Topic: Move project from UNO to Mega 2560 (Read 268 times) previous topic - next topic
sheshman
Jul 17, 2017, 10:43 am Last Edit: Jul 17, 2017, 10:50 am by sheshman
Hi Everyone,
I'm a rookie about arduino, i'm working on replication of this project
Code: [Select]
http://www.instructables.com/id/Star-Tracker-Using-28BYJ-48-Stepper-Motor-and-LCD-/
I'm using;
-28BYJ-48 step motor with ULN2003 controller card
-LCD KEYBOARD SHIELD
-Arduino UNO
Software ;
Code: [Select]
/* This sketch drives an 28BYJ-48 stepper motor via its ULN2003 driver
 *  initial start speed is 271.6 to drive a screw for tracking stars during astro photography.
 The value of adckeyin has been altered to reflect the values delivered by the HobyTronics unit
 if (adc_key_in < 50)   return btnRIGHT;
 if (adc_key_in < 195)  return btnUP;
 if (adc_key_in < 380)  return btnDOWN;
 if (adc_key_in < 555)  return btnLEFT;
 if (adc_key_in < 790)  return btnSELECT;
#include <AccelStepper.h>
#include <LiquidCrystal.h>
#define HALFSTEP 8
LiquidCrystal lcd(8, 9, 4, 5, 6, 7);
int adc_key_val[5] ={50, 195, 380, 555, 790 };
/*Motor pin definitions when using HobbyTronics Keypad shield
 have been changed to 15 16 17 18. */
#define motorPin1  15    // IN1 on the ULN2003 driver 1
#define motorPin2  16    // IN2 on the ULN2003 driver 1
#define motorPin3  17    // IN3 on the ULN2003 driver 1
#define motorPin4  18    // IN4 on the ULN2003 driver 1
/*original code using the authors keypad, the pinouts have to
be changed when using the hobby tronics keypad, this is the original
outputs allocated
#define motorPin1  3     // IN1 on the ULN2003 driver 1
#define motorPin2  4     // IN2 on the ULN2003 driver 1
#define motorPin3  5     // IN3 on the ULN2003 driver 1
#define motorPin4  6     // IN4 on the ULN2003 driver 1
int NUM_KEYS = 5;
int adc_key_in;
int key=-1;
int isRun;
double speeds = 271.6;
int maxspeed = 1245;
AccelStepper stepper1(HALFSTEP, motorPin1, motorPin3, motorPin2, motorPin4);
void setup() {                    // void means dont expect any return from this command
  lcd.clear();                    // clear the lcd
  lcd.begin(16, 2);               // set up the LCD's number of columns and rows:
  lcd.setCursor(0,0);
  lcd.print("    DURUYOR     ");  // display stopped on the LCD
  lcd.setCursor(0,1);
  lcd.print("HIZ ");            // display the value of speed
  lcd.print(speeds);              // display the value of speeds
  lcd.print("   ");
  isRun = 0;
  stepper1.setMaxSpeed(maxspeed); //1245
  stepper1.setSpeed(speeds);      //271.6
  adc_key_in = analogRead(0);    // read the value from the sensor
  key = get_key(adc_key_in);     // convert into key press
  if (key >= 0)                  // if keypress is detected
      if (key == 1) {
         speeds += 0.1;
         delay(50);
      if (key == 2 && speeds > 0) {
         speeds -= 0.1;
         delay(50);
      if (key == 0) {
         speeds += 10;
      if (key == 3) {
         speeds -= 10;
      if (speeds>maxspeed) {
         speeds = maxspeed;
      if (speeds<-maxspeed) {
         speeds = -maxspeed;
      if (key == 4) {
        isRun = 1 - isRun;
        lcd.setCursor(0,0);
        if (isRun == 1) {
          lcd.print("<-- DEVREDE --> ");
        delay(250);
      lcd.setCursor(0, 1);
      lcd.print("Hiz ");
      lcd.print(speeds);
      lcd.print("       ");
      delay(50);
  if (isRun == 1) {
    stepper1.runSpeed();
int get_key(unsigned int input)
    int k;
    for (k = 0; k < NUM_KEYS; k++)
      if (input < adc_key_val[k])
            return k;
    if (k >= NUM_KEYS)
      k = -1;  // No valid key pressed
    return k;
with above combination works perfectly,what i need is to add pressure sensor to stop motor when mechanic hits to pressure sensor.
LCD keyboard shield uses all the pins on UNO so there are no extra pins to connect pressure sensor,that's why i decided to move my project to Mega 2560.
When i connect LCD keyboard shield to 2560 as the same way UNO motor controller doesn't work,i mean leds on controller card is not flashing and motor is not turning,when i move back to UNO it works again.
I thought it could related to pin configuration in the software and i've tried several combinations but no luck.
The other thing i don't understand is LCD's pins getting in to A1-A2-A3-A4 on UNO but in the code developer setting motor pins as 15-16-17-18 why ?
Project Pictures :
How i can run this code on MEGA 2560 ?
Thanks in advance and sorry for bad english.
ieee488
Have you looked at the documentation for the Uno and the Mega 2560 pins?
It would explain a lot of things.
larryd
No technical PMs.
The last thing you did is where you should start looking.
sheshman
#3
Jul 18, 2017, 08:17 am Last Edit: Jul 18, 2017, 08:47 am by sheshman
You are right dude, i've searched on google as arduino mega 2560 pinout and figure it out that UNO and 2560 have different design about pinouts. So the problem solved.
Thanks for your comments.
