Author Topic: Change sign  (Read 394 times)
Hi  friends.
I'm making some code for a motorcontroller.  The arduino receives a negative number when the motor is supposed to spin backwards.
The value tells the desired speed as well.
To my understanding I can't write: analogwrite(pwmPin, -155), so
I  need to make an integer value change sign.
Like, if I have an integer called "x", and the value of x is -135.
How do I write the software to change the sign to + so the new value will be 135?
Thanks in advance smiley
Norway@Oslo
loveArduino(true);
x = -x;
[edit]I was jinxed  :o[/edit]
« Last Edit: September 21, 2010, 01:42:25 pm by AlphaBeta » Logged
Dallas
Online Online
Shannon Member
Assuming "MyValue" stores the value to be written...
if ( MyValue >= 0 )
  // Make the motor go forward here
  analogWrite( pwmPin, MyValue );
  // Make the motor go backware here
  analogWrite( pwmPin, [glow]-[/glow]MyValue );
@AlphaBeta: 15 seconds apart.  I'd say that's close enough for ... JINX!
« Last Edit: September 21, 2010, 01:33:09 pm by bcook » Logged
Thank you very much!
I knew there was an easy answer for this.
Just out of curiosity. Is this a possible solution as well?
analogWrite( pwmPin, MyValue*-1 );
Norway@Oslo
loveArduino(true);
Yes it is smiley
Austin, TX
CMiYC
abs() (absolute) would also work:
analogWrite( pwmPin, abs(MyValue) );
Just don't call any other functions inside of abs().
www.cmiyc.com - A guide to being an Enginerd
Thanks...
