Topic: Clear Screen on Serial Monitor. (Read 104664 times) previous topic - next topic
denadai
Hiho All!
I'm a brazilian guy and my english isn't pretty good. So if anyone can help me i will thankful a lot!
My problem is:
How i can clear the screen on serial monitor?
like we does on #C: "system("cls");" or "clrscr;"
I've tryed "Serial.Clear", but i don't get any results, only a big red message, on my board.
Sorry about the english.
Thx.
PaulS
Why do you want to clear the screen? It's a debugging window.
Closing it, and reopening it will clear it. It will also restart the Arduino.
You could also write your own serial window application. That's what I did. I have a Find field, to find data in the window. I can add additional features are they occur to me.
retrolefty
#2
Nov 24, 2009, 04:58 am Last Edit: Nov 24, 2009, 04:59 am by retrolefty Reason: 1
Or better yet, instead of using the IDE serial monitor, use a real serial terminal program. If you are using Windows I highly recommend Brey terminal, it has tons of features, it's free, it's a standalone exe file, so no installation required. Along with tons of over commands, it has a clear receive window, clear send window.
http://sites.google.com/site/braypp/terminal
Lefty
denadai
Oh, thank everybody!
i want this code, because i'm reading the deegres of a servo and sending this data by serial, and debugging in serial monitor.
But when the debug gets a lot of lines, the serial comunication with arduino stop, and i need to restart the sketch!
I only want, try to clear the serial monitor screen to stop this error...
But i going to try brayapp like lefty said.
sorry about the english, one more time.   :-/
thx everyone again!
Osgeld
#4
Nov 24, 2009, 05:18 pm Last Edit: Nov 24, 2009, 05:18 pm by Osgeld Reason: 1
if your using a normal terminal program i believe the clear charter is (ascii code)12 or 13
http://arduino.cc/forum/index.php?action=unread;boards=2,3,4,5,67,6,7,8,9,10,11,66,12,13,15,14,16,17,18,19,20,21,22,23,24,25,26,27,28,29,30,86,87,89,1;ALL
xp19375
To clear the screen in a terminal emulator, a standard clear screen command is (esc)[2J, so your code would look like this:
 Serial.print(27,BYTE);   //Print "esc"
 Serial.print("[2J");
This will not work in the Arduino Serial Monitor, so you need a terminal emulator.  Since it doesn't use a serial port, you also need a serial port emulator.  DOSBox and Procomm will work.  Both are free.
Download and install DOSBox (I am using v 0.74), then modify the config file under [serial] and set serial1=directserial realport:COM1 (or whatever COM port you are using).
In Procomm, set the appropriate baud rate, using alt-p, and no parity, 8 data bits, and 1 stop bit.
Hope this helps.
retrolefty
Quote
Hope this helps.
It would have a year ago or so.  ;D
