Loading...
Pages: [1]   Go Down
Author Topic: How to send a <return> with Serial Monitor  (Read 1384 times)
0
Offline Offline
Full Member
View Profile
How can I use the Serial Monitor to send a <return> (CHR$(13))?
Logged
Forum Administrator
Cambridge, MA
Offline Offline
Faraday Member
View Profile
WWW
Right now, you can't, although this is something I'd like to add.
Logged
Seattle, WA USA
Offline Offline
Brattain Member
Seattle, WA USA
View Profile
You could use some other terminating character, and have the Arduino recognize that character or the CR as the carriage return.
You could also write your own version of the Serial Monitor window. I did that in C# in less than an hour. Mine can send, or not, the CR/LF combo.
Logged
London
Offline Offline
Faraday Member
Have fun!
View Profile
Quote
that would be a very welcome addition.
I have noticed that some people assume that a cr/lf will be sent at the end of every message sent from serial monitor. Having an option to enable this behaviour would help for them.
Logged
0
Offline Offline
Full Member
View Profile
Quote
Thanks.  It's nice to know I wasn't missing something.
Logged
0
Offline Offline
Full Member
View Profile
Quote
I saw that mentioned when I was searching for a way to send a CR.  I didn't see how to do it however.
Quote
You make it sound so easy  smiley
Logged
0
Offline Offline
Full Member
View Profile
Quote
I was trying to interface the Arduino with another software package, which does send a CR (but not a LF) at the end of every message.  But it's easier to debug my Arduino code if I can use println messages at certain spots, so I was hoping to use the Serial Monitor to send/receive.  The ability to send a CR would be helpful indeed.  But I've learned to manage without  8-)
Logged
Seattle, WA USA
Offline Offline
Brattain Member
Seattle, WA USA
View Profile
Quote
Suppose that you decide that the terminating character is CR or @. Since you can't send the CR, you have to send the @. That shouldn't be too hard to figure out how to do.
If the data being sent controls an LED on a pin, you might send 'O', 'n', ',', '1', '3', '<CR>' from the program. In the serial monitor, you'd type "On,13@" instead.
Then, in the Arduino code, break out of the loop for reading serial data when the character read was a CR or an @.
Logged
0
Offline Offline
Full Member
View Profile
That makes sense.  Thanks.
Logged
Pages: [1]   Go Up
Print
Jump to:
