Topic: setCursor example in Arduino "learning" (Read 2203 times) previous topic - next topic
bigtrumpet
For the learning example in arduino website LiquidCrystal library > setCursor
As I understand the syntax of lcd.setCursor is lcd.setCursor(col, row)
I think the descriptions above the code :
lcd.setCursor(0, 0); // top left
lcd.setCursor(0, 15); // top right
lcd.setCursor(1, 0); // bottom left
should be
lcd.setCursor(15, 0); // top right
lcd.setCursor(0, 1); // bottom left
lcd.setCursor(15, 1); // top right
So the example code works fine( at least on my lcd module), but be aware that in lines 55 to 62 :
variable thisRow is actually referring to the column
variable thisCol is actually referring to the row
I tried this on arduino 0017
Cheers
floresta
big trumpet:
This is not the only place where the rows and columns have been interchanged.  It appears that some of the Playground pages were edited incorrectly several months ago.  A few days ago I sent a private message about this to the person who I believe made those changes but I have not received an answer back.
I started a thread about this last Friday (http://www.arduino.cc/cgi-bin/yabb2/YaBB.pl?num=1259290563) but as of today I am 0 for 68 on responses.
I don't have much C programming experience and I am afraid that if I try to fix things myself I might just make them worse.  None the less I plan to start soon if I don't hear back.
Don
bigtrumpet
Hello Floresta,
I think the guy who's writing the LiquidCrystal library has done a good job, but learning examples just need to catch up a bit. :P :P
I tried the "HelloWorld" again, but it seems working fine. It is set  :
lcd.begin ( 16, 2 )  for a 16 characters x 2 rows / lines display
In the funny world of lcd displays, the (0,0) is top left, which is quite different from conventional x,y co-ordinates in the math books. I think this is confusing sometimes.
Cheers
floresta
big trumpet
He's a "she".
The library is fine.  The Playground description is OK but could use some work.  The 'Hello World' example in the Playground is FUBAR.
Don
tytower
should be
dont you mean "lcd.setCursor(15, 1); // bottom right"  ?
thoed
Really? You make a post just to point out a typo?
There are alot of little things like this to get used to with microcontrollers :D  ... such as counting starting at 0, I made many a mistake when first starting out.. always start counting at 1 and mess things up. :P
And I got an LCD that has 131x131 pixels... and it's the same way! Makes for a hassle when you're trying to remember exactly where that pixel would be on the screen. :P
mellis
CaptainObvious: making a post to point out a typo is a good thing!  We want to fix problems like this.  Don't judge the posters here, please.
retrolefty
#7
Dec 23, 2009, 06:18 pm Last Edit: Dec 23, 2009, 06:19 pm by retrolefty Reason: 1
Agree, however typos in code are educational, typos in comments not as much.
Lefty
