Topic: "L" light flashes, program restarts (Read 3209 times) previous topic - next topic
onebigdoor
I'm running a program interfacing with an LED display.  I have a simple script running in void loop() that just continually spits out numbers.  After only 7 iterations or so, the "L" light blinks, and the board restarts.
I realize I'm being vague, and I can get more specific as necessary, but generally what causes the board to up and restart?
AWOL
#1
Sep 25, 2009, 11:11 pm Last Edit: Sep 25, 2009, 11:12 pm by AWOL Reason: 1
So, quit being vague - show us the "simple script", show us the circuit.
Overheating, hitting the reset button, running out of memory, voltage dips, EMI, ESD ...lots of stuff.
What's an "L" light?
TBAr
#2
Sep 26, 2009, 04:26 am Last Edit: Sep 26, 2009, 04:35 am by TBAr Reason: 1
Pin 13's built-in LED has the legend "L" printed next to it on the PCB.
Does your sketch do anything with pin 13 intentionally? AWOL is right, the entire sketch would be helpful here.
onebigdoor
#3
Sep 28, 2009, 07:57 pm Last Edit: Sep 28, 2009, 07:59 pm by onebigdoor Reason: 1
#include <LedDisplay.h>
// Define pins for the LED display.
#define dataPin 6              // connects to the display's data in
#define registerSelect 7       // the display's register select pin
#define clockPin 8             // the display's clock pin
#define enable 9               // the display's chip enable pin
#define reset 10               // the display's reset pin
#define displayLength 8        // number of characters in the display
// create an instance of the LED display library:
LedDisplay d1 = LedDisplay(dataPin, registerSelect, clockPin,
enable, reset, displayLength);
int brightness = 15;        // screen brightness
 // initialize the display library:
 d1.begin();
 // set the brightness of the display:
 d1.setBrightness(brightness);
//set cursor to 0 position
 d1.home();
//print cursor position in each respective position
 for (int i = 0; i < 8; i++){
  d1.print(d1.getCursor());
//clear display
 d1.clear();
there is no direct manipulation of pin 13.
this program is using the LedDisplay library to talk to an HCMS-2915 8 character led display.
ideally the program would write to the display, one character at a time
01234567
then clear, and begin writing again.
when it gets to 6, the pin 13 LED (or L light as I confusingly called it) blinks, and the program restarts, clearing the display, and starting from 0.
i'm externally powering the display, and I'm running the arduino off of the USB power.
onebigdoor
upon further investigation, i've discovered a few things.
if i say
d1.print((long) d1.getCursor());
i don't have a problem.
getCursor() returns an int.
according to Print.cpp, the included Arduino library, when print receives and int it does the following
void Print::print (int n)
print ((long) n);
any idea why it works when i explicitly tell it to (long).  shouldn't print be able to handle this?
also, if i tell it to
d1.print("01234567")
i get a garbage character instead of the 7
but if explicitly send each character to write
d1.write('0');
d1.write('1);
etc
the 7 comes out fine.
as i understand print();  if you send a string, it basically just parses the string and sends each character to write();
any idea why print(); would fail, but sending each character to write() explicitly would work?
pluggy
Must be young, us old beggers with aging eyes can't see such detail............   :)
http://pluggy.is-a-geek.com/index.html
TBAr
#6
Sep 29, 2009, 03:29 am Last Edit: Sep 29, 2009, 03:52 am by TBAr Reason: 1
Some of the library functions caution about using something other than constants and single variables as parameters to the functions. For example, Print cautions "Be careful about doing math inside the brackets" (http://www.arduino.cc/en/Serial/Print - see "Programming Tips / Known Issues" at the bottom of that page). I presume the same caution applies to using the results of other functions as a parameter, which is what the case is here. Try replacing
with
   int j = d1.getCursor();
   d1.print(j);
The end of that same section (referenced above) also cautions "The Serial.print function puts data into a buffer. It will wait for one character to send, before going on to the next character. However the function returns before sending the last character. " Maybe there is something weird about its interaction with the LedDisplay library that is causing that behavior. Dunno, it's got me stumped too.
TBAr
Well, you can't say they didn't give you a fair chance. They did make it an upper-case "L".   ;D
