3744 times) previous topic - next topic
elf
I'm getting the following error when compiling the sketch found here: http://www.arduino.cc/cgi-bin/yabb2/YaBB.pl?num=1209736981
error: stray '##' in program In function 'void setup()':
In function 'void loop()':
In function 'void __vector_13()':
In function 'long unsigned int buttoncode(byte)':
In function 'void brand(byte)':
In function 'uint8_t timer2top(unsigned int)':
In function 'void setchannel(byte)':
Bad error line: -8
There don't appear to be any stray ## :) Any ideas how to find the error?
wayoda
the website is gone and so is the code.
Eberhard
elf
It can also be found here: http://www.netstuff.org/olympus/arduino/firmware/
programmer
Looks like the problem is the first line from the error:
Line 1 -##main.pde
Remove it and see if it then compiles
mem
#4
Sep 28, 2009, 11:01 am Last Edit: Sep 28, 2009, 11:02 am by mem Reason: 1
I expect the problem is in the .h file - make sure that every #define in the .h file is at the beginning of a new line. The file on the website may have lost some formatting
elf
I tried that earlier and it failed with a message about macros. I've just retried it and it failed at #include "irparams.h" so I commented this out and used the menu to include it.  The program compiles now.
Thanks for your help.
p.s. I was using Arduino v-0012 when it failed earlier, but installed v-0017 this evening.
