Topic: Using 2 attachInterrupt to read two data inputs (Read 873 times) previous topic - next topic
Bacanitus
Hello
First of all I want to congratulate this forum for a excellent job on helping other's. I've been reading some post and I see that everybody wants' to help.
I too have a little problem using attachInterrupt.
I want to create a code that would print the digital data coming from a Digimatic Indicator (IDS). The device isn't important. I've already succeeded printing the data from one device trough the serial pot using attachInterrupt function but know for two devices the problem is that the data coming from each one are all scrambled..
Both data sources have a clock signal and a data signal, i have to read the data signal when the clock signal is rising.  So i used a interrupt to sample the data from the data line. For just one device the code that I've used was the following:
Code: [Select]
int dadosA = 4;
// ClockA is digital pin 2 on the Duemilenove.
int clockA = 2;
 Serial.begin (9600);
 //Inputs
 pinMode (dadosA, INPUT);
 pinMode (clockA, INPUT);
// cicleA is a function which reads from digital pin 2 when triggered
 attachInterrupt(0, cicleA,RISING);
void loop(){
void cicleA(){
     if (digitalRead (dadosA) ==LOW){
     Serial.write("A");
     Serial.write("0");
     else{
     Serial.write("A");
     Serial.write("1");
It works fine and I don't have any problems..
For two devices the code I'm trying to implement is something like this:
Code: [Select]
int dadosA = 4;
int dadosB = 5;
int clockA = 2;
// ClockB is digital pin 3 on the Duemilenove.
int clockB = 3;
 //Inputs
 pinMode (dadosB, INPUT);
 pinMode (clockB, INPUT);
// cicleB is a function which reads from digital pin 3 when triggered
 attachInterrupt(1, cicleB,RISING);
void loop(){
void cicleA(){
     Serial.write("A");
     Serial.write("0");
     else{
     Serial.write("A");
     Serial.write("1");
void cicleB(){
     if (digitalRead (dadosB) ==LOW){
     Serial.write("B");
     Serial.write("0");
     else{
     Serial.write("B");
     Serial.write("1");
The data that I receive is all scramble and sometimes it doesn't prints all the bites  that it should.
I'm using Arduino Duemilanove ATMEGA328?
Thanks for any help?
Regards
kg4wsv
Pretty much every interrupt discussion you can find here will tell you "don't do serial I/O (Serial.write(), etc) inside your interrupt handler."
So, now it's your turn: don't do serial I/O inside your interrupt handler.
-j
Bacanitus
thanks for the tip... I'm going to try another routine...
Confirm your email address
Thank you for subscribing!
Arduino
via Egeo 16
Torino, 10131
Italy
