Loading...
Pages: [1]   Go Down
Author Topic: Prescaler on Watchdog timer interrupt??  (Read 1543 times)
0
Offline Offline
Newbie
Arduino rocks
View Profile
I'm wondering if someone knows how to change the prescaler on the watchdog timer enabled as an interrupt?
So far I have been successful enabling the WDT as an interrupt but I can't get the Prescaler to work.
I'm trying to make the WDT interrupt every 1 second so I can make a 24 hr clock with it. In the reference manual it says you can prescale it down to 1 second by setting 1<<WDP2 and 1<<WDP1, but it seems as tho it has no prescaler at all.
Here is a portion of my code so far:
  cli();          // stop interrupts
  WDTCSR  = (1<<WDCE);     // watchdog change enable
  WDTCSR  = (0<<WDP3)|(1<<WDP2) | (1<<WDP1); // set
                   //prescaler to 1 second
  WDTCSR  = (1<<WDIE) | (0<<WDE);   // enable wdt interrupt
  sei();        // start interrupts
/*WDT interrupt*/
ISR(WDT_vect)
ANY HELP WOULD BE GREATLY APPRECIATED!!
Logged
Indiana
Offline Offline
Full Member
Arduino rocks
View Profile
I think you're confusing the hardware timers (TIMER0 & TIMER1) with the watchdog timer.
The watchdog is mainly designed to reset the chip if it freezes. The hardware timers are meant for programmatic events (like being triggered every second).
Logged
0
Offline Offline
Newbie
Arduino rocks
View Profile
it's very possible my friend. I'm attaching the documentation of what I read from the ATmega datasheet.. this is the reason i thought that I could use it as an interrupt.
Thx!
10.9.2 WDTCSR – Watchdog Timer Control Register
WDIF WDIE WDP3 WDCE WDE WDP2 WDP1 WDP0 = WDTCSR
• Bit 6 - WDIE: Watchdog Interrupt Enable
When this bit is written to one and the I-bit in the Status Register is set, the Watchdog Interrupt is
enabled. If WDE is cleared in combination with this setting, the Watchdog Timer is in Interrupt
Mode, and the corresponding interrupt is executed if time-out in the Watchdog Timer occurs.
Watchdog Timer Configuration
WDTON(1)        WDE        WDIE           Mode                     Action on Time-out
      1                  0             0              Stopped                        None
      1                  0             1              Interrupt Mode           Interrupt
      1                  1             0              System Reset Mode       Reset
      1                  1             1              Interrupt                    interrupt
                                                        System Reset             then go
                                                        Mode                        to system
        reset
      0                  x             x            System Reset Mode         Reset
• Bit 5, 2..0 - WDP3..0: Watchdog Timer Prescaler 3, 2, 1 and 0
The WDP3..0 bits determine the Watchdog Timer prescaling when the Watchdog Timer is running.
Watchdog Timer Prescale Select
WDP3 WDP2 WDP1 WDP0         Number of WDT     Typical Time-out at
                                              Oscillator Cycles     VCC = 5.0V
   0         0      0        0             2K (2048) cycles       16 ms
   0         0      0        1             4K (4096) cycles       32 ms
   0         0      1        0             8K (8192) cycles       64 ms
   0         0      1        1            16K (16384) cycles    0.125 s
   0         1      0        0            32K (32768) cycles    0.25 s
   0         1      0        1            64K (65536) cycles    0.5 s
   0         1      1        0            128K (131072) cycles 1.0 s
   0         1      1        1            256K (262144) cycles 2.0 s
   1         0      0        0            512K (524288) cycles 4.0 s
   1         0      0        1            1024K (1048576) cycles 8.0 s
Logged
Indiana
Offline Offline
Full Member
Arduino rocks
View Profile
Well I guess you can use it for a "time-based" interrupt. But that's what the hardware timers really are for. They can also generate a number of different interrupts based on how you configure them.
The watchdog timer is really designed to allow some event to happen if the watchdog doesn't get reset before it expires. Normally the "something" is reset the chip. The code then must reset the timer frequently (at least faster than the timeout) to prevent the watchdog from firing. This is sometimes referred to as "feeding the dog". Then if the chip crashes or the code goes awry, the watchdog timer will expire and fire the "something" (reset the chip).
The other problem with using the watchdog is that if it triggers a reset it's still enabled when the chip restarts. The bootloader doesn't disable it or regularly "feed the dog" since it doesn't expect the watchdog to be enabled. This can then lead to an endless loop of resets that can only be resolved by reburning the bootloader with a programmer.
So the short answer is the hardware timers are designed to be used for what you're trying to do, not the watchdog timer.
Logged
Indiana
Offline Offline
Full Member
Arduino rocks
View Profile
Ignore the part about having to reburn the bootloader. That only applies if the watchdog fuses were set which isn't a normal Arduino occurrence.
You will still get into an annoying reset loop, but it can be cured by power cycling the chip (which is annoying if your trying to upload a program).
Logged
SF Bay Area (USA)
Offline Offline
Faraday Member
Strongly opinionated, but not official!
View Profile
Also note that the watchdog timer uses an internal, uncalibrated, RC clock that has a very low accuracy compared to the crystal-based "normal" timers; it will probably make a lousy "24 hour clock."
Code:
Your second write to WDTCSR is overwriting the prescaler bits, I think.  And/or apparently you need to set WDE to change the prescaler, even if you're going to immediately clear it.    See the bottom of page 49 of the Atmega168 datasheet.  This sequence seems to work:
Code:
 WDTCSR  = (1<<WDCE | 1<<WDE);     // watchdog change enable
 WDTCSR  = 1<<WDIE | (0<<WDP3)|(1<<WDP2) | (1<<WDP1); // set  prescaler to 1 second
Logged
0
Offline Offline
Newbie
Arduino rocks
View Profile
Thanks so much for the advise! I will probably stick to other interrupts beings that the watchdog is not entended for that reason.
Thx for all the help my friends!!  smiley-grin
Logged
0
Offline Offline
Newbie
Arduino rocks
View Profile
Has anyone managed to get an interrupt from a wdt?
I'm trying with:
Code:
     cli();      // important: disable interrupts
      WDTCSR = (1 << WDCE); // watchdog change enable
      WDTCSR |= (1 << WDIE) | (0 << WDE); // enable wdt interrupt
      sei();
and:
Code:
ISR(WDT_vect)
      wdt_disable();
      Serial.println("Got watchdog reset...");
      delay(700);
Logged
UK
Offline Offline
Faraday Member
Gorm deficient
View Profile
Sleep modes and watchdog interrupt:
http://www.arduino.cc/cgi-bin/yabb2/YaBB.pl?num=1263247150/15
Logged
Per Arduino ad Astra
Pages: [1]   Go Up
Print
Jump to:
