Topic: how to use WifiWebClient Sketch with Google IP address? (Read 2568 times) previous topic - next topic
maker99
The sketch WIFI101 / WifiWebClient runs great (with Winc1500 breakout board).
It contains a google URL example but also says you can use google's IP address:
int status = WL_IDLE_STATUS;
// if you don't want to use DNS (and reduce your sketch size)
// use the numeric IP instead of the name for the server:
//IPAddress server(74,125,232,128);  // numeric IP for Google (no DNS)
char server[] = "www.google.com";    // name address for Google (using DNS)
So I tried
char server[] = "(74,125,232,128)";
but it didn't work. Having searched the internet found this example from the Ethernet library in which the syntax seems the same but curly brackets are used:
https://www.arduino.cc/en/Reference/ClientConnect
So tried:
char server[] = "{74,125,232,128}";
but that didn't work either.
Also tried a number of other things (eg leaving off the brackets...) but no luck.
Anyone know how to make this sketch work with google's IP address instead of domain name?
pert
Arduino has a special type called IPAddress that makes it easy to work with IP addresses. That is one of the allowed argument types of the WiFi101 library's connect function.
Change the line:
Code: [Select]
to:
Code: [Select]
Change the line:
Code: [Select]
to:
Code: [Select]
//char server[] = "www.google.com";    // name address for Google (using DNS)
maker99
maker99
Incidentally, further down the script the domain "google.com" comes up once again:
  if (client.connect(server, 80)) {
    Serial.println("connected to server");
    // Make a HTTP request:
    client.println("GET /search?q=arduino HTTP/1.1");
    client.println("Host: www.google.com");
    client.println("Connection: close");
    client.println();
What is the role of the following line? Is it optional?
