Author Topic: frequencyTimer2 problem  (Read 1466 times)
can someone help me..... i have a problem about timer2.. and this are the following problems.... so please help me i need it now... huhuhu.. how can i fix it..
C:\Program Files\arduino-0021\libraries\FrequencyTimer2\FrequencyTimer2.cpp: In static member function 'static void FrequencyTimer2::enable()':
C:\Program Files\arduino-0021\libraries\FrequencyTimer2\FrequencyTimer2.cpp:150: error: 'TCCR2' was not declared in this scope
C:\Program Files\arduino-0021\libraries\FrequencyTimer2\FrequencyTimer2.cpp:150: error: 'COM20' was not declared in this scope
C:\Program Files\arduino-0021\libraries\FrequencyTimer2\FrequencyTimer2.cpp: In static member function 'static void FrequencyTimer2::disable()':
C:\Program Files\arduino-0021\libraries\FrequencyTimer2\FrequencyTimer2.cpp:160: error: 'TCCR2' was not declared in this scope
C:\Program Files\arduino-0021\libraries\FrequencyTimer2\FrequencyTimer2.cpp:160: error: 'COM20' was not declared in this scope
Dallas
Shannon Member
Which board is selected in the Arduino IDE?
arduino duimelanove/ nano w/ atmega328..
Dallas
Shannon Member
http://www.google.com/search?q=frequencytimer2+328+arduino
http://www.arduino.cc/cgi-bin/yabb2/YaBB.pl?num=1239820770
  FrequencyTimer2.h - A frequency generator and interrupt generator library
  Author: Jim Studt, jim@federated.com
  Copyright (c) 2007 David A. Mellis.  All right reserved.
  This library is free software; you can redistribute it and/or
  modify it under the terms of the GNU Lesser General Public
  License as published by the Free Software Foundation; either
  version 2.1 of the License, or (at your option) any later version.
  This library is distributed in the hope that it will be useful,
  but WITHOUT ANY WARRANTY; without even the implied warranty of
  MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.  See the GNU
  Lesser General Public License for more details.
  You should have received a copy of the GNU Lesser General Public
  License along with this library; if not, write to the Free Software
  Foundation, Inc., 51 Franklin St, Fifth Floor, Boston, MA  02110-1301  USA
#include <FrequencyTimer2.h>
#include <avr/interrupt.h>
void (*FrequencyTimer2::onOverflow)() = 0;
uint8_t FrequencyTimer2::enabled = 0;
#if defined(__AVR_ATmega168__) || defined(__AVR_ATmega328P__)
SIGNAL(SIG_OUTPUT_COMPARE2A)
#else
SIGNAL(SIG_OUTPUT_COMPARE2)
#endif
    static uint8_t inHandler = 0; // protect us from recursion if our handler enables interrupts
    if ( !inHandler && FrequencyTimer2::onOverflow) {
      inHandler = 1;
      (*FrequencyTimer2::onOverflow)();
      inHandler = 0;
void FrequencyTimer2::setOnOverflow( void (*func)() )
    FrequencyTimer2::onOverflow = func;
    if ( func) TIMSK2 |= _BV(OCIE2A);
    else TIMSK2 &= ~_BV(OCIE2A);
#else
    if ( func) TIMSK |= _BV(OCIE2);
    else TIMSK &= ~_BV(OCIE2);
#endif
void FrequencyTimer2::setPeriod(unsigned long period)
    uint8_t pre, top;
    if ( period == 0) period = 1;
    period *= clockCyclesPerMicrosecond();
    period /= 2;            // we work with half-cycles before the toggle
    if ( period <= 256) {
      pre = 1;
      top = period-1;
    } else if ( period <= 256L*8) {
      pre = 2;
      top = period/8-1;
    } else if ( period <= 256L*32) {
      pre = 3;
      top = period/32-1;
    } else if ( period <= 256L*64) {
      pre = 4;
      top = period/64-1;
    } else if ( period <= 256L*128) {
      pre = 5;
      top = period/128-1;
    } else if ( period <= 256L*256) {
      pre = 6;
      top = period/256-1;
    } else if ( period <= 256L*1024) {
      pre = 7;
      top = period/1024-1;
      pre = 7;
      top = 255;
    TCCR2B = 0;
    TCCR2A = 0;
    TCNT2 = 0;
    ASSR &= ~_BV(AS2);    // use clock, not T2 pin
    OCR2A = top;
    TCCR2A = (_BV(WGM21) | ( FrequencyTimer2::enabled ? _BV(COM2A0) : 0));
    TCCR2B = pre;
#else
    TCCR2 = 0;
    TCNT2 = 0;
    OCR2 = top;
    TCCR2 = (_BV(WGM21) | ( FrequencyTimer2::enabled ? _BV(COM20) : 0)  | pre);
#endif
unsigned long  FrequencyTimer2::getPeriod()
    uint8_t p = (TCCR2B & 7);
    unsigned long v = OCR2A;
#else
    uint8_t p = (TCCR2 & 7);
    unsigned long v = OCR2;
#endif
    uint8_t shift;
    switch(p) {
      case 0 ... 1:
      shift = 0;
      break;
      case 2:
      shift = 3;
      break;
      case 3:
      shift = 5;
      break;
      case 4:
      shift = 6;
      break;
      case 5:
      shift = 7;
      break;
      case 6:
      shift = 8;
      break;
      case 7:
      shift = 10;
      break;
    return (((v+1) << (shift+1)) + 1) / clockCyclesPerMicrosecond();   // shift+1 converts from half-period to period
    FrequencyTimer2::enabled = 1;
    TCCR2A |= _BV(COM2A0);
#else
    TCCR2 |= _BV(COM20);
#endif
    TCCR2A &= ~_BV(COM2A0);
#else
    TCCR2 &= ~_BV(COM20);
#endif
another problem occur... like
In file included from C:\Program Files\arduino-0021\hardware\arduino\cores\arduino/WProgram.h:6,
                 from sketch_jan26a.cpp:70:
c:/program files/arduino-0021/hardware/tools/avr/lib/gcc/../../avr/include/math.h:439: error: expected unqualified-id before 'double'
c:/program files/arduino-0021/hardware/tools/avr/lib/gcc/../../avr/include/math.h:439: error: expected `)' before 'double'
Dallas
Shannon Member
#ifndef FREQUENCYTIMER2_IS_IN
#define FREQUENCYTIMER2_IS_IN
[glow]//[/glow]#include <wiring.h>
[glow]#include <WProgram.h>[/glow]
class FrequencyTimer2
  private:
    static uint8_t enabled;
  public:
    static void (*onOverflow)(); // not really public, but I can't work out the 'friend' for the SIGNAL
  public:
    static void setPeriod(unsigned long);
    static unsigned long getPeriod();
    static void setOnOverflow( void (*)() );
    static void enable();
    static void disable();
#endif
sir.. where do i put that code?... confusing..
