Topic: Atmega2560V, trying to burn bootloaders of MegaCore. (Read 322 times) previous topic - next topic
mudassir9999
Hello,
I am trying to burn MegaCore bootloaders to it, I have setup my custom PCB  with Atmega2560V-8AU and 8Mhz Crystal + Load Caps all assembled on using PCBA process.
I am trying to burn MegaCore bootlaoders to it, I am using Arduino UNO as ISP Programmer. My connections are all correct, It shows different Device Signatures (see below) whenever I hit Burn Bootloaders....
Quote
0x0000ff
0x00003f
0x0000ff
0x00ff00
0x001000
0xff0000
0xfc0000
0x00fe00
This is complete output with different Device Signatures
Quote
Arduino: 1.8.3 (Windows 10), Board: "ATmega2560, Arduino MEGA pinout, 2.7v, Disabled (default), 8 MHz external"
C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avrdude -CC:\Users\mudas\OneDrive\Documents\Arduino\hardware\MegaCore-avr-100-pin\avr/avrdude.conf -v -patmega2560 -cstk500v1 -PCOM4 -b19200 -e -Ulock:w:0x3f:m -Uefuse:w:0xfd:m -Uhfuse:w:0xd6:m -Ulfuse:w:0xf7:m
avrdude: Version 6.3, compiled on Jan 17 2017 at 12:00:53
         Copyright (c) 2007-2014 Joerg Wunsch
         System wide configuration file is "C:\Users\mudas\OneDrive\Documents\Arduino\hardware\MegaCore-avr-100-pin\avr/avrdude.conf"
         Using Port                    : COM4
         Using Programmer              : stk500v1
         Overriding Baud Rate          : 19200
         AVR Part                      : ATmega2560
         Chip Erase delay              : 9000 us
         PAGEL                         : PD7
         BS2                           : PA0
         RESET disposition             : dedicated
         RETRY pulse                   : SCK
         serial program mode           : yes
         parallel program mode         : yes
         Timeout                       : 200
         StabDelay                     : 100
         CmdexeDelay                   : 25
         SyncLoops                     : 32
         ByteDelay                     : 0
         PollIndex                     : 3
         PollValue                     : 0x53
         Memory Detail                 :
                                  Block Poll               Page                       Polled
           Memory Type Mode Delay Size  Indx Paged  Size   Size #Pages MinW  MaxW   ReadBack
           eeprom        65    10     8    0 no       4096    8      0  9000  9000 0x00 0x00
           flash         65    10   256    0 yes    262144  256   1024  4500  4500 0x00 0x00
           lfuse          0     0     0    0 no          1    0      0  9000  9000 0x00 0x00
           hfuse          0     0     0    0 no          1    0      0  9000  9000 0x00 0x00
           efuse          0     0     0    0 no          1    0      0  9000  9000 0x00 0x00
           lock           0     0     0    0 no          1    0      0  9000  9000 0x00 0x00
           calibration    0     0     0    0 no          1    0      0     0     0 0x00 0x00
           signature      0     0     0    0 no          3    0      0     0     0 0x00 0x00
         Programmer Type : STK500
         Description     : Atmel STK500 Version 1.x firmware
         Hardware Version: 2
         Firmware Version: 1.18
         Topcard         : Unknown
         Vtarget         : 0.0 V
         Varef           : 0.0 V
         Oscillator      : Off
         SCK period      : 0.1 us
avrdude: AVR device initialized and ready to accept instructions
Error while burning bootloader.
Reading | ################################################## | 100% 0.02s
avrdude: Device signature = 0x00fe00
avrdude: Expected signature for ATmega2560 is 1E 98 01
         Double check chip, or use -F to override this check.
avrdude done.  Thank you.
option enabled in File -> Preferences.
What should be the problem.??? How to solve this.?
pert
#1
Aug 09, 2017, 10:36 pm Last Edit: Aug 09, 2017, 10:37 pm by pert Reason: Add link to other cross post location
