Topic: Arduino Uno + HC-05 + OBD2 ELM adapter = no paring (Read 2341 times) previous topic - next topic
alphazo_id
Hi all
I am trying to play around with an ELM327 OBD2 bluetooth adapter on my old Honda Civic, but encountered a problem with bluetooth paring.
Here is the schema:
And here is the code:
Code: [Select]
#include <SoftwareSerial.h>
#include <Wire.h>
#define RxD 10
#define TxD 11
LiquidCrystal_I2C lcd(0x3F, 16, 2);
SoftwareSerial SoftSerial(RxD,TxD);
byte inData;
char inChar;
String BuildINString="";
String DisplayString="";
String WorkingString="";
long DisplayValue;
long A;
  lcd.init();
  lcd.backlight();
  lcd.home();
  lcd.setCursor(0, 0);
  lcd.print("Honda Civic VII");
  delay(3000);
  lcd.clear();
  //Check if ELM327 responded
  Retry:
  lcd.print("                    ");
  lcd.setCursor(0, 1);
  lcd.print("Connecting......    ");
  //Set up Serial communication at 9600 baud
  SoftSerial.begin(9600);   //initialize Serial
  SoftSerial.println("ATZ");
  lcd.print("OBD2");
  delay(2000);
  ReadData();
                                             // If used substring(1,4)=="ATZ" needed a space before ATZ in Serial Monitor and it did not work
  if (BuildINString.substring(1,3)=="TZ")    // MIATA RESPONSE TO ATZ IS ATZ[[[ELM327 V1.5  OR AT LEAST THAT IS WHAT ARDUINO HAS IN THE BUFFER
      lcd.clear();
      lcd.print("Welcome");
      lcd.setCursor(9, 0);
      //lcd.print(BuildINString);   //Echo response to screen "Welcome  ELM327"
      lcd.print("Connection OK         ");
      delay(1500);
      lcd.clear();
      lcd.print("Error             ");
      lcd.print("No Connection!         ");
      delay(1500);
      lcd.clear();
      goto Retry;
  //Added this from the test Code
  SoftSerial.println("0100");          // Works with This  only
  lcd.print("Initialzing.....");          //Initialize BUS  //lcd.print("0100 Sent");
  delay(4000);
  ReadData();
  lcd.setCursor(0, 0);            //Added 12-10-2016
  lcd.print("Initialized.....");  //Added 12-10-2016
  lcd.clear();
  // Added to display Coolant Temp
  lcd.print("Coolant Temp    ");
  //resets the received string to NULL  Without it it repeated last string.
  BuildINString = "";
  SoftSerial.println("0105");  // Send Coolant PID request 0105
  //SoftSerial.flush();         //Not sure if it's needed*********************************************
  // Receive complete string from the serial buffer
  ReadData();  //replaced below code
  // Parse the received string, retrieve only the hex value for temperature  Example: 32 is the 11 and 12th character
  // 0105[41 05 32   Correct value reading back  10 degrees. (11,13 or even 11,14 works)
  WorkingString = BuildINString.substring(11,13);
  A = strtol(WorkingString.c_str(),NULL,16);  //convert hex to decimnal
  DisplayValue = A;
  DisplayString = String(DisplayValue - 40) + " C            ";  // Subtract 40 from decimal to get the right temperature
  lcd.print(DisplayString);
  //Check if if over 100 C ******************************************************
  int B;
  B = DisplayString.toInt();  //Convert String to Integer  .toInt()
  if (B >= 100){     //Check if if over 100 C
    // ------- Quick 3 blinks of backlight  -------------
    for(int i = 0; i< 3; i++)
      lcd.display();   //For I2C use lcd.backlight
      delay(250);
      lcd.noDisplay(); //For I2C use lcd.noBacklight
      delay(250);
    lcd.display(); // finish with backlight on   //For I2C use lcd.backlight
//Read Data Function ***********************************************************
void ReadData()
  BuildINString="";
  while(SoftSerial.available() > 0)
    inData=0;
    inChar=0;
    inData = SoftSerial.read();
    inChar=char(inData);
    BuildINString = BuildINString + inChar;
Before, the HC-05 bluetooth was switched to AT mode and all that should be, set:
Code: [Select]
AT+BIND=0019,6D,3292EF
OK
AT+BIND?
+BIND:19:6d:3292ef
OK
AT+CMODE?
+CMOD:1
OK
AT+CMODE=0
OK
AT+ROLE?
+ROLE:1
OK
AT+PSWD?
+PSWD:1234
OK
But, according to the LED blinking on the HC-05 module, it can't pair with ELM327 adapter (adapter is fully working, the smartphone connects to it without any issues)
LED blinkage Youtube link
Any advises would be very helpful, thank you in advance!
alphazo_id
UPD1:
When connecting via smartphone, the LEDs on ELM327 blinks. They blink when connection starts, change the blink color and rhythm when it connects and when interchanging the data.
When trying to connect using the HC-05 they doesn't blink at all. Looks like the bluetooth module doesn't even try to connect to it. Although in slave mode I can connect to it via my smartphone and change some data.
It doesn't want to work only in Master mode.
UPD2:   Connection of EN (KEY) pin from HC-05 was removed from Arduino's PIN9. Nothing changed.
kthax
You've got to start from the beginning.
First, you'll need to modify your hc-05. You MUST get pin34 connected to a 5 volt line, that way whenever you power on the BT device, it enters the AT command mode.
Also this gives you the full control of the hc-05 module.
Once you do that you have to follow these steps:
Upload this sketch to the arduino:
http://www.instructables.com/id/Modify-The-HC-05-Bluetooth-Module-Defaults-Using-A/
Open Serial Monitor
Type the following ensuring you have CR and NL selected and if my memory is correct, baud rate should be at 38400 (both during AT command mode and during the transmission of the PIDs)
at+reset
at+cmode=0
at+inqm=0,5,9
at+init
at+inq (now the led on the hc-05 starts to blink rapidly also turn on the car and make sure the elm327 is powered before you do this step)
You should get a response with the address of the elm327 device.
Now type
at+rname?0019,6d,3292EF
to verify if the address you've typed is correct (its easy to screw up the placement of the comma "," also for this step alone, use the entire address i.e 0019,6d,3292EF)
once you get the name its time to connect, note that the name thing is not relevant
at+pair=196D,32,92EF,9 (you'll have to remove the initial zeroes in this step)
at+bind=196D,32,92EF
at+cmode=1
at+link=196D,32,92EF
Turn off the arduino board, disconnect pin34 from any kind of input. You wont be needing it until you try pairing the hc-05 with another bt device.
Turn on the arduino board and open the serial monitor
Now you should notice the led light on the hc-05 blink in a different pattern, it indicates that it has connected to the elm327
And now you can type the PIDs in the serial monitor(like 010D) and you should get a response.
Now if you've gotten it to work this far then let me know and I'll tell you what to do with the display.
Cheers.
at-midnight
Hi kthax
I was wondering if you could offer me any more guidance.
I'm trying to make this odb2 project as well.
I'm following your instructions to update the HC-05.
Everything goes well with all commands returning OK until I get to
the AT+PAIR=  then i get no response at all.
Any ideas?
Thanks
Gavin
