Loading...
Pages: 1 [2]   Go Down
Author Topic: How to set a value for millis()?  (Read 1678 times)
0
Offline Offline
Jr. Member
Arduino rocks
View Profile
have you seen this thread?
http://www.arduino.cc/cgi-bin/yabb2/YaBB.pl?num=1167861718
in one place Member macsimski suggests this declaration
extern volatile unsigned long timer0_overflow_count;
and this code to reset
timer0_overflow_count = 0;
this resets to 0... maybe it can be coaxed to set to a specific value.
Logged
Global Moderator
Dallas
Online Online
Shannon Member
View Profile
WWW
Quote
I have.  And there is a nasty subtle bug in what was proposed as a solution.
Logged
0
Offline Offline
Full Member
... only learning ...
View Profile
@ Coding Badly:
may you help me to understand better the issues you mentioned? I tried to run the code for hours, and it continue working.
Sometimes, the comparison returns false and it is probably caused my the "on going" modification of the variable. But, I only realize the mentioned operation just after the "true", that is after the modification if this is the case.
Thanks
Logged
Pages: 1 [2]   Go Up
Print
Jump to:
