Loading...
Pages: [1]   Go Down
Author Topic: Problem with the code for DS18S20 sensor.  (Read 403 times)
0
Offline Offline
Newbie
Arduino rocks
View Profile
Hello
I´ve got a problem with a DS18S20 sensor. I´ve used a code from an already existing project but it were built for an DS18B20 sensor.
When I run the code it works but I cant get the right value from the sensor. I run the sensor in a room (21 C degrees) but the sensor says 26 C degrees. Please someone help me. I think I must have missed something in the code that only works for a DS18B20. Hope you understand my bad english smiley
#define TEMP_PIN 5 //
void OneWireReset(int Pin);
void OneWireOutByte(int Pin, byte d);
byte OneWireInByte(int Pin);
    digitalWrite(TEMP_PIN, LOW);
    pinMode(TEMP_PIN, INPUT);      // sets the digital pin as input (logic 1)
    delay(100);
    Serial.print("Temperatur:\n");
void loop(){
  int HighByte, LowByte, TReading, SignBit, Tc_100, Whole, Fract;
  OneWireReset(TEMP_PIN);
  OneWireOutByte(TEMP_PIN, 0xcc);
  OneWireOutByte(TEMP_PIN, 0x44); // perform temperature conversion, strong pullup for one sec
  OneWireOutByte(TEMP_PIN, 0xbe);
  LowByte = OneWireInByte(TEMP_PIN);
  HighByte = OneWireInByte(TEMP_PIN);
  TReading = (HighByte << smiley-cool + LowByte;
  SignBit = TReading & 0x8000;  // test most sig bit
  if (SignBit) // negative
    TReading = (TReading ^ 0xffff) + 1; // 2's comp
  Tc_100 = ((TReading*100/2));    // multiply by 0.5
  Whole = Tc_100 / 100;  // separate off the whole and fractional portions
  Fract = Tc_100 % 100;
  if (SignBit) // If its negative
     Serial.print("-");
  Serial.print(Whole);
  Serial.print(".");
  if (Fract < 10)
     Serial.print("0");
  Serial.print(Fract);
      Serial.print("\n");
  delay(5000);
void OneWireReset(int Pin) // reset.  Should improve to act as a presence pulse
     digitalWrite(Pin, LOW);
     pinMode(Pin, OUTPUT); // bring low for 500 us
     delayMicroseconds(500);
     pinMode(Pin, INPUT);
void OneWireOutByte(int Pin, byte d) // output byte d (least sig bit first).
   byte n;
   for(n=8; n!=0; n--)
      if ((d & 0x01) == 1)  // test least sig bit
         delayMicroseconds(5);
         delayMicroseconds(60);
      d=d>>1; // now the next bit is in the least sig bit position.
byte OneWireInByte(int Pin) // read byte, least sig byte first
    byte d, n, b;
    for (n=0; n<8; n++)
        b = digitalRead(Pin);
        delayMicroseconds(50);
        d = (d >> 1) | (b<<7); // shift d to right and insert b in most sig bit position
    return(d);
//Will_jr
Logged
Netherlands
Offline Offline
Tesla Member
In theory there is no difference between theory and practice, however in practice there are many...
View Profile
Temperature can fluctuate locally although 5 degrees is quite much. Does the IC feel hot? Or is it near a hot powersupply, laptopFan , ...?
There may be a problem with the precision (number of bits) as the 18S20 supports only 9 bits and the 18B20 supports 9..12 bit. Check the datasheet to see if the formulas and bit positions are identical. As far as I recall they are, and the code looks OK.
The Dallas Temperature Library support both IC's. Install it and you would have an alternative reference. - http://milesburton.com/index.php/Dallas_Temperature_Control_Library
Finally you can make displaying the Temp easier with a float var
float Temperature = TReading * 0.5;
Serial.println(Temperature, 1); // print with 1 bit precision
give it a try
Logged
Rob Tillaart
Nederlandse sectie - http://arduino.cc/forum/index.php/board,77.0.html -
Pages: [1]   Go Up
Print
Jump to:
