Topic: Tone library using 16 bit timer (Read 2358 times) previous topic - next topic
mako34
Ive seen this subject in other threads but not the explanation or how to
(sorry still learning!)
so I want to use the tone library to generate tones from 1 hz,
I saw that the 16 bit timer needs to be used,
so how to I have to change to accomplish this?
thank you
gigawatts
I second this question. I have been looking to do the exact same thing.
mako34
#2
Oct 21, 2010, 09:56 pm Last Edit: Oct 21, 2010, 10:01 pm by mako34 Reason: 1
hi, thank you to mr Brett Hagman of Rogue Robotics
for the library and the explanation,
tone library:
http://code.google.com/p/rogue-code/wiki/ToneLibraryDocumentation
I have put togher this code, to generate 1Hz, 10 Hz, and 50Hz as test,
#include <Tone.h>
Tone freq1;
Tone freq2;
freq1.begin(11);
freq2.begin(8);
 freq2.play(1, 6000);
 delay (2000);
 freq2.play(10, 6000);
 delay (2000);
 freq2.play(50, 6000);
 delay (2000);
the freq2 is the timer of 16 bits
" The timers are allocated sequentially when you declare the Tone objects.  The second timer is Timer 1, which is a 16 bit timer."
Ok, very nice, thank you again Brett for the library and the explanation,
now to do my project !!! hahaha  :D
gigawatts
Thank you very much for the reply! This had been driving me nuts trying to figure out how to use Timer1.
I had also PM'd Brett, but I guess he got back to you first :D
Can I assume that only Timer1 is 16bit? For my project, I actually need 2 outputs (to drive a speedometer and a tachometer, both requiring a square wave with a frequency range of 0 to ~230 hz).
Thanks again!
