« Reply #15 on: November 05, 2009, 04:19:15 pm » |
Yep your dead right . I got to work and as data was being sent to the terminal ,it was too fast for me and you can't stop it . So I unplugged the device and then when I tried to close the terminal window I got a beep and a kernel failure report . So it wrote home and told mum on me.
Move to a new desktop or minimise all windows and start it again and it comes up with the next port number and all works fine until you pull the plug again.
OK so it looks like add your user to Lock uucp Dialup and Wheel? //dont know what that one does yet
Changing the owner did not work as every time the board is plugged in it is set up with root as the owner.
« Last Edit: November 05, 2009, 08:53:52 pm by tytower »
Logged
0
Offline
Jr. Member
Arduino rocks
« Reply #16 on: November 05, 2009, 09:31:31 pm » |
wheel isn't necessary for this, it's for something else. You can add yourself if you want, but it won't do anything
Logged
« Reply #17 on: November 10, 2009, 10:39:20 pm » |
Yes I find by experimentation that uucp is not necessary either.
So just Lock and Dialup should do it
Logged
Indiana, US
Offline
Newbie
*_+
« Reply #18 on: December 05, 2009, 03:06:53 am » |
Since my last post I have moved onto Fedora 12 64bit (and wished I hadn't for about a million new bugs) but I have had success compiling sketches by installing the following: yum install avr-gcc avr-libc avrdude avr-g++ avr-gcc-c++ -y And using Ardunio 0016 from here: http://www.cibomahto.com/2009/07/arduino-on-64-bit-linux/Now my question is: How do I upload it to the Board?? I have added myself to all of the groups mentioned and I changed my preferences.txt to: serial.port=/dev/ttyUSB0 Tools -> Serial Port is also Greyed Out and I am getting the error: /dev/ttyUSB0 not found
« Last Edit: December 05, 2009, 06:06:20 am by action_owl »
Logged
0
Offline
Full Member
Arduino rocks
« Reply #19 on: December 05, 2009, 06:36:32 am » |
I notice you are using 0016 rather than 0017 ,is this because there is no 64bit version . If so I read a post that said 0017 worked with 64 bit. No idea where You changed the preferences .txt . I did not do that , I still have it as it was # ARDUINO PREFERENCES board = atmega328
upload.using = bootloader
serial.port=COM1 serial.databits=8 serial.stopbits=1 serial.parity=N serial.debug_rate=9600
If the port is greyed out have a look as root at /dev/ and watch what happens as you plug and unplug the board , then check what your system has as the port owner and add yourself to that group . Mine was /dev/ttyUSB0 owner root group dialup Thats all I have to suggest at this time
« Last Edit: December 05, 2009, 06:40:21 am by april.steel »
Logged
0
Offline
Newbie
« Reply #20 on: December 07, 2009, 01:35:44 am » |
april said I notice you are using 0016 rather than 0017 ,is this because there is no 64bit version . If so I read a post that said 0017 worked with 64 bit. No idea where You changed the preferences .txt . I did not do that , I still have it as it was # ARDUINO PREFERENCES board = atmega328
serial.port=COM1 serial.databits=8 serial.stopbits=1 serial.parity=N serial.debug_rate=9600 If the port is greyed out have a look as root at /dev/ and watch what happens as you plug and unplug the board , then check what your system has as the port owner and add yourself to that group . Mine was /dev/ttyUSB0 owner root group dialup Thats all I have to suggest at this time You are very knowledgeable for a 1st time poster. Your experience matches tytower's so there is nothing new here.
Logged
« Reply #21 on: December 07, 2009, 03:58:02 am » |
presumptuous foolish and wrong too
Logged
UK
Offline
Faraday Member
Gorm deficient
« Reply #22 on: December 07, 2009, 04:23:52 am » |
Odd that the language used, and the eccentric use of a space before a comma matches, though, dontcha think?
Logged
Per Arduino ad Astra
« Reply #23 on: December 07, 2009, 04:36:27 am » |
As above . Why dont you use your time constructively and try to answer peoples questions or ask meaningful sensible ones . This continuance is pointless , fruitless and simply the acts of stupid , selfish people who hijack threads to make meaningless posts ,mostly to see their name in lights . No more from me on the matter
Logged
UK
Offline
Faraday Member
Gorm deficient
« Reply #24 on: December 07, 2009, 04:55:47 am » |
From "april": I notice you are using 0016 rather than 0017 ,is this because there is no 64bit version . If so From "tytower" continuance is pointless , fruitless and simply the acts of stupid , selfish See what I mean? Spookily similar, huh? (That, and calling people "clown" in a now-deleted post)
Logged
0
Offline
Full Member
Arduino rocks
« Reply #25 on: December 07, 2009, 06:12:02 pm » |
such silly people here. my experience is with Fedora11 and I have just put it on my puta. Whats it toya? See the clown icon person is a new poster . Very experienced for a new poster NO? what foolishness - perhaps not fully grown yet
All info here followed Add to dialout Add to lock yum install avr-gcc-c++ -y
but still not finding the avr.h and other files . Does someone know why?
Right no had to install avr-libc to
« Last Edit: December 07, 2009, 07:40:17 pm by april.steel »
Logged
0
Offline
Newbie
Arduino rocks
« Reply #26 on: December 18, 2009, 04:36:42 pm » |
Just did a complete system upgrade to Fedora 12 x86_64 and Arduino 17. It all works for me.
basic process I used:
download and install Arduino 17 confirm usb (with arduino plugged in to a usb port)
$lsusb
you should see/find in the output list:
Bus 004 Device 003: ID 0403:6001 Future Technology Devices International, Ltd FT232 USB-Serial (UART) IC
The important part is the FTDI driver being present. If you don't see this then you need to check your usb drivers and hardware connections, etc.
Then:
$su passwd: # yum install avr-libc avr-binutils avr-gdb avr-gcc avr-gcc-c++ avrdude -y # usermod -a -G lock [login_id] # usermod -a -G dailout [login_id] ^D
You will then need to logout and login again for the user group changes to take effect.
I also needed to download and use rxtx-2.2pre2-bins.zip
That did it for me. Also, the java I'm using is:
java version "1.6.0_17" Java(TM) SE Runtime Environment (build 1.6.0_17-b04) Java HotSpot(TM) 64-Bit Server VM (build 14.3-b01, mixed mode)
Logged
