Topic: LCD displaying weird Symbols after Interrupt (Read 7612 times) previous topic - next topic
Newman180
Jan 02, 2011, 04:51 am Last Edit: Jan 02, 2011, 04:53 am by Newman180 Reason: 1
I'm trying to use an LCD to print values which an interrupt calculates, but after the first interrupt, the LCD displays weird symbols and goes hay wire. It does work for the first interrupt though.
Its very odd. Any suggestions?
Here's some example code:
Quote
 #include <LiquidCrystal.h>
 unsigned int revPeriod; // Rotation Time
 volatile unsigned long prevTDCtime; // Previous time Hall Sensor Picked up
 volatile unsigned long TDCtime; // Current TDC Time
 volatile unsigned long nextTDC; // Predicted next TDC Time
 unsigned int rpm;
 unsigned int crankAngle; // Crankshaft Angle out of 360 degrees
 boolean TDCinterrupt1 = false; //
 const int V17Pin = 8; // Valves 1 and 7 assigned to Pin 3  Intake
 const int V35Pin = 9; // Valves 3 and 5 assigned to Pin 4  Intake
 const int V28Pin = 10; // Valves 2 and 8 assigned to Pin 5  Exhaust
 const int V46Pin = 11; // Valves 4 and 6 assigned to Pin 6  Exhaust
 LiquidCrystal lcd (12,11,6,5,4,3);
    // Communicate to Serial Port
  Serial.begin (9600);
  lcd.begin(16,2);
   pinMode (V17Pin, OUTPUT); // Valve 1&7 as Output
   pinMode (V35Pin, OUTPUT); // Valve 3&5 as Output
   pinMode (V28Pin, OUTPUT); // Valve 2&8 as Output
   pinMode (V46Pin, OUTPUT); // Valve 4&6 as Output
   nextTDC = 1;
   lcd.setCursor(4,0);
  lcd.print("*READY*");
   attachInterrupt(0,TDCinterrupt, RISING); // Interrupt 0 is Pin 2 Hall Effect Sensor
 void TDCinterrupt()
  TDCinterrupt1 = true;
  prevTDCtime = TDCtime;  // save last TDC
  TDCtime = micros();  // save THIS TDC
  revPeriod = TDCtime - prevTDCtime;  // calculate revolution period
  if (prevTDCtime > TDCtime)  {
     revPeriod = TDCtime - prevTDCtime + 2147483648;  // correct for micros() overflow every 71 minutes
  else  {
     revPeriod = TDCtime - prevTDCtime;  // no correction needed
  nextTDC = TDCtime + revPeriod;
  rpm = 60000000/revPeriod;
void loop ()
  if ( TDCinterrupt1){
  cli();
  crankAngle = map(micros(), TDCtime, nextTDC, 0, 360);  // Change time into degrees
  sei();
  crankAngle = constrain(crankAngle,  0, 360); // Limit crankshaft vales from 0 to 360
if ( TDCtime == 0){
    Serial.print ("** Device Immobile **");
    lcd.setCursor(0,0);
    lcd.print ("ON");
      lcd.setCursor(1,1);
      lcd.print(rpm);
The rpm displays clearly for the first ISR, but after that it goes crazy.
Another example code would be adding this into the previous code:
Code: [Select]
void loop ()
   lcd.print(TDCtime);
 cli();
robtillaart
#1
Jan 02, 2011, 08:26 am Last Edit: Jan 02, 2011, 08:50 am by robtillaart Reason: 1
First thing I noticed was a var and the LCD sharing pin 11
Code: [Select]
const int V46Pin = [glow]11[/glow]; // Valves 4 and 6 assigned to Pin 6  Exhaust
LiquidCrystal lcd (12,[glow]11[/glow],6,5,4,3);
Furthermore:
Code: [Select]
 [glow]revPeriod = TDCtime - prevTDCtime;[/glow]  // calculate revolution period
 else  {
    [glow]revPeriod = TDCtime - prevTDCtime;[/glow]  // no correction needed
- The else part is done double, can be removed
Code: [Select]
rpm = 60000000[glow]L[/glow]/revPeriod;
You need a L to indicate 60M is a long.
Furthermore if revperiod is zero ==> divide by zero.
Does all this code need to be calculated in the ISR or can it be moved to loop after the  if ( TDCinterrupt1){  to keep the ISR as short as possible.
Code: [Select]
void TDCinterrupt()
 // rest can be done outside the ISR???
the map() function expects a signed long as parameters. micros() is unsigned long so every 35 minutes it might be interpreted as a negative number?
TDCinterrupt1 is set to true but never to false again? Or is this not the complete code?
Rob Tillaart
Nederlandse sectie - http://arduino.cc/forum/index.php/board,77.0.html -
(Please do not PM for private consultancy)
Newman180
Quote
Good Eye. With nothing but the LCD plugged into the arduino, I didnt even notice  :o
Quote
agree
Quote
Your right, I need to use a multiplier like the playground ReadingRPM
I will also add the L
Quote
Is there an unsigned map function?
Quote
I did not post the whole code, but if you need me too, I will. Basically this code is controlling solenoids to run an engine. The timing for the intake and exhaust has to be as good as possible, so I think we concluded in the other thread that putting it in the loop, you had the potential of missing an interrupt? I don't know, give me your opinion.
Quote
As mentioned its not the complete code. I would like to have tdcinterrupt1 go to false again when the engine is at a standstill. I was thinking I could say something about when the crank angle is at the same value for so many seconds, set TDCinterrupt1 = FALSE.
I'm not the most proficient programmer, so maybe you can help me with that.
Thanks for your time/help.
kitesurfer
Change those other variables to volatile as well.
robtillaart
#4
Jan 02, 2011, 07:38 pm Last Edit: Jan 02, 2011, 07:40 pm by robtillaart Reason: 1
Quote
something like this?
Code: [Select]
unsigned long map(unsigned long x, unsigned long in_min, unsigned long in_max, unsigned long out_min, unsigned long out_max)
 return (x - in_min) * (out_max - out_min) / (in_max - in_min) + out_min;
Quote
Could be easier to debug than mindreading ;)
Quote
It is best practice too keep ISR()'s as short as possible - but not shorter - to prevent reentry. Reentry is that the ISR is called again before the last call is finished. You can imagine there might be quite some interference :) Also important is to keep your data consistent, if your main loop is interrupted anywhere and the ISR changes some var's calculations in the main loop must be correct. Use cli() and sei() to disable/enable interrupts around the critical calculations in loop() however that may cause missing interrupts, so these should also be used with care.
Rob Tillaart
Newman180
Quote
Could be easier to debug than mindreading Wink
I'll spare you, at the moment, and give you the stripped down version of the code (no timing control). I made a few changes based upon your previous suggestions...
Quote
 volatile byte rpmcount;
 unsigned int rpm;
 const int V17Pin = 9; // Valves 1 and 7 assigned to Pin 3  Intake
 const int V35Pin = 11; // Valves 3 and 5 assigned to Pin 4  Intake
 const int V46Pin = 12; // Valves 4 and 6 assigned to Pin 6  Exhaust
 LiquidCrystal lcd (8,7,6,5,4,3);
   lcd.begin(16,2);
   nextTDC = 1;
   lcd.setCursor(4,0);
 void TDCinterrupt()
  rpm = 60000000L/revPeriod;
void loop ()
  cli();
  sei();
if ( crankAngle >= 1 && crankAngle <= 179) // If the crankshaft is inbetween 1 to 179 degrees of revolution then...
     digitalWrite(V17Pin, HIGH); // Fire Valve 1 and 7 (Intake)
     digitalWrite(V46Pin, HIGH); // Fire Valve 4 and 6 (Exhaust)
     Serial.println("Intake (1,7) Exhaust (4,6) Fired 100%"); // Print Status and Percent of Valve Open
     lcd.setCursor(12,1);
     lcd.print ("+");
     lcd.setCursor(13,1);
     lcd.print ("+");
 else {
  digitalWrite(V17Pin, LOW); // Don't Fire Valve 1 and 7 (Intake)
  digitalWrite(V46Pin, LOW); // Don't Fire Valve 4 and 6 (Exhaust)
     lcd.print ("-");
     lcd.print ("-");
  if ( crankAngle >= 181 && crankAngle <= 359) // If the crankshaft is inbetween 181 to 359 degrees of revolution then...
     digitalWrite(V35Pin, HIGH); // Fire Valve 3 and 5 (Intake)
     digitalWrite(V28Pin, HIGH); // Fire Valve 2 and 8 (Exhaust)
     lcd.setCursor(14,1);
     lcd.print ("+");
     lcd.setCursor(15,1);
     lcd.print ("+");
     Serial.println("Intake (3,5) Exhaust (2,8) Fired 100%"); // Print Status and Percent of Valve Open
else {
  digitalWrite(V35Pin, LOW); // Don't  Fire Valve 3 and 5 (Intake)
   digitalWrite(V28Pin, LOW); // Don't Fire Valve 2 and 8 (Exhaust)
    lcd.print ("-");
    lcd.print ("-");
      lcd.setCursor(1,1);
      lcd.print(rpm,DEC);
robtillaart
First it is good practice to initialize your variables to a known value. The compiler will often make them zero / 0 but not al the times.
rpm is an int while this calculation is long so there is possible loss of precission.
Not patched the map function to unsigned long as I proposed...
    lcd.print ("+");
Your lcd is 16 x 2, by setting the cursor at 15, 1 it is at the end of the line and you are writing outside the LCD's screen, maybe into memory or registers or something.  Count of the positions goes from 0..15 not from 0..16.
This latter could be the cause of the weird chars.
Rob Tillaart
Newman180
Quote
This is not the most important calculation in the code, but what could I do to prevent this loss of precision?
Quote
I forgot to add it. Would it look like this, since they are all unsigned longs ? Can you explain what the return is doing?
Code: [Select]
crankAngle = unsigned long map (micros(), TDCtime, nextTDC, 0, 360);
 return (micros - TDCtime) * (360 - 0) / (nextTDC - TDCtime) + 0;
Quote
   lcd.print ("+");
I already caught this and fixed it, after I posted the code.  ;D
But the weird characters were caused by the double pin assignment earlier, and is fixed now.
Thanks for the help thus far rob. When we go over these few crinkles, I'll give you the "complete" code to review, if you don't mind  ;)
robtillaart
#8
Jan 04, 2011, 12:34 pm Last Edit: Jan 04, 2011, 12:39 pm by robtillaart Reason: 1
Good to hear things work, if you have finalized your code please post it, also for people in the future who have similar issues.
Quote
make rpm a long too.
Add this function definition to your code (at the end is ok)
Code: [Select]
unsigned long ULmap(unsigned long x, unsigned long in_min, unsigned long in_max, unsigned long out_min, unsigned long out_max)
And change the map call in your exisiting code
Code: [Select]
crankAngle = ULmap (micros(), TDCtime, nextTDC, 0, 360);
Rob Tillaart
Newman180
#9
Jan 04, 2011, 03:07 pm Last Edit: Jan 04, 2011, 03:15 pm by Newman180 Reason: 1
Quote
Great! It will probably take two posts. I have two questions regarding the final code. I have recently learned about calling to functions outside of the loop. I set up my timing and start control outside of the loop to try to minimize clutter, and allow the loop to run faster. Is this in fact the better way?
Also, with start mode, I use delays between each valve, but I don't think that will work right. The plan is that once the engine starts spinning, the interrupt kicks in and invalidates the start code. If the interrupt happens during a delay, I'm doomed. I was thinking of using a "blink without delay" but I'm not sure if I can call to micros/millis if the interrupt is as well.  Your opinion?
Thanks
FYI. The ULmap as displayed below does not compile correctly. It thinks the UL is part of the name, and states that ULmap has not been declared.
Quote
//--- NEWMAN180  1/4/11
 volatile unsigned int revPeriod; // Rotation Time
 volatile unsigned long rpm;
 volatile unsigned int crankAngle; // Crankshaft Angle out of 360 degrees
 unsigned int a; // first crank angle of 180
 unsigned int a1; // second crank angle of 180
 unsigned int b; // first crank angle of 360
 unsigned int b1; // second crank angle of 360
 const int timingPin = 14;
 const int maintbuttonPin = 15;
 const int pushstartPin = 16;
 int pushstartState = 0;
 int maintbuttonState = 0;
 int buttonstate = 0;
 int buttonpushcounter = 0;
 int lastbuttonstate = 0;
 int start;
 int timing;
 int maint;
   lcd.begin(16,2);
   pinMode (pushstartPin, INPUT);
   pinMode (timingPin, INPUT);
   pinMode (maintbuttonPin, INPUT);
   rpm = 0;
   nextTDC = 1;
   lcd.setCursor(0,0);
   lcd.print("ON");
   digitalWrite(2,HIGH);
   delay(3500);
 void TDCinterrupt()
void loop ()
  cli();
  crankAngle = ULmap(micros(), TDCtime, nextTDC, 0, 360);  // Change time into degrees
  sei();
//----------------------------------  Button Counter Control
buttonstate = digitalRead(timingPin);
   if (buttonstate != lastbuttonstate)
       if (buttonstate == HIGH) {
       buttonpushcounter++; // Update Button Counter
lastbuttonstate = buttonstate;
if( buttonpushcounter > 9){
  buttonpushcounter = 0;}
//--------------------------------------- Button Timing Control
 timing = timingcontrol();
 timing;
//--------------------------------  Timing Center
if ( crankAngle >= a && crankAngle <= a1) // If the crankshaft is inbetween 1 to 179 degrees of revolution then...
     lcd.print ("+");
     lcd.print ("+");
 else {
     lcd.print (" ");
     lcd.print (" ");
  if ( crankAngle >= b && crankAngle <= b1) // If the crankshaft is inbetween 181 to 359 degrees of revolution then...
     lcd.print ("+");
     lcd.print ("+");
else {
    lcd.print (" ");
    lcd.print (" ");
Newman180
#10
Jan 04, 2011, 03:09 pm Last Edit: Jan 04, 2011, 03:11 pm by Newman180 Reason: 1
Quote
//------------------------------- RPM Display
      lcd.setCursor(1,1);
      lcd.print(rpm,DEC);
//------------------------------- START MODE
  start = startmode();
  start;
//--------------------------------Maitenance Mode
maint = maintmode();
maint;
int startmode (){
  if (TDCtime == 0){
  pushstartState = digitalRead(pushstartPin);
    if (pushstartState == HIGH){
  delay(3000);
 Serial.print ("** Start MODE **"); // Start Mode, Open valves 2.5 Seconds, Close 15, Open all intake and exhaust. Open and close exhaust .1 second
           lcd.clear();
           lcd.setCursor(3,0);
           lcd.print ("Start Mode");
           digitalWrite( V17Pin, HIGH);
           digitalWrite( V35Pin, HIGH);
           digitalWrite( V28Pin, HIGH);
           digitalWrite( V46Pin, HIGH);
           lcd.setCursor(0,1);
           delay(3500);
           digitalWrite( V17Pin, LOW);
           digitalWrite( V35Pin, LOW);
           digitalWrite( V28Pin, LOW);
           digitalWrite( V46Pin, LOW);
           delay(15000);
           lcd.clear();
           lcd.print("Starting");
           delay(100);
           delay(100);
           delay(100);
           delay(100);
           delay(100);
           delay(100);
           delay(100);
           delay(100);
           delay(100);
           delay(100);
           delay(100);
           delay(100);
           delay(100);
           delay(100);
           delay(100);
           delay(100);
           delay(100);
           delay(100);
           delay(100);
           delay(100);
           delay(100);
           delay(100);
           delay(100);
           delay(100);
           delay(100);
           delay(100);
           delay(100);
           delay(100);
Newman180
#11
Jan 04, 2011, 03:10 pm Last Edit: Jan 04, 2011, 03:12 pm by Newman180 Reason: 1
Quote
           else{
    lcd.setCursor(0,0);
    lcd.print("START *KEY*");
 int timingcontrol(){
  if (buttonpushcounter == 0){
    a = 1;
    a1 = 179;
    b = 181;
    b1 = 359;
    lcd.setCursor(12,0);
    lcd.print("100%");}
 if (buttonpushcounter == 1){
    a = 1;
    a1 = 162;
    b = 181;
    b1 = 342;
    lcd.print(" 90%");
 if (buttonpushcounter == 2){
    a = 1;
    a1 = 144;
    b = 181;
    b1 = 324;
    lcd.print(" 80%");
 if (buttonpushcounter == 3){
    a = 1;
    a1 = 126;
    b = 181;
    b1 = 306;
    lcd.print(" 70%");
 if (buttonpushcounter == 4){
    a = 1;
    a1 = 108;
    b = 181;
    b1 = 288;
    lcd.print(" 60%");
 if (buttonpushcounter == 5){
    a = 1;
    a1 = 90;
    b = 181;
    b1 = 270;
    lcd.print(" 50%");
 if (buttonpushcounter == 6){
    a = 1;
    a1 = 72;
    b = 181;
    b1 = 252;
    lcd.print(" 40%");
 if (buttonpushcounter == 7){
    a = 1;
    a1 = 54;
    b = 181;
    b1 = 234;
    lcd.print(" 30%");
 if (buttonpushcounter == 8){
    a = 1;
    a1 = 36;
    b = 181;
    b1 = 216;
    lcd.print(" 20%");
 if (buttonpushcounter == 9){
    a = 1;
    a1 = 18;
    b = 181;
    b1 = 198;
    lcd.print(" 10%");
 int maintmode() {
    maintbuttonState = digitalRead(maintbuttonPin);
   if (maintbuttonState == HIGH){
     cli();
     TDCtime = 0;
     nextTDC = 0;
     prevTDCtime = 0;
     lcd.clear();
     lcd.print("Maintenance MODE");
     digitalWrite(V28Pin,HIGH);
     digitalWrite(V46Pin,HIGH);
     delay(60000);
robtillaart
wow
ULmap will not work as it is defined inside the loop I guess (I don't have the complete overview of your code yet)
Furthermore you must spend some time learning about array's - http://www.arduino.cc/en/Reference/Array - and functions - http://www.arduino.cc/en/Reference/FunctionDeclaration.
If you have mastered these two basic techniques you can cleanup your code quite a lot.
Also important to learn is to use proper identation as that makes code better readable.
Rob Tillaart
robtillaart
Snippet by snippet
Code: [Select]
int maintmode()
    cli();     [glow]// where is the sei()[/glow]
    TDCtime = 0;
    nextTDC = 0;
    prevTDCtime = 0;
    lcd.clear();
    delay(60000);
Rob Tillaart
robtillaart
This is the code of timingcontrol with the use of array's
Code: [Select]
int timingcontrol()
 a = 1;
 b = 181;
 int a1array[10] = { 179, 162, 144, 126, 108, 90, 72, 54, 36, 18 };
 int b1array[10] = { 359, 342, 324, 306, 288, 270, 252, 234, 216, 198 };
 a1 = a1array[buttonpushcounter];
 b1 = b1array[buttonpushcounter];
 lcd.print(100-10*buttonpushcounter);
 lcd.print("%");
In fact as all values are linear (almost) this can be optimized to
Code: [Select]
int timingcontrol()
 a = 1;
 b = 181;
 a1 = 180 - 18 * buttonpushcounter;
 if (buttonpushcounter ==0) a1 = a1 -1;  // makes 179
 b1 = a1 + 180;
 lcd.print("%");
Rob Tillaart
