Loading...
Pages: 1 2 [3]   Go Down
Author Topic: Clock with Arduino  (Read 2758 times)
London
Offline Offline
Faraday Member
Have fun!
View Profile
are you using 0018?
version 0017 disabled interrupts in delayMicroseconds and the LCD library does use this function.
Sounds like that may be the cause of you problem. Try it with 0018 if you are not yet using that.
« Last Edit: February 09, 2010, 10:30:39 am by mem » Logged
Seattle, WA USA
Offline Offline
Brattain Member
Seattle, WA USA
View Profile
I think I've read that the LCD library disables and re-enables interrupts. Maybe that's why millis is not keeping an accurate count.
Logged
UK
Offline Offline
Faraday Member
Gorm deficient
View Profile
Quote
Can't think of any good reason why it should.  :o
Some delays, certainly, but the rest is just "digitalWrite"s
« Last Edit: February 09, 2010, 10:39:05 am by GrooveFlotilla » Logged
Per Arduino ad Astra
London
Offline Offline
Faraday Member
Have fun!
View Profile
It was a side affect of the way delayMicroseconds works that has been fixed in arduino release 0018
Logged
Madison, WI
Offline Offline
Newbie
Exploring Electrons. . .
View Profile
WWW
mem - you sir win a cookie.  I upgraded to v18 and it is now running perfectly.  I'll have to try my original code with the rest of the software but the timer works fine now  smiley-grin
Logged
London
Offline Offline
Faraday Member
Have fun!
View Profile
Good to hear you have it working.
btw, the code posted in reply #14 has the advantage that is uses fewer variables and uses less processing time (it does two additions each second rather than two divisions each time through the loop).
Logged
Pages: 1 2 [3]   Go Up
Print
Jump to:
