Topic: (Major headache...!) - 1 line code crashes arduino (Read 1 time) previous topic - next topic
phil755
im making a drawing arduino, the code is messy (amature programmer) but faily simple...
only problem is when i uncomment either a call to;
drawLine(x,y);
random(x,y);
in the drawBoxP(int x, int y, int size, int count) function and upload the sketch the aruino doesnt hold LED high for 5 seconds but crashes Serial (even tho its not used) and forces TX high instead.....????????;
im sure im missing something simples and messy cooding to blame...
any help would be much apreaciated.....
phil
int data[50][50] = { ########### DATA ARRAY (0-255 int) ###############}
int StepUnit = 30;
int w= 38*StepUnit;
int h= 28*StepUnit;
int x1= w/2;
int y1= h;
int a1= sqrt(pow(x1,2)+pow(y1,2));
int b1= sqrt(pow((w-x1),2)+pow(y1,2));
// Stepper motor objects: A is left, B is right
Stepper StepperA(motorStepsA, motorPinA1,motorPinA2, motorPinA3,motorPinA4);
Stepper StepperB(motorStepsB, motorPinB1,motorPinB2, motorPinB3,motorPinB4);
void moveTo(int x2, int y2) {
 // Turn the stepper motors to move the marker from the current point (x1, y1) to (x2, y2)
 // Note: This only moves in a perfectly straight line if
 // the distance is the same in both dimensions; this should be fixed, but it works well
 // a2 and b2 are the final lengths of the left and right strings
 int a2 = sqrt(pow(x2,2)+pow(y2,2));
 int b2 = sqrt(pow((w-x2),2)+pow(y2,2));
 int stepA;
 int stepB;
 if (a2>a1) {
   stepA=1;
 if (a1>a2) {
   stepA=-1;
 if (a2==a1) {
   stepA=0;
 if (b2>b1) {
   stepB=1;
 if (b1>b2) {
   stepB=-1;
 if (b2==b1) {
   stepB=0;
 // Change the length of a1 and b1 until they are equal to the desired length
 while ((a1!=a2) || (b1!=b2)) {
   if (a1!=a2) {
     a1 += stepA;
     StepperA.step(stepA);
   if (b1!=b2) {
     b1 += stepB;
     StepperB.step(-stepB);
 x1 = x2;
 y1=y2;
void drawLine(int x2, int y2)
 /*Serial.print("DL:");
  Serial.print(x1);
  Serial.print(":");
  Serial.print(y1);
  Serial.print("/");
  Serial.print(x2);
  Serial.print(":");
  Serial.println(y2);*/
 int X = x2-x1;
 int Y = y2-y1;
 int topX = x1;
 int topY = y1;
 int L = (int)sqrt(pow(X,2)+pow(Y,2));
 for (int i = 0; i <= L; i++)
   int x = (int)(X * (double)((i+0.0)/L));
   int y = (int)(Y * (double)((i+0.0)/L));
   moveTo(x+topX,y+topY);
void drawBoxP(int dbpsx, int dbpsy, int dbpsize, int dbpcount)
 int dbps = dbpsize/2;
 int dbpminX = dbpsx-dbps;
 int dbpminY = dbpsy-dbps;
 int dbpmaxX = dbpsx + dbps;
 int dbpmaxY = dbpsy + dbps;
//THESE ARE THE FUNCTION CALLS THAT FORCE CRASH
 // drawLine(dbpminX,dbpminY);
 //  drawLine(dbpminX,dbpmaxY);
 // drawLine(dbpmaxX,dbpmaxY);
 // drawLine(dbpmaxX,dbpminY);
 for (int dbpi = 0; dbpi<dbpcount;dbpi++)
   // blink(20);
   //    int dbptx = random(dbpminX,dbpmaxX);
   //int dbpty = random(dbpminY,dbpmaxY);
   //drawLine(dbptx,dbpty);
int blink(int time)
 digitalWrite(13,HIGH);
 delay(time);
 digitalWrite(13,LOW);
 StepperA.setSpeed(4);
 StepperB.setSpeed(4);
 // Serial.begin(9600);
 delay(2000);
 randomSeed(analogRead(0));
 pinMode(13,OUTPUT);
 delay(5000);
 int rows = 50;
 int cols = 50;
 int size = 10;
 int count=0;
 int sX = x1-((cols*size)/2);
 int sY = y1+20;
 int nX = sX;
 int nY = sY;
 int xX = sX+(cols*size);
 int xY = sY+(rows*size);
 drawLine(nX,nY);
 drawLine(nX,xY);
 drawLine(xX,xY);
 drawLine(xX,nY);
 drawLine(nX,nY);
 for (int yi = 0; yi < rows; yi++)
   for (int xi = 0; xi < cols; xi++)
     count++;
     int px = sX+(size*xi);
     int py = sY+(size*yi);
     int i = (data[yi][xi]/5.0);
     drawBoxP(px,py,size,i);
Coding Badly
Please modify your post and put code tags (
  • button) around the code.
    Which board are you using?
westfw
Quote
int data[50][50]
This is 5000 bytes of data, which is more than there is space for data on the Arduino (unless you have a MEGA with 1280 or 2560 CPU.)  Neither the Arduino IDE nor the CPU itself detects this sort of error, causing all sorts of strange crash-like behavior.
PaulS
While you are fixing the oversize array, take a look at this statement:
Code: [Select]
and this page:
http://arduino.cc/en/Reference/Pow
The pow() function expects two floats, not two ints. So, a cast is performed to convert the ints to floats, so that pow can effectively do this for you: X * X.
Instead of the casts and the overhead of a relatively inefficient algorithm, just multiply the number by itself.
One last observation. Executable code must be in a function.
Code: [Select]
int w= 38*StepUnit;
int h= 28*StepUnit;
int x1= w/2;
int y1= h;
None of this code will do what you think it will.
