Topic: Upload Issues (Read 904 times) previous topic - next topic
itc55
I've been trying to get my first program uploaded to a Duemilanove w/ ATmega328.  I keep getting the following error though.
My best guess is the listed serial port is wrong. /dev/ttyS0 is the only one listed in tools-serial port. Most posts I've read list /dev/ttyUSB0 as the correct port but there isn't anything in /dev/ like that.  The only thing with usb is usbmon0-5.  The board is blinking in it's default program so I know it's getting power. Any ideas?
I'm running xubuntu 9.10 with the 2.6.31 kernel.  I downloaded the sowtware through the ppa.
wayoda
when a arduino is plugged in the device /dev/ttyUSB0 will be created by the operating system, and it will be removed when the arduino is unplugged.
Test:
Unplug your arduino
Open a console window and list the current devices with
ls -all /dev/ttyUSB*
plug your arduino into your machine and list the devices again
You should now see the device created for the Ardunio.
If not, please check the system log with
dmesg
It should contain some kind of error report.
Eberhard
MarkT
Do you have the FDTI drivers?
wayoda
The FTDI driver is part of the Linux kernel. There is no need to install manually.
Eberhard
itc55
I noticed no change in /dev/.  My dmesg output is below.
[48876.377581] usb 1-4: USB disconnect, address 11
[49049.352105] usb 3-2: new full speed USB device using uhci_hcd and address 4
[49049.472071] usb 3-2: device descriptor read/64, error -71
[49049.696135] usb 3-2: device descriptor read/64, error -71
[49049.912139] usb 3-2: new full speed USB device using uhci_hcd and address 5
[49050.032102] usb 3-2: device descriptor read/64, error -71
[49050.256108] usb 3-2: device descriptor read/64, error -71
[49050.472101] usb 3-2: new full speed USB device using uhci_hcd and address 6
[49050.884115] usb 3-2: device not accepting address 6, error -71
[49051.000112] usb 3-2: new full speed USB device using uhci_hcd and address 7
[49051.408129] usb 3-2: device not accepting address 7, error -71
[49051.408165] hub 3-0:1.0: unable to enumerate USB device on port 2
I think this is the relevant part.  If not I really don't know because everything else seemed to be related to file systems.
wayoda
bad news.
On the Linux-USB subsytem error 71 is a  "Protocol error".
If the error does not go away when you use a different cable or use a different USB-Port/Hub it looks like your board (the USB2Serial adapater at least) is damaged.
Eberhard
pluggy
I'd try a new USB cable first.
http://pluggy.is-a-geek.com/index.html
