Topic: Cannot update firmware, programmer not responding (Read 4275 times) previous topic - next topic
kida001
Aug 05, 2017, 06:42 am Last Edit: Aug 05, 2017, 07:05 am by kida001
So I've been trying to update the firmware on my Wifi101 Shield, Model ATWINC1500-MR210PB
It's on firmware 19.4.4 and need to upgrade to 19.5.2 due to a bug that is fixed with making HTTP requests.
I have tried every which way to update the firmware. I tried the built in Firmware updater, but it just says "programmer not responding" whenever I try to test the connection or update the firmware. I tried opening the example sketch for updating firmware first, but still the same result. I also tried updating the firmware through the command-line, but that also fails as it just hangs at a certain spot (I forget off the top of my head).
I even bought a 2nd WifiShield as I thought maybe I bricked the first one, but still the same result. I'm really frustrated and at a loss here, so any help is greatly appreciated. This is the exact chip I purchased: https://tinycircuits.com/collections/communication/products/wifi-tinyshield-atwinc1500
Help!!!
sandeepmistry
#1
Aug 11, 2017, 03:22 pm Last Edit: Aug 11, 2017, 03:23 pm by sandeepmistry
Just to confirm, you've followed all the steps in the guide here? https://www.arduino.cc/en/Tutorial/FirmwareUpdater
What board do you have the WiFi101 shield connected to?
Edit: WiFi101 shield has a model A chip on it, and the latest firmware it can run is 19.4.4.
