Topic: polyphonic piano with arduino?? (Read 10812 times) previous topic - next topic
GrooveFlotilla
Code: [Select]
          if(A == [glow]0[/glow])  //which key held down
           tones[[glow]0[/glow]] = 262;  //store the tone in array
               buttonState[[glow]0[/glow]] = LOW; //store the state in array
        if(A ==[glow] 1[/glow])
           tones[[glow]1[/glow]] = 294;
               buttonState[[glow]1[/glow]] = LOW;
        if(A == [glow]2[/glow])
           tones[[glow]2[/glow]] = 330;
               buttonState[[glow]2[/glow]] = LOW;
Do you see a pattern emerging?
Some people are like Slinkies.
Not really good for anything, but they bring a smile to your face when pushed down the stairs.
falohao
#31
Mar 04, 2010, 03:40 pm Last Edit: Mar 04, 2010, 04:48 pm by falohao Reason: 1
Absolutely I see it. So that I may use shorter command?(Such as the last past?
If not using this, how can I map keys to tones? :-[
plz give me hints.>< this project is my first project using arduino. :-?
falohao
I wanted to ask:
If I attached an interruption, I can't use delay function?
Code: [Select]
void setup(){
attachInterrupt(0, A, CHANGE);}
if(tones[t] == 262){
       digitalWrite(speakerpin[0], HIGH);
     [glow]delayMicroseconds(tones[t]);[/glow]
     digitalWrite(speakerpin[0], LOW);
     [glow]delayMicroseconds(tones[t]);}[/glow]
PaulS
I asked this before, but you didn't answer. Why are you not using the tone library functions for making the sounds? Tone::play() and Tone::Stop() are so much easier to use.
falohao
I write some code which included tone.h, but I don't know how to read keys and play note= = I think the syntax is dedicated, am I right. I've found this link:
http://www.arduino.cc/cgi-bin/yabb2/YaBB.pl?num=1251750920/25
Can you give me some guide lines?
here is my code, it's so primary>< :'(
Code: [Select]
#include <Tone.h>
#define NOTE_C4;
#define NOTE_D4;
Tone notePlayer[2];
int key[] = {2, 3};
int sp1 = 11;
int sp2 = 12;
int A = HIGH;
int B = HIGH;
void setup(void)
 notePlayer[0].begin(11);
 notePlayer[1].begin(12);
 pinMode(key[0], INPUT);
 pinMode(key[1], INPUT);
void loop(void)
 for(int x=0;x<2;x++)
{if(HIGH == digitalRead{key[x]}){
  if(x = 0){
  notePlayer[0].play('NOTE_C4');
  Serial.print("pin 11:");
  Serial.println('NOTE_C4');
  notePlayer[0].stop();
  break;}
  if(x = 1){
  notePlayer[0].play('NOTE_D4');
  Serial.println('NOTE_D4');
  break;}
PaulS
Code: [Select]
if(x = 0){
You want == in there, not =.
falohao
Sorry, I wrote a new one, but it didnt be compiled. here's my code.
Code: [Select]
#include <Tone.h>
int speakerA = 12;
int speakerB = 13;
int keyA = 2;
int keyB = 3;
Tone tone1;
Tone tone2;
int buttonStateA = 0
int buttonStateB = 0
 tone1.begin(12);
 tone2.begin(13);
 pinMode(keyA, INPUT);
 pinMode(keyB, INPUT);
 buttonStateA = digitalRead(keyA);
 if (buttonStateA == HIGH)
   tone1.play(NOTE_A4);
   tone1.stop();
 buttonStateA = digitalRead(keyB);
 if (buttonStateB == HIGH)
   tone2.play(NOTE_B4);
   tone2.stop();
Error: expected unqualified-id before numeric const. :P
PaulS
#37
Mar 06, 2010, 05:23 pm Last Edit: Mar 06, 2010, 05:23 pm by PaulS Reason: 1
Code: [Select]
I detect a missing ; here, and on the next line, too. I think the compiler did to.
Code: [Select]
 buttonState[glow]A[/glow] = digitalRead(keyB);
 if (buttonState[glow]B[/glow] == HIGH)
Where did buttonStateB get a value?
falohao
#38
Mar 06, 2010, 05:35 pm Last Edit: Mar 06, 2010, 05:37 pm by falohao Reason: 1
Corrected it. resulting in the same= =
expected unqualified-id before numeric constant= =
according to this link #9reply
http://www.arduino.cc/cgi-bin/yabb2/YaBB.pl?num=1257390337
on the other hand, what commands can I use if code without delay function?
PaulS
Quote
What = = are you talking about? Where's the current code?
Quote
Wouldn't you be better off getting something working, first?
falohao
ok. i changed int buttonstateA=low and also buttonstateB.
then it can be compile.
but it keeps playing tone1 then tone2 then tone1......
with no key pressed, whatever i press switch1 and switch2, no any respond but tones keep playing. :-/
PaulS
Can you lean to one side so I can see over your shoulder? Umm, still can't see...
falohao
Polyphonic piano has been done few days ago....the sounds come in square waves, I want to make it to be sine waves or saw and sth. else.
But how can I accomplish waveform shaping??
Pots? PWM? any suggestion? :'(
