Topic: REplace USB type B with USB-C (Read 5219 times) previous topic - next topic
termistion
Hi, have Arduino Uno, but would like to have it USB-C like my Samsung Galaxy S8 so I can use the same car charger.
Cheers and great job.
Budvar10
Exactly, the connectors will be damaged more quickly and they could sell more UNOs in result. :)
It is not easy to make such change on the board. Each change in design has impact to profit. USB on the UNO is pretty durable and in my opinion it is the best for this format of the board. The most of chargers has A type socket so it is not problem to use different cable.
Arduino clone with ATmega1284P   http://forum.arduino.cc/index.php?topic=277260.0
ballscrewbob
And of course there are adaptors galore on Ebay and Amazon that take one type and make it into another.
I like the bigger more reliable connectors myself.
I have a bag full of those tiny ones that have been bent or squashed (not by me I might add).
It may not be the answer you were looking for but its the one I am giving based on either experience, educated guess, google or the fact that you gave nothing to go with in the first place so I used my wonky crystal ball.
Delta_G
What's funny is that a few posts down someone is asking to put the A on the Nano instead of the C.
OP have you considered the Nano?  Same chip same code but has the connector you want.
|| | ||| | || | ||  ~Woodstock
Please do not PM with technical questions or comments.  Keep Arduino stuff out on the boards where it belongs.
TELunus
Delta_G, that's false.  The Nano does not have a USB-C connector.  As of March 15, 2018, it the website says it "works with a Mini-B USB cable".  (see https://store.arduino.cc/usa/arduino-nano )
USB Mini-B is not particularly a great connector.  USB Type-C is a much more sturdy connector that is better in every way than regular USB: it's more compact than USB-A or USB-B, it can carry more current (it can carry 100W!) than they can (even if they're USB 3.0), it has significantly higher data speeds (you can transmit HD video over a tiny USB cable!), and it's rated for a larger number of connect/disconnection cycles than USB Micro-B.
Speaking of Micro-B, Micro-B is really not a great connector.  But at least it's become fairly standard.  USB Mini-B doesn't even have that going for it.  There was a short while where it looked like Mini-B was going to take off, but in the end Micro-B won.  Everyone has Micro-B cables in their house, whether it's from their phone, their chrome-cast, or who knows what else.  Whereas if you have an Arduino Nano it's probably the only reason to you have a USB Mini-B cord.
ballscrewbob
@TELunus
Clearly you overlooked the point that a lot of USB 3.0 chip-sets don't work with many of the arduinos or are hit and miss to say the very least.
I prefer the current selection of ports rather than adopting a new one that many people cannot use.
The USB connector also varies on the source as the clones have been moving to the micro connector for the UNO's.
The forum is littered with posts about non connecting or intermittent connecting boards of many types with a selection of connectors...The standard fix for anyone with those issues is to insert a standard USB 2.0 powered hub between the offending USB 3.0 and the Arduino.
Just some context.
Igoro00
"Clearly you overlooked the point that a lot of USB 3.0 chip-sets don't work with many of the arduinos"
USB-C isn't only about usb3.0. If you look at USB-C pinout, you would know that there is usb2.0 data + and - and regular usb 5V and GND.
This is all about the connector. My phone uses type C, my earphones uses type C. I dont have good quality microUSB cable anymore(i have Leonardo, UNO with this fckin type B would be even worse to find). Everyone is adopting type C so why arduino doesn't do that?
ballscrewbob
Quote
True but that does not get around the problem that some USB 3.0 chipsets still dont work with Arduino's.
Dont take my word for that as the forums are littered with examples.
As is the internet itself for more than just Arduino's.
The connector is fine and who knows Arduino might adopt it at some point.
As of right now that is not the case.
Personally I dont have any issues finding USB connectors all the way back.
I go as far as thrift stores to pick up cables and PSU's for pennies.
wolframore
#8
Today at 02:13 am Last Edit: Today at 02:13 am by wolframore
Yeah Arduinos need HMDI :D
Bad boys rate our young girls but Violet goes willingly :)
- this is a mnemonic from BEC
