Author Topic: Arduino and PWM  (Read 377 times)
one question,
why the arduino function analogWrite only work in 6 pins?
I needed to use 7 PWM ports, so I wrote new function so that I was able to use up to 14 PWM pins.
Thanks
Seattle, WA USA
Seattle, WA USA
Want to tell us anything about the function? How does it work? What timers does it use? What frequency is the duty cycle change?
I used a part of the code found on arduino.cc website.
To make the LED fade, I used the function delayMicroseconds
worked well
   for(i=1;i<=1000;i++){
      digitalWrite(j, HIGH);
      delayMicroseconds(i);
        digitalWrite(j, LOW);
        delayMicroseconds(1000 - i);
« Last Edit: May 23, 2010, 12:04:39 pm by dansku » Logged
UK
And the processor load vs. using the PWM pins?
Why did you stop at 14?
What about the analogue pins?
« Last Edit: May 23, 2010, 12:10:49 pm by AWOL » Logged
UK
Gorm deficient
With the code snippet above, for 14 pins, you're looking at a refresh rate of around 70Hz, which will produce noticeable flicker on an LED.
The hardware pins operate at around 490Hz.
Per Arduino ad Astra
ah, that's the difference then
but i cant see it flickering smiley
Manchester (England England)
Solder is electric glue
For all the pins PWMed see:-
http://www.arduino.cc/playground/Main/PWMallPins
