Topic: MKR1000 robot project : can't connect to http://WiFiRobot.local/ (Read 992 times) previous topic - next topic
qubifoo
HI
I am trying to implement this Robot project with the MKR1000 : HERE
The code compile successfully and upload successfully. I did update the FW to 19.4.4 and followed the instructions HERE
I believe I managed to connect to my router, see below the output of the serial monitor from the Arduino window:
SSID: NETGEARxx
IP Address: xxx.xxx.x.xx
signal strength (RSSI):-67 dBm
Server listening at http://WiFiRobot.local/
But when I enter "http://WiFiRobot.local/" in the urL of a safari browser it remains stuck and a chrome browser would return a DNS error.
Do you have any idea where the issue could be or what should I focus on ?
qubifoo
I confirm I am connected to the router as when open its interface I can see the MAC address of the MKR1000.
Chrome still give DNS error message
ballscrewbob
Can you access it via its IP rather than the local host name ?
It may not be the answer you were looking for but its the one I am giving based on either experience, educated guess, google or the fact that you gave nothing to go with in the first place so I used my wonky crystal ball.
qubifoo
It works ! Would you be able to explain what was happening ?
ballscrewbob
Possibly a router / ISP issue / OS IP resolving issue.
Plenty of reasons for it not to work via an unqualified domain.
If you have IPV6 enabled try turning it off for a few tests.
qubifoo
I was reading about MDNS issue on Apple environment and was wondering if that could be the issue. Anyway thanks for your help it works now.
