Loading...
Pages: [1]   Go Down
Author Topic: Baud rate greater than 115200?  (Read 447 times)
0
Offline Offline
Newbie
Arduino rocks
View Profile
I am trying to run my code at 115200 baud rate but it gives me garbled data.I was running a shorter version of the same code at the same baud rate and it worked perfectly at 115200 but as I added more print commands and a few more lines to the code it just started spitting out random symbols.
I probably think I will have to increase the baud rate to get coherent data on the terminal but  the maximum baud that arduino runs on is 115200.
I'll be extremely grateful for any suggestions regarding this problem.
Thanks
SK
Logged
Global Moderator
Dallas
Offline Offline
Shannon Member
View Profile
WWW
Quote
How far apart are the two devices?
Do they share a ground?
Are there any high EMF devices (motors, fluorescent lights, etcetera) in between?
Is any part of the cable in a tight loop?
Have you tried a different cable?
Logged
0
Offline Offline
Newbie
Arduino rocks
View Profile
So I am transmitting data between my bluetooth device and my laptop.The bluetooth is using a serial port profile.
There are no motors or other EMF devices in between.And since I am doing testing my bluetooth board is pretty much right next to my PC.
Logged
UK
Offline Offline
Faraday Member
Gorm deficient
View Profile
Quote
At 115200, your 128 byte receiver buffer will overflow in a little over 11 milliseconds.
Are you processing the input fast enough?
Logged
Per Arduino ad Astra
0
Offline Offline
Jr. Member
http://twitter.com/azrobbo
View Profile
WWW
Are you running on the real UART ports or a NewSoftSerial port?
I noticed that the NewSoftSerial cpp file states that RX is not supported at 115200 baud.
Logged
0
Offline Offline
Newbie
Arduino rocks
View Profile
I am displaying the data on the arduino terminal and as far as I can tell I don't see any latency between the data sent and received.
Logged
0
Offline Offline
Newbie
Arduino rocks
View Profile
Im not using the softserial port.
Logged
Pages: [1]   Go Up
Print
Jump to:
