Topic: "AWT-EventQueue-0" java.lang.StackOverflowError (Read 8320 times) previous topic - next topic
rpowell86
Hey People,
started making some real progress on my project and then compiling it I get:
Exception in thread "AWT-EventQueue-0" java.lang.StackOverflowError
     at java.util.Stack.push(Stack.java:67)
     at com.oroinc.text.regex.Perl5Matcher._pushState(Perl5Matcher.java)
where the last line occurs about 100 times  ::)
This is an arduino/processing problem, but I dont know why! Ive tried remove the *.o files and retrying without any luck.
Building any arduino example works, but my sketch dont.
Is there a limit to the size of a *.pde file it can process? Mines 437 lines.
Oh yeh, this is version 17.
Thanks,
Ryan
PaulS
Stacks are used for many things by compilers. Function arguments are pushed onto a stack, then popped off the stack by the called function. Return addresses are pushed onto a stack, then popped off as the functions return.
Having a function call itself can generate a stack overflow, if there is no way to terminate the call. However, this is generally a run-time issue, not a compile-time issue.
Without seeing your code, there is no way to guess what the problem is. Can you post it?
437 lines of code may be a lot of code, or it might not. It all depends on what the code is doing.
rpowell86
By the way Im using the asynclabs Wishield Library
rpowell86
#include "WiServer.h"
#include <EEPROM.h>
#include <Wire.h>
#define enableWifi 0
#define TRUE 1
#define FALSE 0
#define on 1
#define off 0
#define I2C_Write(a) (a&0x0xFEU)
#define I2C_Read(a) (a|0x01U)
#define MCP9802  72U
#define MCP9802_R 0b10010001
#define MCP9802_W 0b10010000
#define M41T81_R 0b11010001
#define M41T81_W 0b11010000
#define ledPin 9
boolean bLed = on;
#if enableWifi == TRUE
// Wireless configuration parameters ----------------------------------------
#define WIRELESS_MODE_INFRA      1
#define WIRELESS_MODE_ADHOC      2
unsigned char local_ip[] = {192,168,0,10};      // IP address of WiShield
unsigned char gateway_ip[] = {192,168,0,1};      // router or gateway IP address
unsigned char subnet_mask[] = {255,255,255,0};      // subnet mask for the local network
const prog_char ssid[] PROGMEM = {"thegrannybashers"};            // max 32 bytes
unsigned char serialBufIdx = 0U;
#define serialBufMax sizeof(serialBuf)
unsigned char security_type = 2;      // 0 - open; 1 - WEP; 2 - WPA; 3 - WPA2
// WPA/WPA2 passphrase
const prog_char security_passphrase[] PROGMEM = {"QSPELQJP"};      // max 64 characters
// WEP 128-bit keys
// sample HEX keys
prog_uchar wep_keys[] PROGMEM = {      0x01, 0x02, 0x03, 0x04, 0x05, 0x06, 0x07, 0x08, 0x09, 0x0a, 0x0b, 0x0c, 0x0d,      // Key 0
                                                     0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,      0x00,      // Key 1
                                                     0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,      0x00,      // Key 2
                                                     0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,      0x00      // Key 3
// setup the wireless mode
// infrastructure - connect to AP
// adhoc - connect to another WiFi device
unsigned char wireless_mode = WIRELESS_MODE_INFRA;
unsigned char ssid_len;
unsigned char security_passphrase_len;
#endif
/* Meter declarations */
unsigned int impCount = 0U;
unsigned char kwhTotalDay = 0U;
/* Cost of KW-Hr */
#define penceKWH 12U
/* How many pulses to one KWH */
#define impPerKWH 5U
/* How many days to cache in eeprom */
#define numDaysCache 30U
unsigned char eepromIdx = 0U;
boolean processHTMLReq ( char* URL );
#endif
void processBlip ( void );
void resetDevice( void );
boolean getTemperature ( void );
boolean getTime ( void );
void serialPrintEnv ( void )
         Serial.print("\nWifi-Status:");
         Serial.print("\nLocal Ip: ");
         Serial.print(local_ip[0], DEC);
         Serial.print(".");
         Serial.print(local_ip[1], DEC);
         Serial.print(".");
         Serial.print(local_ip[2], DEC);
         Serial.print(".");
         Serial.print(local_ip[3], DEC);
         Serial.print("\nGateway Ip: ");
         Serial.print(gateway_ip[0], DEC);
         Serial.print(".");
         Serial.print(gateway_ip[1], DEC);
         Serial.print(".");
         Serial.print(gateway_ip[2], DEC);
         Serial.print(".");
         Serial.print(gateway_ip[3], DEC);
         Serial.print("\nSubnet Ip: ");
         Serial.print(subnet_mask[0], DEC);
         Serial.print(".");
         Serial.print(subnet_mask[1], DEC);
         Serial.print(".");
         Serial.print(subnet_mask[2], DEC);
         Serial.print(".");
         Serial.print(subnet_mask[3], DEC);
         Serial.print("\nSSID: ");
         Serial.print(&ssid[0]);
         Serial.print(", Passphrase: ");
         Serial.print(&security_passphrase[0]);
         Serial.print(", SECURITY-");
         switch (security_type)
           case 0:
             Serial.print("OPEN");
           case 1:
             Serial.print("WEP");
           case 2:
             Serial.print("WPA");
           case 3:
             Serial.print("WPA2");
           defualt:
             Serial.print("UNKOWN");
         Serial.print("\n\n");
#endif
void resetDevice ( void )
 unsigned char i = 0U;
 /* Reset eeprom values */
 for(i=0U;i<=numDaysCache;i++)
   EEPROM.write(i,0U);
 EEPROM.write(255U,0);
 impCount = 0U;
 kwhTotalDay = 0U;
 impCount = impCount + 1U;
 if ( impCount >= impPerKWH )
   impCount = 0U;
   /* Increment totalKWH */
   kwhTotalDay = kwhTotalDay + 1U;
   EEPROM.write(eepromIdx,kwhTotalDay);
 Wire.beginTransmission(M41T81_R);
 Wire.send(0x02);
 Wire.endTransmission();
 Wire.requestFrom(M41T81_R,1);
 while(Wire.available())
   Serial.println(Wire.receive(),DEC);
 return false;
 unsigned char tempVal = 0;
 unsigned char tempRead1 = 0U;
 unsigned char tempRead2 = 0U;
 boolean tempNegative = false;
 bReturnVal=false;
 /* Begin transmission to MCP9800X */
 Wire.beginTransmission((int)MCP9802_R);
 /* Request temperature register */
 Wire.send(0x00);
 Wire.requestFrom((int)MCP9802_R,2);
 if (Wire.available() > 0 )
   Serial.println("Data available");
   Serial.println("NO data available");
 if(Wire.available())
   tempRead1 = (unsigned char)Wire.receive();
     tempRead2 = Wire.receive();
     bReturnVal=true;
 if (tempRead2 & 0b10000000)
   tempNegative = true;
 tempVal = (tempRead2 & 0b10000000) >> 7;
 tempVal = (tempRead1 << 1) | tempVal;
 Serial.print("Temperature: ");
 if (tempNegative)
   Serial.print("-");
 Serial.print(tempVal,DEC);
 Serial.println("");
 return bReturnVal;
 bInitStatus=true;
 Serial.println("Initializing Wifi");
 WiServer.init(processHTMLReq);
#else
 Serial.println("NO Wifi enabled");
#endif
 Serial.println("Retrieving values from eeprom");
 eepromIdx = EEPROM.read(255);
 kwhTotalDay = EEPROM.read(eepromIdx);
 Serial.println("Setting up Phototransistor");
#if 0
 pinMode(3, INPUT);
 digitalWrite(3, HIGH);
 pinMode(4, OUTPUT);
 digitalWrite(4, HIGH);
 pinMode(5, INPUT);
 digitalWrite(5, LOW);
#endif
 Serial.println("connecting to I2C bus");
 Serial.println("Retrieving temperature");
 Wire.begin();
 if (getTemperature())
   bInitStatus=false;
   Serial.println("Failed to get the temperature, I2C connected?");
 Serial.println("Retrieving time");
 if (getTime())
   bInitStatus=false;
   Serial.println("Failed to get the time, I2C connected?);
 Serial.println("Initializing complete\n");
 Serial.println("Wifi enabled to:");
 serialPrintEnv();
#endif
 if (!bInitStatus)
   while(1)
     Serial.println("\n\nERROR: Failed to initiliaze some components!\nHALTING !!!\n");
 /* Keep the webpage alive */
 WiServer.server_task();
#endif
 if (digitalRead(3) == HIGH)
   digitalWrite(ledPin, HIGH);
   digitalWrite(ledPin, LOW);
 if ( Serial.available() > 0U )
   char serialChar = Serial.read();
   switch (serialChar)
     case '1':
     //fake electric meter blip
     processBlip();
     case '9':
       //increment the day
       eepromIdx += 1U;
       if (eepromIdx > numDaysCache)
         eepromIdx = 0U;
       /* Reset the KWH count */
       EEPROM.write(eepromIdx,0U);
       kwhTotalDay = 0U;
     case 'R':
       /* Reset device */
       Serial.println("Resetting device");
       resetDevice();
       Serial.println("done!");
 unsigned char day = 0U;
 unsigned char cacheMinusIdx = numDaysCache - eepromIdx;
 unsigned char kwhRead = 0U;
 unsigned int kwhTotalMonth = 0U;
 WiServer.print("<html>");
 /* Auto-refresh page every 60 seconds */
 WiServer.print("<head><meta http-equiv=\"refresh\" content=\"60\"></head>");
 for(i=eepromIdx;i>0;i--)
   WiServer.print("Days-ago: ");
   WiServer.print(day,DEC);
   WiServer.print(", usage: <b>");
   kwhRead = EEPROM.read(i);
   WiServer.print(kwhRead,DEC);
   WiServer.print(" KW-Hours</b><br>");
   kwhTotalMonth += kwhRead;
   day += 1;
 for(i=numDaysCache;i>eepromIdx;i--)
   day += 1;
 WiServer.print("<hr>KWH cost today: <b>");
 WiServer.print((penceKWH*kwhTotalDay)/100, DEC);
 WiServer.print(".");
 WiServer.print(((penceKWH*kwhTotalDay)%100), DEC);
 WiServer.print("p</b>,  Past month: <b>");
 WiServer.print(((penceKWH*kwhTotalMonth)/100), DEC);
 WiServer.print(((penceKWH*kwhTotalMonth)%100), DEC);
 WiServer.print("p</b>,  Cost per KWH: <b>0.");
 WiServer.print(penceKWH, DEC);
 WiServer.print("p</b>,  KWH used past hour: <b>");
 WiServer.print("NOT IMPLEMENTED");
 WiServer.print("</b>,  Blips Counted: ");
 WiServer.print(impCount,DEC);
 WiServer.print("</html>");
 return true;
#endif
rpowell86
Ive just fixed this.
But read on:
There are a few bugs in the code (undeclared variables, strings quotes not terminated)
But the processing does return them. Does the ide do some preprocessing before passing it to gcc?
Can an arduino ide developer confirm if the above is a known bug.
Thanks
Ryan
PaulS
Quote
Fixed what? The stack overflow error? If so, what did you do to fix it?
rpowell86
There were some bugs in the code. But when I compile it I get the stackoverflow error and not the errors about the code.
This is a bug in the arduino IDE
wayoda
Hi Ryan,
Quote
But read on:
There are a few bugs in the code (undeclared variables, strings quotes not terminated) ..... Does the ide do some preprocessing before passing it to gcc?
Yes : http://code.google.com/p/arduino/wiki/BuildProcess
Quote
I'm not one of the developers, but I can confirm that the preprocessing of the Sketch chokes at least on the strings quotes not terminated parts.
Eberhard
marcello.romani
Hi, I had the same exception as the OP and found out that it was due to a double-quote character wrongly typed around the mid of a sketch.
Serial.println("buf);
and the some 100 lines of code...
Removing that " typo solved the issue.
