Topic: Change sign (Read 2212 times) previous topic - next topic
Zahrec
Hi  friends.
I'm making some code for a motorcontroller.  The arduino receives a negative number when the motor is supposed to spin backwards.
The value tells the desired speed as well.
To my understanding I can't write: analogwrite(pwmPin, -155), so
I  need to make an integer value change sign.
Like, if I have an integer called "x", and the value of x is -135.
How do I write the software to change the sign to + so the new value will be 135?
Thanks in advance :)
AlphaBeta
#1
Sep 21, 2010, 08:30 pm Last Edit: Sep 21, 2010, 08:42 pm by AlphaBeta Reason: 1
x = -x;
[edit]I was jinxed  :o[/edit]
Coding Badly
#2
Sep 21, 2010, 08:31 pm Last Edit: Sep 21, 2010, 08:33 pm by bcook Reason: 1
Assuming "MyValue" stores the value to be written...
if ( MyValue >= 0 )
 // Make the motor go forward here
 analogWrite( pwmPin, MyValue );
 // Make the motor go backware here
 analogWrite( pwmPin, [glow]-[/glow]MyValue );
@AlphaBeta: 15 seconds apart.  I'd say that's close enough for ... JINX!
Zahrec
Thank you very much!
I knew there was an easy answer for this.
Just out of curiosity. Is this a possible solution as well?
analogWrite( pwmPin, MyValue*-1 );
AlphaBeta
James C4S
abs() (absolute) would also work:
analogWrite( pwmPin, abs(MyValue) );
Just don't call any other functions inside of abs().
Zahrec
