Topic: LCD displaying weird Symbols after Interrupt (Read 7761 times) previous topic - next topic
robtillaart
loop with some proper indentation, and a bit compacting
Code: [Select]
void loop ()
 if ( TDCinterrupt1)
   cli();
   crankAngle = ULmap(micros(), TDCtime, nextTDC, 0, 360);  // Change time into degrees
   sei();
   crankAngle = constrain(crankAngle,  0, 360); // Limit crankshaft vales from 0 to 360
//----------------------------------  Button Counter Control
buttonstate = digitalRead(timingPin);
 // Update Button Counter
 if ((buttonstate != lastbuttonstate) && (buttonstate == HIGH)) buttonpushcounter++;
 lastbuttonstate = buttonstate;
 if( buttonpushcounter > 9) buttonpushcounter = 0;
//--------------------------------------- Button Timing Control
 timing = timingcontrol();
 // timing; ?????
//--------------------------------  Timing Center
// If the crankshaft is inbetween 1 to 179 degrees of revolution then...
 if ( crankAngle >= a && crankAngle <= a1)
   digitalWrite(V17Pin, HIGH); // Fire Valve 1 and 7 (Intake)
   digitalWrite(V46Pin, HIGH); // Fire Valve 4 and 6 (Exhaust)
   Serial.println("Intake (1,7) Exhaust (4,6) Fired 100%"); // Print Status and Percent of Valve Open
   lcd.setCursor(12,1);
   lcd.print ("++");
   digitalWrite(V17Pin, LOW); // Don't Fire Valve 1 and 7 (Intake)
   digitalWrite(V46Pin, LOW); // Don't Fire Valve 4 and 6 (Exhaust)
    lcd.print ("  ");
 // If the crankshaft is inbetween 181 to 359 degrees of revolution then...
 if ( crankAngle >= b && crankAngle <= b1)
    digitalWrite(V35Pin, HIGH); // Fire Valve 3 and 5 (Intake)
    digitalWrite(V28Pin, HIGH); // Fire Valve 2 and 8 (Exhaust)
    lcd.setCursor(14,1);
    lcd.print ("++");
    Serial.println("Intake (3,5) Exhaust (2,8) Fired 100%"); // Print Status and Percent of Valve Open
   digitalWrite(V35Pin, LOW); // Don't  Fire Valve 3 and 5 (Intake)
   digitalWrite(V28Pin, LOW); // Don't Fire Valve 2 and 8 (Exhaust)
   lcd.print ("  ");
//------------------------------- RPM Display
 lcd.setCursor(1,1);
 lcd.print(rpm,DEC);
//------------------------------- START MODE
 start = startmode();
 // start;
//--------------------------------Maitenance Mode
 maint = maintmode();
 // maint;
Code: [Select]
unsigned long ULmap(unsigned long x, unsigned long in_min, unsigned long in_max, unsigned long out_min, unsigned long out_max)
 return (x - in_min) * (out_max - out_min) / (in_max - in_min) + out_min;
Rob Tillaart
Nederlandse sectie - http://arduino.cc/forum/index.php/board,77.0.html -
(Please do not PM for private consultancy)
Newman180
#16
Jan 05, 2011, 02:14 am Last Edit: Jan 05, 2011, 02:18 am by Newman180 Reason: 1
Quote
Furthermore you must spend some time learning about array's - http://www.arduino.cc/en/Reference/Array - and functions - http://www.arduino.cc/en/Reference/FunctionDeclaration.
If you have mastered these two basic techniques you can cleanup your code quite a lot.
Also important to learn is to use proper identation as that makes code better readable.
I've been trying. I've learned all of this with no background or class's in programming, so my brain isn't exactly wired to think in "code". I am a mechanical engineer major, who assumed this was easier then it actually is  ::)
I was searching for a function like array, but didn't know how to find that actual definition.
Quote
cli();     // where is the sei()
With "maitenance mode", I won't be needing to activate the interrupt. It's mainly something to allow me to turn the engine over by hand. If no valves we open, it be impossible. I also bought a switch, so that delay will no longer be there.
Quote
In fact as all values are linear (almost) this can be optimized to
Code:
int timingcontrol()
 a = 1;
 b = 181;
 a1 = 180 - 18 * buttonpushcounter;
 if (buttonpushcounter ==0) a1 = a1 -1;  // makes 179
 b1 = a1 + 180;
 lcd.setCursor(12,0);
 lcd.print(100-10*buttonpushcounter);
 lcd.print("%");
This is awesome. Looks like it would work perfectly. If only I knew about setting up these functions.
Quote
Great, thank you. I will post an updated version of mine with this included after this post.
Quote
// timing; ?????
Why the question marks?
Quote
// start;
why do you have // in front of all the functions I'm calling? The // makes it so arduino can't see that.
Newman180
I've attempted to clean the code further as well as label everything more clearly.
I got rid of the ULmap at the moment as it still won't compile.
I also attempted to use a fucntion in start mode to get rid of all the clutter. I don't know if I implemented it correctly. Please let me know. Thanks
Code: [Select]
//--- NEWMAN180  1/4/11
#include <LiquidCrystal.h>
volatile unsigned int revPeriod; // Rotation Time
volatile unsigned long prevTDCtime; // Previous time Hall Sensor Picked up
volatile unsigned long TDCtime; // Current TDC Time
volatile unsigned long nextTDC; // Predicted next TDC Time
volatile unsigned long rpm; // Used to calculate RPM
volatile unsigned int crankAngle; // Crankshaft Angle out of 360 degrees
unsigned int a; // first crank angle of 180
unsigned int a1; // second crank angle of 180
unsigned int b; // first crank angle of 360
unsigned int b1; // second crank angle of 360
boolean TDCinterrupt1 = false; // States very first interrupt is ignored
const int timingPin = 14; // Timing Button Assignment
const int maintbuttonPin = 15; // Maint Button Assignment
const int pushstartPin = 16; // Push Start Button Assignment
int pushstartState = 0; // Push Start Button State
int maintbuttonState = 0; // Maint Button State
int buttonstate = 0; // Used to count button pushes for Timing
int buttonpushcounter = 0;
int lastbuttonstate = 0;
int start; // Used when declaring Start Mode Function
int timing; // Used when declaring Timing Mode Function
int maint; // Used when declaring Maint Mode Function
const int V17Pin = 9; // Valves 1 and 7 assigned to Pin 3  Intake
const int V35Pin = 11; // Valves 3 and 5 assigned to Pin 4  Intake
const int V28Pin = 10; // Valves 2 and 8 assigned to Pin 5  Exhaust
const int V46Pin = 12; // Valves 4 and 6 assigned to Pin 6  Exhaust
LiquidCrystal lcd (8,7,6,5,4,3);
   // Communicate to Serial Port
  Serial.begin (9600);
  lcd.begin(16,2);
  pinMode (V17Pin, OUTPUT); // Valve 1&7 as Output
  pinMode (V35Pin, OUTPUT); // Valve 3&5 as Output
  pinMode (V28Pin, OUTPUT); // Valve 2&8 as Output
  pinMode (V46Pin, OUTPUT); // Valve 4&6 as Output
  pinMode (pushstartPin, INPUT); // Push Start Button Input
  pinMode (timingPin, INPUT); // Timing Button Input
  pinMode (maintbuttonPin, INPUT); // Maint Button Input
  rpm = 0;
  nextTDC = 1;
  lcd.setCursor(0,0);
  lcd.print("ON");
  attachInterrupt(0,TDCinterrupt, RISING); // Interrupt 0 is Pin 2 Hall Effect Sensor
  digitalWrite(2,HIGH);
  delay(3500);
void TDCinterrupt()
 TDCinterrupt1 = true;  // First interrupt has passed
 prevTDCtime = TDCtime;  // save last TDC
 TDCtime = micros();  // save THIS TDC
 revPeriod = TDCtime - prevTDCtime;  // calculate revolution period
 if (prevTDCtime > TDCtime)  {
 revPeriod = TDCtime - prevTDCtime + 2147483648;}  // correct for micros() overflow every 71 minutes
 nextTDC = TDCtime + revPeriod;
 rpm = 60000000L/revPeriod; // Calculate RPM divide rotation period by the difference of micros to minute
void loop ()
 if ( TDCinterrupt1)
   cli // Disable Interrupt
   crankAngle = map(micros(), TDCtime, nextTDC, 0, 360);  // Change time into degrees
   sei(); // Enable Interrupt
 if ((buttonstate != lastbuttonstate) && (buttonstate == HIGH)){ buttonpushcounter++;} // If the buttonstate is greater than last, and it is high, increase counter
 if( buttonpushcounter > 9) {buttonpushcounter = 0;} // If buttonstate has been pushed more than 9 times, reset to 0
timing = timingcontrol(); //
timing; // Calling Timing Control Function
 if ( crankAngle >= a && crankAngle <= a1)// If the crankshaft is inbetween 1 to 179 degrees of revolution then a and a1 from timing function
   lcd.print ("++");
    lcd.print ("  ");
 if ( crankAngle >= b && crankAngle <= b1) // If the crankshaft is inbetween 181 to 359 degrees of revolution then use b and b1 from timing function
    lcd.print ("++");
   lcd.print ("  ");
 lcd.setCursor(1,1);
 lcd.print(rpm,DEC);
 start; // Calling Start Mode function
 maint; // Calling Maint Mode Function
//-------------------------Start Mode Function
int startmode (){
 if (TDCtime == 0){
 pushstartState = digitalRead(pushstartPin);
 if (pushstartState == HIGH){
 delay(3000);
 Serial.print ("** Start MODE **");
          lcd.clear();
          lcd.setCursor(3,0);
          lcd.print ("Start Mode");
// Open All Valves for 3.5 Seconds
          digitalWrite( V17Pin, HIGH);
          digitalWrite( V35Pin, HIGH);
          digitalWrite( V28Pin, HIGH);
          digitalWrite( V46Pin, HIGH);
          lcd.setCursor(0,1);
          delay(3500);
// Close All Valves and wait for 15 seconds
          digitalWrite( V17Pin, LOW);
          digitalWrite( V35Pin, LOW);
          digitalWrite( V28Pin, LOW);
          digitalWrite( V46Pin, LOW);
          delay(15000);
          lcd.clear();
          lcd.print("Starting");
   int i;
   int n;
   n = 5;
   for (i = 0; i < n ; i++) { // Do the following function  5 times in a row. Open one intake and all exhaust
          delay(100);
          digitalWrite( V28Pin, LOW);// Open and close exhaust every 10th of a second
          delay(100);}
   int j;
   int m;
   m = 5;
   for (j = 0; j < m ; j++) { // Do the following function  5 times in a row. Open other intake and all exhaust
          delay(100);
          digitalWrite( V46Pin, LOW);// Open and close exhaust every 10th of a second
          delay(100);}
else{
   lcd.setCursor(0,0);
   lcd.print("START *KEY*");// If tdc time still equals 0, Please hit start button again
//-------------------------------- Timing Control Function
int timingcontrol()
 a = 1;
 b = 181;
 a1 = 180 - 18 * buttonpushcounter; // a1 is upper end of first half of crank angle
 if (buttonpushcounter ==0) a1 = a1 -1;  // When buttonpushcounter equals 0, it demands a seperate function to equal 179 rather than 0
 b1 = a1 + 180; // b1 is the upper end of the second half of crank angle
 lcd.print(100-10*buttonpushcounter); // print value of timing
 lcd.print("%");
//-------------------------------- Maint Mode Function
int maintmode() {
   maintbuttonState = digitalRead(maintbuttonPin);
  if (maintbuttonState == HIGH){
    cli(); // disable interrupt
    TDCtime = 0; // set all values to 0 to enforce no "automatic" rotation
    nextTDC = 0;
    prevTDCtime = 0;
    lcd.clear();
    lcd.print("Maintenance MODE");
    digitalWrite(V28Pin,HIGH); // Open all Exhaust and stay open as long as maintbutton is high
    digitalWrite(V46Pin,HIGH);
robtillaart
Quote
If it does compile you can check it.
Rob Tillaart
Newman180
Quote
it compiles, I just didn't know if I applied the it to the "formula" correctly. I guess since you didn't make a comment, I did ;)
I'm still not sure about using the delays in start mode though. I feel like I'll miss an important interrupt.
