Topic: Help with installing a bootloader (Read 5829 times) previous topic - next topic
Jassper
May 27, 2010, 10:24 pm Last Edit: May 27, 2010, 10:24 pm by Jassper Reason: 1
I am trying to install the bootloader for the ATMEGA 1280.
I am using Arduno v17 and an USB tiny ISP programmer.
It seems to upload fine but at the end I get this message
Reading | ################################################## | 100% 70.45s
avrdude: verifying ...
avrdude: verification error, first mismatch at byte 0x1f000
        0x0c != 0xff
avrdude: verification error; content mismatch
avrdude done.  Thank you.
Thanks
leppie
Quote
Is your bootloader larger than 124kb ????
Jassper
#2
May 28, 2010, 02:01 pm Last Edit: May 28, 2010, 02:05 pm by Jassper Reason: 1
I don't know, I am useing the one that comes with the Arduino_17 program. I also updated to version 18, same result. I wouldn't think that the standard bootloader is larger than what the chip can hold.
I have been able to upload several different sketches to the MEGA1280 and they seem to run fine, but I am worried that it is unreliable because of the boot load error.
EDIT
I am useing the this programmer, http://www.sparkfun.com/commerce/product_info.php?products_id=9231
could that be an issue?
Jassper
msproul
I have been having the same error on both 1280 and 2560, HOWEVER, it programs correctly and works.
On the 1280, the standard bootloader has a MONITOR mode, open up the serial port at 57600 and type "!!!"  It easiest to just hold down the "!" and hit reset on the board. this will bring up monitor which will verify that its working properly.
I have the standard bootloader modified to run on the 2560, but it does not support past 128K due to limitations in stk500 protocol
Mark
retrolefty
#5
May 30, 2010, 02:12 am Last Edit: May 30, 2010, 02:13 am by retrolefty Reason: 1
Quote
That's interesting, I have not read that posted here before. I tried it on my Seeeduino mega. It printed out a signature line, but then went ahead and jumped to the existing sketch. If there was no existing sketch already in flash, would the monitor stay in control, and is it interactive with the user in anyway?
Lefty
msproul
Lefty
the "monitor" has a very short time out, there are several commands you can give it including "j" to jump to the user program.
I have never seen it mentioned anywhere either, I discovered it looking through the bootloader source code that came with v0018.  It is specifically limited to the 1280.  I have been working on 2560 quite a bit and have found lots of interesting things.
Mark
retrolefty
Quote
That's very cool. I'll look over the source code someday, not that I'm very good at it.  ;D
I've done a lot of bootloader flashing on 328, 168, and mega 8 chips to test out my USBtiny programmer and a windows GUI driven AVRDUDE program, however I've stayed away from playing with my Seeeduino mega bootloader as it's soldered SM packaging scares me if I was to screw it up and not able to reload it properly.  ;)
Lefty
Jassper
Quote
Mark, Is there a way to get a list of these commands?
msproul
#9
May 31, 2010, 02:19 am Last Edit: May 31, 2010, 02:20 am by msproul Reason: 1
I went through the source code and came up with this.
First open the USB port at 57600 baud
First you send it "!!!"
it gives you a welcome message
    ATmegaBOOT / Arduino Mega - (C) Arduino LLC - 090930
Then you can type
   t  Toggle LED
   r  <ignore><x><x><ignore><ignore>   Read byte from address xx (x is a BINARY value)
   u  loop back, continuous loop to echo back what every you send
    b  external Bus, does something with external memory
    j Jump to user program, same as doing nothing.
It not a real good monitor, it doesnt do much, it is limited in size
It is only compiled for
     __AVR_ATmega128__ and
     __AVR_ATmega1280__
     I added __AVR_ATmega2560__
The monitor has a very short timeout. If you dont type something it goes back to waiting for download and then will start the user program if it exists
Mark
Jassper
Hay thanks,
I have been reading your other post as well
http://www.arduino.cc/cgi-bin/yabb2/YaBB.pl?num=1274821710
Do you think that might have something to do with the error message after installing the Bootloader?
msproul
#11
May 31, 2010, 10:06 pm Last Edit: May 31, 2010, 10:06 pm by msproul Reason: 1
Jassper
No, it does not. The above 80K has been resolved but I dont have it working yet because I cannot get gcc to compile.  the bug has been fixed in gcc 4.4.0
Mark
Jassper
#12
Jun 01, 2010, 07:49 pm Last Edit: Jun 01, 2010, 08:42 pm by Jassper Reason: 1
This is what I am working on,
it breaks out all 100 pins on the ATMEGA 1280.
This is the first proto type, so far 3 issues to note. 1) the ISP connector is "mirrored" so I had to solder the connector from the underside to line up with my programmers ISP. 2) the overall width of the board is 0.05 in to wide and won't line up with a breadboard. 3) the TX and RX LEDs don't flicker when uploading.
It provides a pin for unregulated voltage so you can use the on board V reg, or you can provide it an external +5 volts on the REG pin to power it. I also use a simple jumper to enable or disable USB port power.
At first I thought the TX and RX LEDs were installed back words, but I verified that I got them the correct polarity.
I haven't tested all the I/Os yet but everything seems to work aside from the above stated issues.
This is however 100% hand soldered so I need to investigate if I have a pins "jumped" someplace but my initial checks show negative.
EDIT
Found the issue with the TX and RX LEDs. Will correct on the next proto run
leppie
Quote
That's quite neat  :)  Good work.
borref
Quote
Since you're into building your own boards based on one of the 128k  AVR's I would get a "real programmer". The USB Tiny is a big mess, both hardware and software wise. As it is now you really don't know whether the programmer is at fault or your board is. Get an AVRSIP MKII using the Stk500v2 protocol. If you think the Atmel version is too expensive to justify, you may look at eBay for Chinese copies.
