Topic: AnalogRead error (Read 4430 times) previous topic - next topic
edgardmi
Hello,
Im trying to read a value from a LM35 at PIN A0 and I getting the follow error:
Cannot convert from 'int' to 'string'
Could anyone help me?
Project: Arduino UNO + Raspberry pi 3 + Visual Studio 2017 Pro + Windows 10 iot Core
Thank you very much!
Code: [Select]
using System;
using Windows.UI.Xaml;
using Windows.UI.Xaml.Controls;
using Microsoft.Maker.Serial;
using Microsoft.Maker.RemoteWiring;
using Microsoft.Maker.Firmata;
namespace Raspberry
    public sealed partial class MainPage : Page
        private UsbSerial connection;
        private RemoteDevice arduino;
        private UwpFirmata firmata;
        private const byte led1 = 13;
        private const byte led2 = 12;
        private DispatcherTimer readTemperatureTimer;
        private const int lm35 = 14;
        public MainPage()
            this.InitializeComponent();
            this.Unloaded += MainPage_Unloaded;
            InitWRA();
        private void InitWRA()
            connection = new UsbSerial("VID_0403", "PID_6001");
            firmata = new UwpFirmata();
            arduino = new RemoteDevice(firmata);
            firmata.begin(connection);
            connection.ConnectionEstablished += Connection_ConnectionEstablished;
            connection.begin(57600, SerialConfig.SERIAL_8N1);
        private void Connection_ConnectionEstablished()
            arduino.pinMode(led1, PinMode.OUTPUT);
            arduino.pinMode(led2, PinMode.OUTPUT);
            arduino.pinMode(lm35, PinMode.ANALOG);
            textConnection.Text = "Connected";
            var action = Dispatcher.RunAsync(Windows.UI.Core.CoreDispatcherPriority.Normal, new Windows.UI.Core.DispatchedHandler(() =>
                setup();
        private void setup()
            //Set the timer to schedule every 500 ms.
            readTemperatureTimer = new DispatcherTimer();
            readTemperatureTimer.Interval = TimeSpan.FromMilliseconds(500);
            readTemperatureTimer.Tick += readTemperature;
            readTemperatureTimer.Start();
        private void Onbutton_Click(object sender, RoutedEventArgs e)
            arduino.digitalWrite(led1, PinState.HIGH);
            Onbutton.Visibility = Visibility.Collapsed;
            Offbutton.Visibility = Visibility.Visible;
        private void MainPage_Unloaded(object sender, RoutedEventArgs e)
            arduino.Dispose();
        private void Offbutton_Click(object sender, RoutedEventArgs e)
            arduino.digitalWrite(led1, PinState.LOW);
            Offbutton.Visibility = Visibility.Collapsed;
            Onbutton.Visibility = Visibility.Visible;
        private void readTemperature(object sender, object e)
            //Read analog value from 0 to 1023, which maps from 0 to 5V
            int temperatureValue = arduino.analogRead(lm35);
            //Convert analog value to temperature.
            double temperature = (500.0 * temperatureValue) / 1024.0;
            //Print temperature to Output.
            textTemp1.Text = temperature.ToString() ;
edgardmi
Hello!
I found the solution:
Code: [Select]
using System;
namespace Raspberry
        private UsbSerial usb;
        public MainPage()
            usb = new UsbSerial("VID_0403", "PID_6001");
            arduino = new RemoteDevice(usb);
            arduino.DeviceReady += onDeviceReady;
            usb.begin(57600, SerialConfig.SERIAL_8N1);
        private void onDeviceReady()
                setup();
            //Set the pin mode of the led.
            arduino.pinMode("A0", PinMode.ANALOG);
            readTemperatureTimer.Interval = TimeSpan.FromMilliseconds(1000);
            int temperatureValue = arduino.analogRead("A0");
