Topic: DHT11, LCD DISPLAY and Arduino Mega reset (Read 3210 times) previous topic - next topic
kamaxeon
Hi everybody !!
I have a small trouble, and I don't know how to resolve it. I'm getting crazy.
I have a Arduino Mega (using IDE 021) with a DHT11 sensor (temperature and humidity), with a lcd & keypad from dfrobot.
If a run a simple code test, without use the LCD it works without any trouble, and return the values to a Serial.
Code: [Select]
#define SENSORES 52
byte bGlobalErr;
byte dht_dat[4];
int temperatura;
int humedad;
void setup(){
IniciarSensor();
delay(300);
Serial.println("Humidity and temperature\n\n");
delay(700);
void loop(){
 LeerDHT();
 switch (bGlobalErr){
    case 0:
     Serial.print("Current humdity = ");
     Serial.print(temperatura);
     Serial.print(".");
     Serial.print(dht_dat[1], DEC);
     Serial.print("%  ");
     Serial.print("temperature = ");
     Serial.print(humedad);
     Serial.print(".");
     Serial.print(dht_dat[3], DEC);
     Serial.println("C  ");
    case 1:
       Serial.println("Error 1: DHT start condition 1 not met.");
    case 2:
       Serial.println("Error 2: DHT start condition 2 not met.");
    case 3:
       Serial.println("Error 3: DHT checksum error.");
    default:
       Serial.println("Error: Unrecognized code encountered.");
 delay(800);
void IniciarSensor(){
 pinMode(SENSORES,OUTPUT);
 digitalWrite(SENSORES,HIGH);
void LeerDHT(){
bGlobalErr=0;
byte dht_in;
byte i;
digitalWrite(SENSORES,LOW);
delay(18);
delay(5);
delayMicroseconds(40);
pinMode(SENSORES,INPUT);
dht_in=digitalRead(SENSORES);
if(dht_in){
  bGlobalErr=1;
  return;
delayMicroseconds(80);
if(!dht_in){
  bGlobalErr=2;
  return;
for (i=0; i<5; i++)
  dht_dat[i] = LeerDatosDHT();
byte dht_check_sum =
      dht_dat[0]+dht_dat[1]+dht_dat[2]+dht_dat[3];
if(dht_dat[4]!= dht_check_sum)
  {bGlobalErr=3;}
temperatura = dht_dat[0];
humedad = dht_dat[2];
byte LeerDatosDHT(){
 byte i = 0;
 byte resultado=0;
 for(i=0; i< 8; i++){
     while(digitalRead(SENSORES)==LOW);
     delayMicroseconds(30);
     if (digitalRead(SENSORES)==HIGH)
         resultado |=(1<<(7-i));
   while (digitalRead(SENSORES)==HIGH);
 return resultado;
But when I  upload the code to show the values on the LCD display the arduino automatically reset. Any ideas ???
Code: [Select]
#include <LiquidCrystal.h>
#define SENSORES      52
byte celsius[8] = {
     B01110,
     B01010,
     B01110,
     B00000,
     B00000,
     B00000,
     B00000,
     B00000
int temperatura ;
int humedad;
byte bGlobalErr;
byte dht_dat[4];
LiquidCrystal lcd(8, 9, 4, 5, 6, 7);
void LeerDHT(){
bGlobalErr=0;
byte dht_in;
byte i;
delay(23);
if(dht_in){
  bGlobalErr=1;
  return;
if(!dht_in){
  bGlobalErr=2;
  return;
for (i=0; i<5; i++)
byte dht_check_sum = dht_dat[0]+dht_dat[1]+dht_dat[2]+dht_dat[3];
  {bGlobalErr=3;}
Serial.println(temperatura);
Serial.println(humedad);
 byte i = 0;
 byte resultado=0;
     delayMicroseconds(45);
 return resultado;
void MostrarSensores()
           LeerDHT();
           // Temperatura
           lcd.setCursor(4,0);
           // Si es menor de 10 grado pongo un cero delante
           if ( temperatura < 10) {
                 lcd.print(0);
           lcd.print(temperatura);
           // Humedad
           lcd.setCursor(12,0);
           if ( humedad < 10) {
                 lcd.print(0);
           lcd.print(humedad);
           lcd.setCursor(6 ,1);
           lcd.print("test");
//# Setup
     // Iniciamos el sensores
     IniciarSensor();
     delay(1000); // Necesario
     lcd.begin(16,2);
     lcd.createChar(3, celsius);
     lcd.clear();
     lcd.setCursor(0,0);
     lcd.print("T.:     H.:   %");
     lcd.setCursor(6,0);
     lcd.write(3); //
     lcd.setCursor(0,1);
     lcd.print("Modo: ");
 Serial.println("DEBUG:");
 Serial.println("================");
//# LOOP
MostrarSensores();
delay(800);
Thanks a lot
floresta
#1
Nov 19, 2010, 04:28 pm Last Edit: Nov 19, 2010, 04:29 pm by floresta Reason: 1
kamaxeon:
Do you have any prior experience successfully using the LCD with your Mega?
If the answer is yes then do you have any experience successfully using the custom characters?
If the answer is also yes then have you tried temporarily ending your program just before the 'serial.begin()' statement to see if the LCD part is working at that point?
Don
kamaxeon
Don:
Quote
Yes
Quote
Yes, using a ds18b20 (temperature sensor)
Quote
Using this code the arduino doesn't reset
Code: [Select]
#define SENSORES      52
byte celsius[8] = {
     B01110,
     B01010,
     B01110,
     B00000,
     B00000,
     B00000,
     B00000,
     B00000
int temperatura ;
int humedad;
byte bGlobalErr;
byte dht_dat[4];
void LeerDHT(){
bGlobalErr=0;
byte dht_in;
byte i;
delay(23);
if(dht_in){
  bGlobalErr=1;
  return;
if(!dht_in){
  bGlobalErr=2;
  return;
for (i=0; i<5; i++)
  {bGlobalErr=3;}
 byte i = 0;
 byte resultado=0;
 return resultado;
           LeerDHT();
           // Temperatura
           lcd.setCursor(4,0);
                 lcd.print(0);
           // Humedad
                 lcd.print(0);
           lcd.print(humedad);
           lcd.print("test");
//# Setup
     IniciarSensor();
     lcd.begin(16,2);
     lcd.clear();
     lcd.setCursor(0,0);
     lcd.setCursor(6,0);
     lcd.write(3); //
     lcd.setCursor(0,1);
//# LOOP
Any ideas ?
floresta
Quote
Help me out here.  Does the LCD display what it should display?
Don
kamaxeon
Something like  this:
T.: 24º H.: 55%
Modo: test
floresta
#5
Nov 29, 2010, 04:49 am Last Edit: Nov 29, 2010, 04:52 am by floresta Reason: 1
Do you have a question?  Carnac the Magnificent died with Johnny Carson.
