Topic: Flash vs EEPROM (Read 2910 times) previous topic - next topic
MarvinMartian
Hi
I need to store one byte of program-state data in non-volatile memory. Are there any pros/cons on using flash vs eeprom?
From a code POV it looks like the EE is most straightforward.
Any issues with writing either in an ISR?
Cheers
retrolefty
I could be mistaken but I thinks it's very hard, if even possible to write to flash program memory within a running sketch, so EEPROM is your friend.
Lefty
Coding Badly
Writing to EEPROM takes about 3.5ms.  I suspect writing to Flash is also a relatively slow process.  Leaving interrupts disabled that long is very likely going to cause problems.
MarvinMartian
Yeah I suddenly realised that just after I posted!
I'm thinking of something on the lines of
setup
 read eeprom - if it's outside permitted range, default to 0
 copy value to ram
ISR
 update ram value
loop
 if ram & eeprom differ, write ram back to eeprom
 do stuff with ram value...
Coding Badly
Should work well so long as the usual caveats regarding data shared between loop and an interrupt service routine are considered.
borref
The way I read the datasheet is that the write itself is "immediate", but you will have to wait for the eeprom update to finish prior to writing the next byte.
The avrlibc implements this as an initial status/wait followed by write. For the first byte - wait will return immediately, but will block for successive bytes.
So a single byte EEPROM write may actually be Ok also from within an ISR.
