Topic: i2c Pressure Sensor (Read 23997 times) previous topic - next topic
mem
Because the pressure is varying with atmospheric conditions, you need to set an offset in the pressure value to correct it to a known altitude (or exact pressure). I may add that function to the library,  but for now you will need to do it in your sketch.
I think my sensor was accurate to around 5 or 10 meters, but its been a while since I designed and tested the library so have forgotten that exact figure.
If you do some tests please do report on your results. I hope you enjoy using the library as much as I enjoyed writing that code.
msonnabaum
First, thanks so much for all the great information!
I'm using the HP01D and I had the exact same experience as maca_404 getting the code to compile.
I'm a bit new to the arduino though, and I'm not what it means to bring xclear high:
Quote
duh forgot to bring xclear high,  Working perfectly now got lost of lovely data coming threw and looks like rain is on the way
Here is what I'm getting now, which I'm guessing is similar to what maca_404 got at first:
Code: [Select]
Error getting HP01D calibration, check sensor connection
pressure 1100
  Altitude, Meters = -698.2
  Altitude, Feet  = -2291.0
pressure 1050
  Altitude, Meters = -301.5
  Altitude, Feet  = -989.0
pressure 1000
  Altitude, Meters = 110.8
  Altitude, Feet  = 363.0
pressure 950
  Altitude, Meters = 540.2
  Altitude, Feet  = 1772.0
pressure 900
  Altitude, Meters = 988.5
  Altitude, Feet  = 3243.0
pressure 850
  Altitude, Meters = 1457.1
  Altitude, Feet  = 4780.0
pressure 800
  Altitude, Meters = 1948.9
  Altitude, Feet  = 6394.0
pressure 750
  Altitude, Meters = 2466.1
  Altitude, Feet  = 8091.0
pressure 700
  Altitude, Meters = 3012.1
  Altitude, Feet  = 9882.0
pressure 650
  Altitude, Meters = 3590.6
  Altitude, Feet  = 11780.0
pressure 600
  Altitude, Meters = 4206.0
  Altitude, Feet  = 13799.0
pressure 550
  Altitude, Meters = 4865.2
  Altitude, Feet  = 15961.0
pressure 500
  Altitude, Meters = 5574.3
  Altitude, Feet  = 18288.0
pressure 450
  Altitude, Meters = 6343.6
  Altitude, Feet  = 20812.0
pressure 400
  Altitude, Meters = 7185.3
  Altitude, Feet  = 23574.0
pressure 350
  Altitude, Meters = 8117.2
  Altitude, Feet  = 26631.0
Error getting HP01D data, check sensor connection
If anyone can explain this to me, I'd greatly appreciate it!
nikivan
mem, thank you for posting this library. I was able to compile the sketch under IDE 15 after fuddling with frequencytimer2 library. I have two questions though. I am using Arduino Pro Mini, which is 16MHz instead of 8MHz, and I was wondering if something needs to be changed to account for this. For example, will line 141 in HP03.cpp be still accurate?
 FrequencyTimer2::setPeriod(31); // 31us = 32258hz
Also, I actually have HP02D sensor, which is very similar, but it works with 5V. When comparing the spreadsheets I can see some differences in how the pressure is calculated. Do you happen to have a library for the HP02 sensor as well?
Thanks,
Nick
mem
Hi Nick,  you should not need to change anything to use the code on 16MHz or 8MHz boards, although I have only tested on 16MHz boards. FrequencyTimer2 adjusts to a board specific clock value when it is compiled should produce the correct frequencies for your board.
I have not looked at the HP02D sensor but the HP03 code could be modified to use the calculations needed for that sensor. Unfortunately, its not an easy task and I don't have the time to do this, sorry. The HP03 costs less than $10 from Futurlec so the easiest thing may be to use that module instead of the HP02.
nikivan
mem, thanks for the reply. I was trying to avoid using HP03, because it is 3V device. I am prototyping an altitude monitoring system for RC helicopter. I only have 5V rail available there and I am trying to keep the number of components to a minimum (I will need additional 3V regulator and logic level converter if HP03 is used).
Anyway, your library is very well commented, so I will try to make HP02 version. The differences I see so far are in the wait time between readings: 32ms vs 40ms, and in HP02 there are only 5 calibration constants to be read. I will post here if I run into trouble.
Do you know any other low-cost pressure sensor which is easy to integrate with Arduino?
Thanks,
Nick
mem
Modifying the library to support the hp02 is certainly possible if you are comfortable coding the math needed for the calculations.
But integrating the hp03 is not difficult if your controller board has a 3.3 volt supply (or you can use a couple of diodes to drop the 5 volts line). You can do the logic level conversion with a couple of FETs and a six resistors.
Which is easier depends on whether you are more comfortable working in software or hardware.
Have fun!
nikivan
#21
Jun 10, 2009, 07:19 pm Last Edit: Jun 10, 2009, 07:20 pm by nikivan Reason: 1
Well, I went ahead yesterday and updated the library. so far no cigar.  Arduino shoots back to the serial port some garbled symbols. Even the normal text sent from the sketch is not recognizable. I wen back to the original library and I see the same thing. Some how the serial communication is not working properly even with the sensor disconnected. I wonder it this has something to do with the fact I am using IDE 15 and Atmega 328. Your thoughts?
mem
The example sketch posted earlier in this thread uses 19200 baud, have you set that rate in the serial monitor?
nikivan
Hm, no, I did not. But I can execute other sketches using this bit rate without any problem.
mem
Quote
I am not sure what you are saying. My question was about ensuring the baud rate on the serial monitor viewing the serial data matches the 19200 baud being sent. If the anwswer is no then that is why you are seeing gibberish characters.
nikivan
#25
Jun 11, 2009, 12:36 am Last Edit: Jun 11, 2009, 02:07 am by nikivan Reason: 1
OK, I'll check again when I get home. In the mean time I was looking at the sensor spreadsheet and I could not figure out where the following values are coming from:
#define HP03_I2C_SENSOR_ADDRESS 0x77
#define HP03_I2C_CALIBRATION_ADDRESS 0x50
Why 0x77 and 0x50?
Also, I assume the following code refers to PB4(MISO) and PB5(SCK) atmega pins:
#define MCLK_pin 16   // Arduino uses analog pins 4 and 5 for I2C
#define XCLR_pin 17
PB5 (17) on Atmega 328 in Arduino Pro Mini is connected to the green LED via 330 om resistor. I am not getting a good square signal there, so I am using PB3 (pin 15) instead.
In this regards, it would be nice if you could provide the pin connections, as you have them in your setup (Atmega -> HP03)?
Thanks again for your help.
Nick
mem
#26
Jun 11, 2009, 06:30 am Last Edit: Jun 11, 2009, 06:31 am by mem Reason: 1
The Arduino I2C wire library requires that you divide the datasheet address by 2. The HP03 sensor address is 0xEE, which is 0x77 after dividing by 2. See the wire library reference page here: http://www.arduino.cc/en/Reference/Wire
I have not used a Pro Mini, but according to the reference page:  "The Pro Mini has 6 analog inputs, each of which provide 10 bits of resolution (i.e. 1024 different values). Four of them are on the headers on the edge of the board; two (inputs 4 and 5) on holes in the interior of the board. "
MCLK_pin is analog pin 4
XCLR_pin  is analog pin 5
So the sensor connects to analog pins 4 and 5. Although you don't need the following information, you may be interested in knowing that analog pin 4 is also digital pin 16,  this is physical port PC4 on the controllers chips physical pin numbered 27.
nikivan
Wow, this is getting confusing. The analog input 4 and 5 are also marked as SDA and SCL. I thought I need to connect there SDA and SCLK pins from the sensor. If you are saying I need to connect MCLK to analog 4 and XCLR to analog 5, then where the SDA and SCLK go to?
BTW, the serial communication is working now. I found I need to press the reset button, after I start the monitor. Sure enough, the message is 'Error getting HP03 data'. Not surprising, considering the mess with the pins assigment.
mem
The comment in that code is confusing ( I even forgot what I meant by it)
I2C uses analog pins 4 and 5:
SDA (data line) is on analog input pin 4
SCL (clock line) is on analog input pin 5.
MCLK is on analog pin 2 (the code uses it as digital pin  16)
XCLR is  on analog pin 3 (used as digital pin 17)
I hope that helps with the connections.
BTW, I think the wire library may have been modified slightly since I last ran this code so you if you still get errors, you  may need to fiddle with the wire error return codes.
nikivan
Thanks, mem.
In the sketch, there is a comment:
// note that the HP03 code uses digital pin 11 for the clock and analog pins 4 and 5 for I2C
I understand that means MCLK should be connected to digital pin 11 (PB3,  MOSI), but your last comment puts it to analog pin 2 (PC2, ADC2). Which one is the correct assigment?
