I changed the unsigned char for a char and it now work for negative number. The only downside is that we loose a bit for the value itself. Here are the final codes if anyone needs it :
SIGNED 6 bit Receiver
#include <Wire.h>
// MAX INT -16382 to 16382
Wire.begin(); // join i2c bus (address optional for master)
Serial.begin(9600); // start serial for output
int output = 0;
Wire.requestFrom(2, 1); // the first byte
while(Wire.available())
char received = Wire.receive();
output = received;
for (int i = 0 ; i < 3 ; i++) // next 3 bytes
output |= (received << 8);
Serial.print(output);
Serial.println(".");
SIGNED 6 bit Sender :
#include <Wire.h>
Wire.begin(2); // join i2c bus with address #2
Wire.onRequest(requestInt); // register event
int byteSending = 1;
int toTransfer = 32766;
int Shift = toTransfer;
int mask = 0xFF;
char toSend = 0;
delay(100);
// function that executes whenever data is requested by master
// this function is registered as an event, see setup()
void requestInt()
if (byteSending == 1) //send packet 1
toSend = Shift & mask;
Shift = Shift >> 8;
Wire.send(toSend);
byteSending = 2;
else if (byteSending == 2) //send packet 2
Shift = Shift >> 8;
Wire.send(toSend);
byteSending = 3;
else if (byteSending == 3) //send packet 3
Shift = Shift >> 8;
Wire.send(toSend);
byteSending = 4;
else if (byteSending == 4) //send packet 4
Shift = Shift >> 8;
Wire.send(toSend);
byteSending = 1;
//initialization for next turn
Shift = toTransfer;
mask = 0xFF;
toSend = 0;
UNSIGNED 7 bit Sender :
#include <Wire.h>
// MAX INT 32767
int toTransfer = 32767;
int mask = 0xFF;
unsigned char toSend = 0;
delay(100);
void requestInt()
Shift = Shift >> 8;
Wire.send(toSend);
byteSending = 2;
Shift = Shift >> 8;
Wire.send(toSend);
byteSending = 3;
Shift = Shift >> 8;
Wire.send(toSend);
byteSending = 4;
Shift = Shift >> 8;
Wire.send(toSend);
byteSending = 1;
Shift = toTransfer;
mask = 0xFF;
toSend = 0;
UNSIGNED 7 bit Receiver :
#include <Wire.h>
// MAX INT 32767
int output = 0;
unsigned char received = Wire.receive();
output = received;
