Topic: Serial.println (Read 3106 times) previous topic - next topic
bspirit
Hi all!
Someone could tell me where i can find the source code of the function Serial.println used in IDE of arduino.
Thanks in advance!
Regards
Coding Badly
{Arduino Path}\hardware\cores\arduino\Print.h
{Arduino Path}\hardware\cores\arduino\Print.cpp
Zandaa
as said before, in the Arduino path, you look for hardware\cores\arduino
it has all the sourcecode for the individual arduino functions like digitalWrite, pinMode, etc. so if you fancy taking a look, that's where you'll need to be.
bspirit
Thanks, i will take a look!
regards
bspirit
I see functions like this one,
void Print::println(const char c[]){
in this  file {Arduino Path}\hardware\cores\arduino\Print.cpp
what this mean void Print::println? it is not usual to see this, i think.
regards
AWOL
#5
Apr 02, 2010, 06:52 pm Last Edit: Apr 02, 2010, 06:57 pm by AWOL Reason: 1
It means "println" is a member of the class "Print", and is  a "void" (i.e. it doesn't return a value) function.
That's C++, and perfectly usual.
You'll see that that there are different versions of the functions, distinguished only by their parameter types. This is called "overloading"
bspirit
Ok, thanks, i never seen C++ source code, only C, that is why i couldn't understand.
Regards
