Topic: Analog Pin State (Read 718 times) previous topic - next topic
fujtech
ON a Mega2560, can the analog pin in (A0) be used as an output to go from zero (nothing) to low? Or does it have to go from either high to low? Can this pin be configure to rest at nothing until trigger to go from nothing to low?
ballscrewbob
This is the 101 board section.
However a pin can be defined and set as high till a low signal or low till a high signal.
Or even edge detection of a high or low signal.
Your choice.
It may not be the answer you were looking for but its the one I am giving based on either experience, educated guess, google or the fact that you gave nothing to go with in the first place so I used my wonky crystal ball.
