Topic: Can be Arduino IDE installed on PC Pentium II? (Read 568 times) previous topic - next topic
falexandru
Jul 17, 2017, 11:34 am Last Edit: Jul 17, 2017, 11:35 am by falexandru
Procesor Dual Core 1,8 GHz
Memory RAM 1Gb
HDD - 80 GB
Linux Ubuntu
Thank you!
horace
I have the IDE running on a Intel Core 2 6600 @ 2.4MHz, 2G RAM 146Mbyte hard disk  under Windows XP SP 3
falexandru
Thank you, Horace!
I guess the PC uses an USB 1.1., right?
On what Arduino do you connect it, please?
horace
the PC is a DELL OptiPlex 745 with USB 2.0
at  the moment it is connected to an Arduino Nano monitoring an experiment
on the PC I use C# with Visual Studio Express 2010 to communicate with the Arduino and display results
Robin2
#4
Jul 17, 2017, 01:35 pm Last Edit: Jul 17, 2017, 01:37 pm by Robin2
Have you tried it?  What happened.?
What version of Ubuntu are you using?
My guess is that it should be just fine - the IDE is just a Java program. There is very little to installing it. Download the version you want. Copy it to the directory you want. Extract the ZIP and enjoy.
...R
Two or three hours spent thinking and reading documentation solves most programming problems.
Nick_Pyner
Memory RAM 1Gb
HDD - 80 GB
Linux Ubuntu
The IDE will run on practically anything and, with a powerhouse like that, you can't go wrong. If you are having problems, it can hardly be your computer, unless it is actually faulty. Otherwise, you might look to the installation.
falexandru
