I've tweaked the emf meter sketch found here:
http://www.hyundaiaftermarket.org/forum/index.php?/blog/3/entry-26-arduino-ef-meteradapting the blogger's circuit diagram:
using the below sketch on the Arduino UNO:
Hertz based electric field meter for Arduino.
Free and Open Source Apache License release.
Apache license is free and open source and simply requires notification
to the author before derrivitive work. adamoutler at hotmail dotcom.
Based on a sketch found here:
http://www.hyundaiaftermarket.org/forum/index.php?/blog/3/entry-26-arduino-emf-meter/
and circuit diagram here:
http://i236.photobucket.com/albums/ff111/DrivingTibNaked/leds.gif
//A note on HZ, if you notice meter oscillations on a known steady
// signal increase or decrease hertz by 1. The oscillations are
// caused when the signals are in near-perfect resonance.
float FrequencyToMonitor=59; //hertz
//setup pins
#define ANTENNA 10 //antenna pin
//10 LEDs on 16 different pins
// int LEDPin[]={ 2, 3, 4, 5, 6, 7, 8, 9, 11, 12 } ;
int LEDPin[]={ 12, 11, 9, 8, 7, 6, 5, 4, 3, 2 } ;
int LEDCount=10; //number of LEDs
//setup initial global values
int LEDCounter=0; //initial value of LEDs to display
int HalfPeriodMicroseconds=0;// initial value of halfwavelength
SETUP defines pins and performs POT(Power On Test) on LEDs
double HalfPeriod=((1/FrequencyToMonitor)*.5); //Half-period in seconds from frequency
HalfPeriodMicroseconds=int(1000000*HalfPeriod); //Convert period seconds to microseconds integer
pinMode(ANTENNA, INPUT); //set antenna pin
for (int Pin=0; Pin < LEDCount; Pin++) { //initialize each LED
pinMode(LEDPin[Pin], OUTPUT);
digitalWrite(LEDPin[Pin], HIGH); //Turn the LED on
delay(100);
digitalWrite(LEDPin[Pin], LOW); //Turn the LED back off
swingLEDs(); //perform LED check to verify LED functionality
LOOP checks for value of antenna to go high and then low
if change is seen, then 2 LEDs are lit, otherwise total number
of LEDS are decreased. This allows for a magentic effect when
near the field.
void loop(){
int ANTENNAValue=0; //sets and resets ANTENNAValue
int OldANTENNAValue=0; // as well as OldANTENNAValue
for ( int Pass=0; Pass < 4; Pass++ ) {//take 4 readings
ANTENNAValue=digitalRead(ANTENNA); // from the antenna
if ( ( ANTENNAValue == HIGH ) && ( OldANTENNAValue == LOW ) ) {
incrementLED(); //If a change is detected increase twice
incrementLED(); // 4 passes means 3 changes total
} else if ( ( ANTENNAValue == LOW ) && ( OldANTENNAValue == HIGH ) ) {
incrementLED(); // This makes the meter rise by
incrementLED(); // a total factor of 2 and
decrementLED(); // if there is no change it falls by 1
OldANTENNAValue=ANTENNAValue; //Log old value for next pass
delayMicroseconds(HalfPeriodMicroseconds); // half-wave pause before next reading
delayMicroseconds(HalfPeriodMicroseconds); //visual delay between reading passes
delayMicroseconds(HalfPeriodMicroseconds); //twice to avoid extremely long numbers
FUNCTION swingLEDs tests the LEDs by lighting
them up sequentially. Each LED is brought high
then low twice.
void swingLEDs(){
digitalWrite(LEDPin[Pin], HIGH); // light LEDs from left to right
delay(50);
digitalWrite(LEDPin[Pin], LOW); // clear LEDs from left to right
delay(50);
for (int Pin=LEDCount; Pin > -1; Pin--) {
digitalWrite(LEDPin[Pin], HIGH); // light LEDs from right to left
delay(50);
digitalWrite(LEDPin[Pin], LOW); // clear LEDs from right to left
delay(50);
FUNCTION incrementLED increases the number
of LEDs lit by 1.
void incrementLED(){
if ( LEDCounter < LEDCount - 1 ){ LEDCounter++;} //if not max increase
digitalWrite(LEDPin[LEDCounter], HIGH); //light new LED
FUNCTION decrementLED decreases the number
of LEDs lit by 1.
void decrementLED(){
digitalWrite(LEDPin[LEDCounter], LOW); //turn off current LED
if ( LEDCounter >= 0 ){ LEDCounter-- ;} // if not zero, decrease
Everything works as expected. Woohoo!
I noticed an odd thing when I first tried this
int LEDPin[]={ 11, 10, 9, 8, 7, 6, 5, 4, 3, 2 } ;
for my pins. Pin 10 would light up at the same time as pin 2. I cannot say why, so that was the main reason why pin 10 became my choice for the antenna. Also, I chose pin 10 for the antenna because Pins, 13 and 0 didn't seen to work well for this. I didn't try pin 1. Pins 12 and 11 Use blue LED's. Pins 9 and 8 are green. 7 and 6 are yellow. 5 and 4 are orange. 3 and 2 are red.
Dumb Noob Questions:
1. Why would pin 10 light up at the same time as pin 2 when used as shown in the one-line code LEDPin[] array as above, and why in general do some of the digital pins not work as expected? For instance, I couldn't get pin 13 to act as an antenna, but it's fine as an LED.
2. I tried two different size antennae (3" and 6") but could distinguish little difference in sensitivity. What is a good antenna length for sensing something at about 60Hz? Why aren't we using an analog-in for the antenna?
3. I notice that I had to isolate the UNO from the AC power supply when connecting the UNO via USB to the computer in order to get a valid reading. But when I put my hands near the antenna (within six inches), I get a high reading. It doesn't make sense that the human body should be cycling at 60 Hz. What's really happening?
4. It looks like the fluctuation matches my heart beat, but I'm guessing this is really the oscillation the original blogger noted about in the sketch. Correct?
5. I've used 220 Ohm resistors instead of the 440. Might this affect sensitivity? I'm guessing not. But if so, how?
Cheers.
