Loading...
Pages: [1]   Go Down
Author Topic: Step by step debugging arduino  (Read 786 times)
0
Offline Offline
Jr. Member
Arduino rocks
View Profile
I come to a point where standard serial debugging is not effective enough to debug my project.  I searched but I havent found a definitive how-to.  What do I need to have a step-by-step debugging solution hardware and software wise to be debug with the arduino?
« Last Edit: October 09, 2010, 08:51:05 am by Mart » Logged
0
Offline Offline
Faraday Member
20 LEDs are enough
View Profile
WWW
I suggest a JTAG debugger. However I asked about JTAG debuggers a while ago and still nobody in this forum seems to have a good description on how to setup such a debugger with Linux. However I am pretty sure that JTAG is the way to go.
Anyway I have >10 klocs and still stick to serial. It is possible although somewhat harder than with a debugger. In the end you need to understand what your code is doing. If you do not understand it a debugger is only a poor substitute.
Udo
Logged
Check out my experiments http://blog.blinkenlight.net
Seattle, WA USA
Offline Offline
Brattain Member
Seattle, WA USA
View Profile
Quote
If you do not know what the code is supposed to do, how would you recognize when it it is not doing it? How could you possibly debug code without understanding what it does?
Logged
Global Moderator
UK
Online Online
Brattain Member
I don't think you connected the grounds, Dave.
View Profile
JTAG is great...if you've got somewhere on your UUT to connect it to.
Never yet come across an Arduino problem that couldn't be solved with serial debug and possibly a 'scope.
(The day job involves many 100s of KLOCs, if not MLOCs, and 99% of debugging is done with little more than with serial prints)
Logged
Pete, it's a fool looks for logic in the chambers of the human heart.
0
Offline Offline
Jr. Member
Arduino rocks
View Profile
Well I hit that particular problem:
http://www.arduino.cc/cgi-bin/yabb2/YaBB.pl?num=1261506776
no serial print or scope could help me smiley
that being now partially workaround'd, I am looking for a better way to debug then serial print because when I enable log in my project, I break the 126976 byte maximum....
- avr dragon?
- http://search.digikey.com/scripts/DkSearch/dksus.dll?Detail&name=ATAVRISP2-ND
I found some post here and there but there is no definitive guide I guess on how to that smiley-sad
« Last Edit: October 09, 2010, 11:09:57 am by Mart » Logged
Global Moderator
UK
Online Online
Brattain Member
View Profile
Quote
Never yet come across a compile-time error that needed single-step debug either.
Logged
0
Offline Offline
Jr. Member
Arduino rocks
View Profile
it is more an arduino pre-processing voodoo bug/feature I believe...
anyway now the code is somewhat running but I am still having issue... I guess I could use some JTAG debugging...
« Last Edit: October 09, 2010, 11:25:12 am by Mart » Logged
Global Moderator
UK
Online Online
Brattain Member
View Profile
Quote
Yes, that I realise, but why do you think JTAG or ICE or whatever would help you with it?
Logged
0
Offline Offline
Jr. Member
Arduino rocks
View Profile
I guess if chip makers are creating debugging tool and suite, it may help me?
Logged
UK
Offline Offline
Faraday Member
Gorm deficient
View Profile
Not with cross-compiling problems, no, I don't think so.
Logged
Per Arduino ad Astra
ottawa, canada
Offline Offline
God Member
Arduino rocks
View Profile
I have a dragon and have run a 328 in debug mode through avr studio.
I did not find a good how-to but i fumbled my way through it.
Logged
Pages: [1]   Go Up
Print
Jump to:
