Loading...
Pages: [1]   Go Down
Author Topic: Error opening serial port '/dev/ttyUSBx' on Ubuntu  (Read 5410 times)
0
Offline Offline
Newbie
Arduino rocks
View Profile
Hi!
I'm suddenly having problems uploading/communicating with my Arduino board via the Arduino Java IDE.. The strange thing is it happened after working for 2 days straight..
I was editing a program, continously uploading and testing it, when I clicked the "Serial Monitor" button so I could debug (which had worked fine just minutes ago).
First I get a lot of weird char's, like you'd get trying to Serial.print a non-alphanumeric byte (although it was an int) - then, after fiddeling with the Serial rate from the IDE (while the Arduino program was still running), I got an error.
Ctrl+c, ./arduino and "Upload to I/O Board"... Still get an error.
I've tried rebooting Ubuntu, reinstalling the software, removing all components and reprogrammed the Blink-example with my Windows machine (which worked - so I doubt the board is damaged).
Below is the full error message. I'm 100% sure the usb-device is correct.
processing.app.SerialException: Error opening serial port '/dev/ttyUSB0'.
     at processing.app.Serial.<init>(Serial.java:142)
     at processing.app.Serial.<init>(Serial.java:72)
     at processing.app.Uploader.flushSerialBuffer(Uploader.java:66)
     at processing.app.AvrdudeUploader.uploadViaBootloader(AvrdudeUploader.java:73)
     at processing.app.AvrdudeUploader.uploadUsingPreferences(AvrdudeUploader.java:48)
     at processing.app.Sketch.upload(Sketch.java:1632)
     at processing.app.Sketch.exportApplet(Sketch.java:1701)
     at processing.app.Editor$41.run(Editor.java:2004)
     at java.awt.event.InvocationEvent.dispatch(InvocationEvent.java:209)
     at java.awt.EventQueue.dispatchEvent(EventQueue.java:597)
     at java.awt.EventDispatchThread.pumpOneEventForFilters(EventDispatchThread.java:273
     at java.awt.EventDispatchThread.pumpEventsForFilter(EventDispatchThread.java:183)
     at java.awt.EventDispatchThread.pumpEventsForHierarchy(EventDispatchThread.java:173
     at java.awt.EventDispatchThread.pumpEvents(EventDispatchThread.java:168)
     at java.awt.EventDispatchThread.pumpEvents(EventDispatchThread.java:160)
     at java.awt.EventDispatchThread.run(EventDispatchThread.java:121)
Caused by: gnu.io.UnsupportedCommOperationException: Invalid Parameter
     at gnu.io.RXTXPort.setSerialPortParams(RXTXPort.java:171)
     at processing.app.Serial.<init>(Serial.java:132)
     ... 15 more
Logged
Forum Administrator
Cambridge, MA
Offline Offline
Faraday Member
View Profile
WWW
Try editing your Arduino preferences file (~/.arduino/preferences.txt I think) and setting the serial.debug_rate to, say, 9600.  (serial.download_rate should be 19200).
Logged
0
Offline Offline
Sr. Member
Arduino rocks
View Profile
Also make sure /dev/ttyUSB0 exists and has the correct permissions so your account can access it
You can chown it if necessary
Code:
sudo chown username /dev/ttyUSB0
Code:
dmesg
will let you confirm the FTDI chip is getting detected correctly
smiley
Logged
0
Offline Offline
Sr. Member
Arduino rocks
View Profile
Code:
dmesg
should show messages like these when you connect your device
Code:
usb 2-6: new full speed USB device using ohci_hcd and address 5
usb 2-6: configuration #1 chosen from 1 choice
ftdi_sio 2-6:1.0: FTDI USB Serial Device converter detected
ftdi_sio: Detected FT232RL
usb 2-6: FTDI USB Serial Device converter now attached to ttyUSB0
usb 2-6: New USB device found, idVendor=0403, idProduct=6001
usb 2-6: New USB device strings: Mfr=1, Product=2, SerialNumber=3
usb 2-6: Product: TTL232R
usb 2-6: Manufacturer: FTDI
usb 2-6: SerialNumber: FTDxxxxx
Sometimes the device may not be ttyUSB0, it could be ttyUSB1 ttyUSB2 and so on
smiley
« Last Edit: December 03, 2008, 03:19:35 pm by gnu_linux » Logged
0
Offline Offline
Newbie
Arduino rocks
View Profile
Quote
Thanks, this fixed the problem! :-)
Logged
0
Offline Offline
Newbie
Arduino rocks
View Profile
thanks
it works for me also
I just edit
Logged
0
Offline Offline
Newbie
Arduino rocks
View Profile
Ubuntu 9.10
Arduino Uno 0022
It appears to be intermittent, the menu is 10 seconds behind and sometimes the serial port is there and sometimes it dont
yesterday it eventually stabilised, (many unplugs reboots etc etc)  and i ran it all day no probs, i assumed it was because i ran arduino as root which *seemed* to help but today it's not having any.
Code:
sudo ./arduino
terminal implied it was a permission issue so i chowned it to me anyways
Code:
sudo chown username  /dev/ttyACM0
it shows no serial port but i can upload! and fails only when i try to open the serial monitor
i get this message sometimes "serial port already in use" so i rm the lock and try again but i am going in circles
when run sudo ./arduino i get this in the terminal window, it implies my port isn't there
Code:
Native lib Version = RXTX-2.1-7
Java lib Version   = RXTX-2.1-7
RXTX Warning:  Removing stale lock file. /var/lock/LCK..ttyACM0
Binary sketch size: 7564 bytes (of a 32256 byte maximum)
processing.app.SerialNotFoundException: Serial port '/dev/ttyACM0' not found.  Did you select the right one from the Tools > Serial Port menu?
      at processing.app.Serial.<init>(Serial.java:153)
      at processing.app.Serial.<init>(Serial.java:76)
      at processing.app.debug.Uploader.flushSerialBuffer(Uploader.java:75)
      at processing.app.debug.AvrdudeUploader.uploadViaBootloader(AvrdudeUploader.java:93)
      at processing.app.debug.AvrdudeUploader.uploadUsingPreferences(AvrdudeUploader.java:56)
      at processing.app.Sketch.upload(Sketch.java:1603)
      at processing.app.Sketch.exportApplet(Sketch.java:1568)
      at processing.app.Sketch.exportApplet(Sketch.java:1524)
      at processing.app.Editor$DefaultExportHandler.run(Editor.java:2293)
      at java.lang.Thread.run(Thread.java:636)
i don't know the answer but hope there is a fix for this one day
... i got it working briefly today by sudo ./arduino then pasting in my code into the default (and empty) sketch and saved then uploaded it without looking at the selected Serial port, Yay success, but the next upload a minute later failed with the old 'Serial port /dev/ttyACM0 not found' nutmeg
aaaaagggghh
« Last Edit: January 02, 2011, 09:00:00 am by ndmaque » Logged
0
Offline Offline
Newbie
Arduino rocks
View Profile
kubuntu 9.10
arduino-0022
arduino-0021 […]
i have the exact same problem. it started yesterday when i tried arduino-0022 to play with my new ethernet/sd shield. there is a huge lag in the java application and i cannot choose a serial port.
i deleted the preference file, but it did not help. i used a fresh sketchbook folder. i was not able to change/see the serial port and it complained com1 was busy. my serial port is /dev/ttyACM0. i closed the application and edited the serial device in the preference file. when i started the application, it automatically had chosen the duemilanove instead of uno and i could see/set the serial port. i changed it to uno and the serial port was gone.
it is not usable at all anymore and the application is really, really slow/nonresponding smiley-sad
Logged
0
Offline Offline
Newbie
Arduino rocks
View Profile
sorry, i did not realise that this is an ancient thread. should we open up a new one for this, even if it seems to be related?
also i found that after i manage to upload a sketch without serial output, all seems to be fine again. if i upload one of the basic examples without all seems ok (i tried "blink" and can use the software again). if i upload basic-analogreadserial it is broken again.
i will need serial output soon though… :/
« Last Edit: January 17, 2011, 04:34:27 pm by simulation » Logged
Colorado
Offline Offline
Full Member
Arduino 0022 and Ubuntu 11.10 64bit.
View Profile
Quote
If you can,  post the actual error message you are getting.
Does arduino software run normally without the uno plug in? select the duemilanove board, how does it run.
plug in the uno and run the commands:
lsusb -v
ls /dev/tty*
and post results
Logged
0
Offline Offline
Newbie
Arduino rocks
View Profile
thank you, i could solve my problem with some further reading in this fine forum. it is a problem of the old firmware of the 8u2 (uno's replacement for the ftdi). basically it blocks the serial port by constantly sending data when serial output is used in a sketch.
i solved it by
1. setting the arduino in dfu-mode http://www.arduino.cc/cgi-bin/yabb2/YaBB.pl?num=1285962838/10#10
2. uploading the new firmware http://www.arduino.cc/cgi-bin/yabb2/YaBB.pl?num=1286088093/34#34
3. unplugging the arduino and plugging it in again
it's faster than ever now and serial output seems to work fine too smiley
i hope this can help andy mac too.
Logged
Pages: [1]   Go Up
Print
Jump to:
